Old August 18th, 2014, 12:13   #1
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Default Audi Allroad BHW TDI conversion.
This has been my ongoing project over the last few months, I'm currently driving the car, it's an absolute dream! Enjoy the pictures.
The donor car. 2005 Passat TDI, blown auto trans, Balance shaft delete
Alh oil pump mod, New turbo Cams and lobes, healthy little engine.
The project car, 2002 audi allroad 2.7TT 6spd from California.
And it begins...
Made sweet shop chair from Passat seat...
Modified front cross member from Passat, notice the front stabilizer mount.
Now the front cross member with added Passat radiator mounts.
Wing_man is offline   Reply With Quote
Old August 18th, 2014, 12:14   #2
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Downpipe.
Clean donor.
Engine's in.
Cruising speed in 6th with the euro gearbox.
Old August 18th, 2014, 13:09   #3
Hasenwerk
Hasenwerk's Avatar
Great work!
Anything that you would do differently if you had to do it again?
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old August 18th, 2014, 16:10   #4
riddleyo
riddleyo's Avatar
Awesome project, great job. How about a video!?
riddleyo is offline   Reply With Quote
Old August 18th, 2014, 22:46   #5
96cali
TDI(s): Passat
Very nice and thanks very much for sharing! That's my dream car right there.
How did you handle the AC lines and air suspension? Could you have used any stock exhaust components instead of all that fab work?
96cali is offline   Reply With Quote
Old August 19th, 2014, 03:50   #6
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
The stock Passat downpipe would have been okay, some fabrication is absolutely necessary if you want to re-use the original audi cat back system. I made a new downpipe that gave the transmission a lot of clearance, that way when ever I have to remove the transmission I don't need to bother with removing the downpipe first.
Old August 19th, 2014, 04:17   #7
Scott02
TDI(s): Too Many
Fuel Economy: 51/45/41
Damn, I've been beaten!
Mine still looks like your "clean donor" pic...
Congrats!
Please be sure to report back mpg figures, as that's the reason for doing all this work, after all.
2015 GSW DSG - 27kmi, Kerma engine tune
2011 JSW DSG - 160kmi, Malone DSG tune - Buyback soon
03 Jetta Wagon TDI 5MT - 175kmi, 2.5"F 2"R lift, 215/75r15 tires, self tuned
02 allroad TDI 6MT - 150kmi, current project, getting a BSM deleted BHW and euro TDI geared 01E quattro
Scott02 is offline   Reply With Quote
Old August 19th, 2014, 08:00   #8
mannytranny
mannytranny's Avatar
TDI(s): 02 Jetta
Passat engine bolts up easily to Audi trans?
mannytranny is offline   Reply With Quote
Old August 19th, 2014, 09:19   #9
Scott_DeWitt
Scott_DeWitt's Avatar
Certain Audi transmissions yes.
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old August 19th, 2014, 13:01   #10
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Yeah, I believe the O1E transmissions will bolt up to the vw 4 Cyl diesels. It's just a matter of getting a transmission with proper gearing ratio's. The transmission I used is from a 1.9 European probably AFN tdi out of an a6 Quattro or something like that, transmission code is FTF... I had to swap out the original audi Allroad transmission cv flanges into this transmission, and replace my rear differential with one that had the same final drive as my FTF transmission... 4.11 final drive I believe it was.
Old August 19th, 2014, 14:09   #11
vwztips
vwztips's Avatar
Did you have to add what looks like a couple of 3/4" diameter tubes to the turbo crossover pipe? Was it something the Audi needed?
vwztips is offline   Reply With Quote
Old August 19th, 2014, 16:15   #12
otty
otty's Avatar
Notice you have a Euro cluster (only KM/h). I do too. Mine came from the Euro AVF TDI donor car. Why do you have one? Just curious.
Looks like a sweet ride
Malone tuned stage 1 and loving it!
otty is offline   Reply With Quote
Old August 19th, 2014, 19:31   #13
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Yes, that's how I mounted the lower part of the Passat rad. The bottom part of the Audi rad support needs to be cut in order to fit the crossover pipe... I suppose you could also just add an after market intercooler pipe and leave the front end as-is... Mind you the way I did it looks more original.
Old August 19th, 2014, 19:33   #14
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Thanks, It's not euro, I'm canadian KM/H haha.
Old August 19th, 2014, 20:32   #15
jonlowe
How's the power? The all road is about 600 lbs heavier than the Passat, according to the figures I've found. Does the engine have a tune?
Did you get your climate control electrical issues sorted out?
What did you have to do to the fuel system to work with diesel fuel?
I'm very impressed.
Sent from my Nexus 5 using Tapatalk
jonlowe is offline   Reply With Quote
2002 Audi Allroad ALH Conversion Dirty_Al TDI Conversions 45 June 2nd, 2018 07:07
02 Allroad BHW swap w/ euro TDI 6MT Scott02 Other TDI/Diesel Picture Gallery 23 August 21st, 2014 09:13
Looking into an BHW swap into an 2001 allroad arjax TDI Conversions 7 July 14th, 2014 20:06
Audi Allroad Diesel Conversion Dirty_Al TDI Conversions 14 October 14th, 2013 21:41
Audi 3.0 TDi Allroad donDavide TDI News/Tech 20 June 20th, 2007 07:34
Page generated in 0.16368 seconds with 10 queries
[Output: 131.03 Kb. compressed to 109.96 Kb. by saving 21.07 Kb. (16.08%)]
