Old July 6th, 2014, 21:18   #1
midntdi
Fuel Economy: 40-50 mpg
Default My build thread AKA my slide down the slippery slope
A bit of background:
I bought this 2002 ALH Jetta GL with an automatic transmission with 98k mi on the clock.
This is the car when I bought it
Fast forward 7 years and this how she sat
As you can see some things have changed.
Torden: http://forums.tdiclub.com/showthread.php?t=418613
Lyn:2015 Night Blue Golf TDI
midntdi is offline   Reply With Quote
Old July 6th, 2014, 21:47   #2
midntdi
Since purchasing the car I have left the engine stock, preferring to do chi-chi cosmetic mods as I was not entirely sure of my mechanical skills.
So far here is what I have done:
Brushed Aluminum Trim and three spoke steering wheel
.:R pedals
MFA Retrofit with custom Housing modification
OEM Rep HID Headlights
GTI Recaro Seats
Le Castellette Wheels
Black headliner and pillars
Lock pin delete
Updated '04 center console
Updated '04 taillights
Sharkfin antenna
2.5" Turbo back exhaust to replace a leaking exhaust
DG Race pipe and EGR delete kit
and probably more that I am forgetting.
Old July 6th, 2014, 22:13   #3
midntdi
Well last year I got a good deal on some parts so I snatched them up and they have been sitting around for a while.
I have been working over the past few weeks to install these parts (and others)
While I won't give away every detail here is what has happened so far.
Using this thread http://forums.tdiclub.com/showthread.php?t=301184
I upgraded from the early style to later style shift tower
Using this thread http://forums.vwvortex.com/showthrea...h-Replacement& with some modifications.
I upgraded my stock clutch to this one
SBC II END
I also removed all the intercooler piping intake manifold, turbo and exhaust manifold.
While disassembling everything I found this
Probably needed to be replaced. Fortunately it will be.
Also installed a PD Liftpump using this guide http://idparts.com/downloads/PDLiftP...Guide_v1.5.pdf
Old July 7th, 2014, 11:25   #4
duwem
Fuel Economy: Used to get 45, but big wheels, big brakes and a roof rack, 36mpg now
Hood notch filler in the plans?
2002 Golf GLS TDI 5spd-288,000 miles
Panzer FMJ Skid Plate, PP520's on Flow Balanced Injectors, H&R 28mm Rear Swaybar, Eurosport X Brace, TT Shifter, 42DD shifter Bushings, exhaust restriction reduction, Eibach Pro Kit Springs, Koni STR.T Struts/Shocks, TT front control arms, spindles and brakes, 17" wheels w/ Potenza Summer Tires
duwem is offline   Reply With Quote
Old July 7th, 2014, 17:44   #5
midntdi
Actually it isn't, I am thinking of either a custom mesh grill to go with future body styling or going back to a stock grill.
Old July 10th, 2014, 15:15   #6
Countryboy07
Countryboy07's Avatar
TDI(s): '02 Jetta
Looks good so far! Love the color... I'm a little biased though.
2002 Jetta TDi - Some things done... FK streetlines, Monte's with worn tires, spacers...
~Constantly under construction~
Countryboy07 is offline   Reply With Quote
Old July 10th, 2014, 15:35   #7
midntdi
Thanks. I love the color too, I just do not like the fading issue.
Old July 11th, 2014, 21:44   #8
JeffDes4
TDI(s): Jetta
Love the timeline photos, thanks for sharing both. The color is really nice. Time for a new paint job now.
JeffDes4 is offline   Reply With Quote
Old August 13th, 2014, 17:07   #9
midntdi
So a little bit of an update.
Car has been sitting like this for a while now waiting for injectors and my turbo.
Yesterday I received my new nozzles from Boraparts and began installing them.
They are PP502s which should pair nicely with my turbo which I am still waiting on. Additionally I replaced and cleaned up all my vacuum lines. Other then that I have been working on a couple other small project which I will reveal when they are complete.
Old August 14th, 2014, 14:52   #10
mrrhtuner
mrrhtuner's Avatar
Very cool.
Keep this thread updated, builds like this are always great to follow
mrrhtuner is offline   Reply With Quote
Old August 16th, 2014, 18:57   #11
midntdi
Thanks. I plan to keep updates coming. I have a few more things planned for the engine but after that I am moving on to some other things that I want to update.
Old August 19th, 2014, 23:10   #12
midntdi
Okay, not the best update but here goes.
Yesterday, I was prepping the car for restart. While I was attaching the banjo bolt for the turbo inlet line I heard a snap and the threaded portion on the oil filter housing had cracked off. I am sure this is somewhat related to about 5 years ago when I had a leak from the turbo feed line and had to over tighten the bolt to stop it long enough to get it to a shop for repair. New filter housing and install kit is on its way. On to the carnage:
On the bright side it gave me a chance to install this nice little upgrade.
Old August 27th, 2014, 19:49   #13
midntdi
Ok another update. I had some cluster work done to make my cluster all nice, nice.
- Modified Cluster housing to incorporate the circular Fuel and Temp gauge rings from the B5.5
- Replaced MFA screen with new VDO unit
- Installed Outside Temperature Sensor
- Clock and Odometer screens inverted and replaced LEDs with red to match MFA
- Lit Needles and Displays (Displays necessary to see clock and ODO)
-Linear Temp Gage mod
-Cruise Light Mod
Old August 27th, 2014, 20:22   #14
midntdi
While the cluster was out I wired in a boost and EGT gage from VEI systems.
I have not had everything hooked up to test it yet since I am still waiting on my Turbo. That should be here on Friday so I will have some updating to do then.
Old August 27th, 2014, 20:26   #15
midntdi
Lastly, I took advantage of the fact that my steering wheel was faded and replaced it with a new three spoke steering wheel.
It is a steering wheel off the Sirocco R that I had gotten off of the R32 forums on Vortex.
Build thread audiphile VW MKIV-A4 TDIs (VE and PD) 0 February 17th, 2012 10:38
the slippery slide of power has started! UsArmyTDI TDI Power Enhancements 3 June 17th, 2011 17:44
My build thread robbinsresort VW MKV-A5 Golf/Jettas 13 April 14th, 2009 07:50
new build thread numbnuts TDI Power Enhancements 2 March 7th, 2009 10:25
MAF Screens, Or, The Slippery Slope Karl Roenick TDI Power Enhancements 20 May 6th, 2000 01:15
Page generated in 0.15815 seconds with 10 queries
[Output: 126.97 Kb. compressed to 105.76 Kb. by saving 21.21 Kb. (16.70%)]
