Old August 27th, 2014, 13:28   #46
Ifixit
Ifixit's Avatar
Originally Posted by jonlowe View Post
That is true with the original allroad ECU. But on the Passat BHW ecu, I can't find any correlation to the pins you mention. There are two connectors on the Passat ecu, T60 and T94. To which are you referring?
Ok so then he must be using EDC16 ecu (the original NA market BHW controller)
my next question would be is the ecu coding set for climatronic?
I believe the only coding option for that control unit is manual or automatic climate control unless his tuner changed the firmware
BHW with climatronic only has one wire from clima T16B to ECU T94 pin 50 blk/gry
also has a wire from ecu to passat fan module which will also be different on allroad and probably wont effect compressor engagement
Any engine DTCs?
lets check clima DTCs first now can we?
the thing is the clima units are different between the two cars so pinouts/signal may not match up exactly
also, A6 TDI of that era used edc15P in Europe I believe so control scheme in ECU may be different
elsawin is down here right now so I dont have access to allroad tdi wire diagrams but maby someone else does?
mine will be fixed soon...
VW AUDI & TDI Repair in VT fullcircleauto@gmavt.net 802-496-9236
Vw Transmission, DSG Repair/Rebuilding
Petroleum Enthusiast
Ifixit is offline   Reply With Quote
Old August 27th, 2014, 13:47   #47
Scott_DeWitt
Scott_DeWitt's Avatar
Why not verify what the real Allroad diesels used regarding pins? Also the 1.9 was put into A6's as well.
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old August 27th, 2014, 13:53   #48
Ifixit
Ifixit's Avatar
Thats what I was thinking but no elsa right now..
DTCs would be a great place to start for no compressor engagement IMO
ECU would be EDC15P in the A6 1.9 of that era right scott?
Old August 27th, 2014, 14:01   #49
Scott_DeWitt
I believe this to be correct for the PD models (2001-2005).
Old August 27th, 2014, 14:08   #50
jonlowe
Any engine DTCs?
As I pointed out in post 28, T94/85 also connects to the Passat Climatronic T12/2, 'RPM increase". This doesn't show directly on the ECU side of the ELSA wiring diagram, but does show on the Climatronic side of the wiring diagrams. So there are two connections between the climatronic and the Passat ECU.
Good thought about the coding. That may help him.
Jon
jonlowe is offline   Reply With Quote
Old August 27th, 2014, 14:09   #51
jonlowe
Good point. I'll check.
Old August 27th, 2014, 14:27   #52
Ifixit
Ifixit's Avatar
Yes A6 1.9 L with climatronic should be the closest wire diagram match
Although on the ECUs side the pin out won't match as it will be EDC15P
But if there is only two wires from climb a Tronic unit to ECU then it may work with those two wires connected to the right pins
Old August 27th, 2014, 15:37   #53
jonlowe
Well, ELSA is giving me fits also. It's not letting me see the engine or climate control wiring diagrams for any A6's with the 1.9 TDI engine.
We really need to understand what the three signal wires between the stock allroad ECU and climate control are. At least on the Passat I was able to find out what the Climatronic signals were. I can't find anything similar for the allroad.
Jon
Old August 28th, 2014, 05:39   #54
Ifixit
Ifixit's Avatar
Ive found one description on the allroad 2.7 diagram:
clima A2 to 2.7 ECU pin 37 grn/blu "Tachometer"
Shows a direct connection beetween clima and ECU with a tap comming off that goes to" Tachometer"
not sure if that is going to be helpful but I believe some clusters have a RPM out square wave signal?
beautiful mitchell wire diagrams
Old August 28th, 2014, 12:10   #55
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
What transmission are you using? .54 is not an 01E gear ratio.
Yeah my bad Scott, It's a .56 6th.
Wing_man is offline   Reply With Quote
Old August 28th, 2014, 12:18   #56
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
As for active DTC's I've left my VCDS cable and laptop at my shop in ottawa, I will scan in a few days I'll see what I find. I'll also do some more digging for the pressure switch thing.
The econ light is on when is start the vehicle. If I hit the econ button the light goes off for a few seconds then comes back on.
Old August 28th, 2014, 13:18   #57
Ifixit
Ifixit's Avatar
Climatronic is locking out ac due to a system fault then..
check codes and let us know
Old August 28th, 2014, 14:38   #58
jonlowe
Ok, got ELSA working. I found that the 2001 A6 with the 1.9 AJM TDI engine uses a climate control in the same family as the allroad, if not exactly the same one; they have variants for w/wo heated seats, NAV, etc. The AJM is the only 1.9 I could find that used a compressor clutch rather than the compressor control that Scott mentioned. In addition, Audi made a running change in the climate control in 2002, and I don't know which one he has or if it even makes a difference in the wiring.
Anyway, pin numbers between the BHW and AJM ecu's don't match at all, but wire colors seem to match reasonably well, discounting for differences in the engine electronics.
The A6 climate control shows:
1. sw/ge (black/yellow) going from A7 to the ECU. This seems to match up with the same function as black/yellow on the Passat ecu, terminal T94/85.
2. ws/bl (white/blue) going from C13 to the ECU. Unfortunately, the AJM ecu has multiple white/blue wires. The connection to C13 on the climate control is interesting because it is only noted for diesels. The AJM ecu has white/blue on terminal 61, but that goes to the EGR valve. It also has white/blue on terminal 15, that indicates it goes to the climate control. I don't know what the function is. Finally, the AJM ecu has a sw/bl changing to white/blue at terminal 20. This appears to be a speedometer related item. The Passat ecu has two white/blue wires, one of which is only used for an additional heater (not for US/CDN), and the other going to the speedo. So I don't know where to connect this wire from C13 on the Passat ecu, or if it is even necessary.
3. sw/gr (Black/grey) going from C15 to the ecu. This appears to match T94/50 on the Passat ecu, same color wire.
4. gn/bl (green/blue) going from A2 to the ecu. This appears to be the engine speed signal. I don't know where this signal is on the Passat ecu, or if it is available there. I would think it would be, but I don't know where. That color wire doesn't appear to exist on the Passat ecu. The Passat climate control has a pin for it, but it doesn't appear to be used on the wiring diagram. I also can't find it on the Passat gauges pinout. They may use the CAN bus on the Passat.
I've got PDFs of the A6 diagrams (and the Passat) if you need them. I'd post them, but there only seems to be a way to post images, not PDFs.
Jon
Old August 28th, 2014, 14:58   #59
Scott02
TDI(s): Too Many
Fuel Economy: 51/45/41
Wish I had some to add, but when I couldn't figure it out "simply", I gave up and moved onto other far more important items.
2015 GSW DSG - 27kmi, Kerma engine tune
2011 JSW DSG - 160kmi, Malone DSG tune - Buyback soon
03 Jetta Wagon TDI 5MT - 175kmi, 2.5"F 2"R lift, 215/75r15 tires, self tuned
02 allroad TDI 6MT - 150kmi, current project, getting a BSM deleted BHW and euro TDI geared 01E quattro
Scott02 is online now   Reply With Quote
Old August 28th, 2014, 18:42   #60
Scott_DeWitt
Most of the climate control head differences are cosmetic. The plastic finish changed in 2002 and the seat heater switches are mounted in the head unit. Not sure about the nav, but the head unit is probably slightly smaller. The only wiring differences that I know of are the cars with solar sunroof, there is an additional few wires that go to the sunroof.
2002 Audi Allroad ALH Conversion Dirty_Al TDI Conversions 45 June 2nd, 2018 07:07
02 Allroad BHW swap w/ euro TDI 6MT Scott02 Other TDI/Diesel Picture Gallery 23 August 21st, 2014 09:13
Looking into an BHW swap into an 2001 allroad arjax TDI Conversions 7 July 14th, 2014 20:06
Audi Allroad Diesel Conversion Dirty_Al TDI Conversions 14 October 14th, 2013 21:41
Audi 3.0 TDi Allroad donDavide TDI News/Tech 20 June 20th, 2007 07:34
Page generated in 0.47532 seconds with 10 queries
[Output: 138.05 Kb. compressed to 115.99 Kb. by saving 22.06 Kb. (15.98%)]
