Airborne1cav
Hello, so earlier this week I was removing the foam box under my passenger seat to determine if I had a 9W7 or Bluetooth installed. (Plan on installing a RNS-510). I have a 2014 Passat SE with the RNS-315 installed. I was told it had built in Bluetooth, but still saw the foam box so I wanted to find out what was inside? Removing the foam cover I found the Car-Net module, and accidentally broke a cable in the process. After taking a few pictures, I re-installed the foam cover and started up the car. The navigation system, voice commands, Bluetooth, radio and everything work EXCEPT my Carnet light on the overhead panel switched to red? The call button still works, and my mobile app still updates with how many miles, fuel left in tank etc. HOWEVER, the parking position never updates ! So by a process of elimination I have determined that the cable I broke seems to be a GPS interlink with the Carnet module ? (just my guess) I don't plan on subscribing to Carnet, so I could care less if my Carnet location doesn't update.
Questions -
- Can anyone confirm this is the GPS cable ?
- Will this affect switching over to the RNS-510 ?
- Is the Bluetooth built in this box also ? The connection looks identical to a 9W7 port right ?
- Any idea if I can order just this cable ? Or the whole harness ?
- Hooking it back up looks to be virtually impossible as the cable is already extremely short already.
Notes -
- First 2 pictures are the Carnet Module, second two pictures are the cable I broke and where it was connected (black box marked China & VW)
- Also, I will have a VCDS cable available for use next week....
- Thanks for any input !
[/url]photo (4) by AustinB747, on Flickr[/IMG]
[/url]photo (3) by AustinB747, on Flickr[/IMG]
[/url]photo (2) by AustinB747, on Flickr[/IMG]
[/url]photo by AustinB747, on Flickr[/IMG]
Questions -
Notes -
