Old July 16th, 2014, 10:43   #1
nate0031
nate0031's Avatar
TDI(s): 96 B4 Passat
Default Audi A6 with a CJAA Common Rail
I figure it's time I start a build thread. I'm preparing to swap a 2010 CJAA in place of the 2.7tt in a 2000 Audi A6. The car already has a 6-speed 01E, so that's being left alone for now. I'll add pictures and more details later, but I have a couple quick questions.
Is there a difference between the ALH/BEW and BRM/CBEA/CJAA oil pickup tubes? I know the 1.8t tube works for an ALH in a longitudinal application, but would the 1.8t tube also fit the CJAA oil pump? Idparts lists two different parts, one for an ALH/BEW and another for the BRM/CBEA/CJAA but I can't distinguish any differences from the photos alone.
Oil pan. Everything I'm finding suggests that the AWM 1.8t oil pan will fit the CJAA just fine. Can anyone confirm this before I buy one?
Thanks!
2005.5 VW Jetta - 1.9 Turbo Diesel - 5 Speed
2000 Audi A6 - CJAA Common Rail TDI - Quattro - 01E
2005 Ford F-350 - 6.0L Turbo Diesel - Auto - 4x4
nate0031 is offline   Reply With Quote
Old July 16th, 2014, 11:18   #2
jimbote
jimbote's Avatar
the difference in the pickup tubes is due to the oil pan difference....I tried to put a BRM pan on an ALH but the pickup interfered with the bottom of the pan....so the pickup tube is slightly different between the common rail, BRM and the earlier VE/PD's ....I think you would probably be ok using the 1.8t longitudinal pickup and pan..
Old July 16th, 2014, 11:35   #3
nate0031
nate0031's Avatar
Thanks Jim!
Old July 23rd, 2014, 07:53   #4
nate0031
nate0031's Avatar
Does anyone have a way to look up the part number for a 2010 Audi A4 2.0 TDI (as sold in Europe) accessory bracket? Ideally I need the part numbers for the bracket, idler, and tensioner pulleys. I don't have access to ETKA. Found a few places to download it online, but that seemed a bit sketchy. Maybe I'm just new to it, but I couldn't seem to find it on vagcat. Thanks.
Old July 23rd, 2014, 17:07   #5
baja_brewer
Assuming you'll need to source it as well, PM Frans. He's in the Netherlands and is a vendor of used parts on here with good prices.
baja_brewer is offline   Reply With Quote
Old July 25th, 2014, 06:45   #6
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Let me know if you get in touch w him, been nearly a month and still no reply to me on T4 TDI conversion parts
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old July 25th, 2014, 14:57   #7
nate0031
nate0031's Avatar
Will do. Are those parts you already bought or need to buy?
Old July 25th, 2014, 16:13   #8
94x
I just bought a rebuilt DUJ Eurovan trans and conversion parts 2 weeks ago, delivered last Tuesday. Use his email address - dutchautoparts.com
Trusted TDI Mechanic in western MA
& Malone Tuning Dealer
New shop location, Westfield MA.
413 Auto Repair (413) 455-5602
94x is offline   Reply With Quote
Old July 25th, 2014, 16:33   #9
GTiTDi
GTiTDi's Avatar
Thank you!
MK2 GTI build
schnellsnailFB
Old July 25th, 2014, 19:14   #10
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
I look forward to this. Good Luck, Also, Boraparts may be able to help.
2003 Jetta GLS TDi TTbushings
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old July 28th, 2014, 06:26   #11
nate0031
nate0031's Avatar
GTiTDi - Frans got back to me promptly as well, so I would try him at the email given above if you haven't yet, that's what I used.
Aside from getting the ECU tuned and the new accessory bracket, all the parts have come in. I just got the Bentley manual as well, so I'm going to spend some time studying the wiring diagrams. I'll make a spreadsheet with the pin-out, and be sure to document what I do to the harness to make it work in this car. I can see that being pretty useful on here.
Getting the 2.7t pulled out so I can get the ball rolling.
Old August 5th, 2014, 08:57   #12
nate0031
nate0031's Avatar
Pictures to come. I'm hoping to have the CJAA setting down in there after this weekend. Then it's a wiring game, lol.
Old August 18th, 2014, 09:39   #13
nate0031
nate0031's Avatar
I was swapping on the new oil pan yesterday, and just about had a heart attack. The AWM pan wasn't the same. The bolt pattern is the same, but the CJAA pan has sections that extend out beyond the bolt holes to clear the windage tray. Here's a Picture:
After removing the windage tray, I see that the block continues underneath, so there is a straight path and no issue with having a surface to seal against. So one question, what to do about the windage tray? I'm guessing simply cutting the tabs off would not be best. Is there another that will fit with this pan? One out of an ALH maybe?
Old August 18th, 2014, 10:28   #14
vwztips
vwztips's Avatar
Subscribed. I picked up a 2000 A6 2.7t with 6 speed manual, but the plan is to install a BHW and a euro spec TDI gearbox. I already know the RPM the gasser gearbox will be turning so no need to go back and take out and install the gearbox twice as I would not be happy with the RPMs. Good luck and make good notes.
vwztips is offline   Reply With Quote
Old August 18th, 2014, 10:52   #15
Hasenwerk
Hasenwerk's Avatar
What are you doing for engine management? Are you going to take the entire CAN bus controller / ABS system / instrument pod to make it all work?
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Audi A6 Diesel, A6 and A8 Hybrids Models to Get Delayed U.S. Launch TDIMeister Other VW Group TD(I)s 7 December 10th, 2011 22:18
2.0 Common rail a6 Injector coding c_higgins OBD Scanners 3 November 29th, 2010 17:58
Audi Cross Coupe Quattro Concept: 2.0 Common Rail TDI Is Here (204hp/295 lb-ft) chewy TDI News/Tech 35 April 29th, 2007 21:56
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 21:33
Audi A8 3.0 TDI 24valve common rail 2fastdre TDI News/Tech 13 September 8th, 2003 09:53
Page generated in 0.16244 seconds with 10 queries
[Output: 133.46 Kb. compressed to 110.64 Kb. by saving 22.82 Kb. (17.10%)]
