CoolAirVw
Brian and I were extremely disappointed that Tdifest was cancelled as we have never been and St Louis would have been so convenient, so we decided that since we should have a Get-together at CoolAirVw (kansascitytdi) near labor day. I decided against labor day weekend as folks will probably be spending their time with the family or going to the lake or whatever.
So, were having a "working" Get together on Sept 6th, the weekend AFTER labor day weekend.
Date: 9-6-14
Time: 8am - ????? four or five pm???
Address: 604 N Scott, Belton MO 64012
Event is for "Do it yourself work on your cars", socializing. 3 Lifts, jacks, vagcom and special tools available. Please bring your own hand tools. Please keep it "mostly minor". Please don't start a major job like clutch replacement or timing belt unless your 100% confidant you can finish in allotted time. Brian and I will be glad to help with advice and to lend a hand.
please don't expect us to do major stuff like Timing belt or Clutch or any work work for you, this is for you to do the work, but we can definitely help with the special tools or and knowledge.
If your around at lunch time we can send someone down to the BBQ joint for some tasty BBQ (best ribs in the world!) , or just order in and chow on a pizza.
Please bring Tdi loving friends or other folks who we can expose to the love of Tdi's and get them to join the family.
If your wanting to bring stuff.... cups, ice, or pop? Cheese dip?
To see the pics of some other Get-togethers we've had click the links below.
http://forums.tdiclub.com/showthread.php?t=394242&highlight=kansas
http://forums.tdiclub.com/showthread.php?t=349379&highlight=kansas
http://forums.tdiclub.com/showthread.php?t=304474&highlight=kansas&page=2
Great time to:
1. change that oil
2. Look at that annoying oil/antifreeze leak.
3. change that transmission filter
4. grease up them squeeky sway bar bushings.
5. fix that annoying armrest
6. change that cabin air filter that you didn't know existed.
7. See why that check engine, ABS light or Airbag light is on.
8. Inspect your Cam.
9. Install a skid plate
Date: 9-6-14
PHP:
Great time to:
1. change that oil
