I just ordered a TacoTaco intercooler yesterday and this is the thread in which I will document its install and do some data logging to see if its truly better than the OEM intercooler.
For those that don't know, the TacoTaco intercooler is an intercooler sold by eBay user ILoveTacoTaco for the 1.8T models, but its supposed to fit our ALH TDIs too. The TacoTaco intercooler is less than $135 shipped in the U.S. at the time of this writing, so if it is in fact better than stock, its a great budget option, but that's a big IF. Here is the eBay link, live and working as of 6/30/2014 http://www.ebay.com/itm/1999-2004-V...r_Truck_Parts_Accessories&hash=item484b4b10e1
From what I've read, the TacoTaco comes with a small MAP sensor hole. It works fine with 3bar MAP sensors, but if you want to run your stock, larger 2.5bar MAP sensor, you will have to drill out the hole. Since I am going to be wanting to run both 2.5bar and 3bar MAP sensors in my TacoTaco, I am going to have to devise a way of getting a 3bar to seal in the larger 2.5bar hole. so that should be fun. EDIT: JFettig has given this info below 038 906 051B is the small hole 2.5bar MAP. Its used on some 2003 and all 2004-2006 TDI's except for the 2004-2005 Passat TDI which uses a 3bar MAP.
helpful links and info
A great thread from tdiclub user Dorkage who found a 10C (18F) decrease in IATs and a noticeable amount of extra torque: http://forums.tdiclub.com/showthread.php?t=357177
