Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old May 9th, 2014, 21:38   #1
Scoutx
Default MK6 Quest for 900+ mile tank
Ok, time to start documenting this so folks can follow along.
Filled up the other day, and did some donuts and slaloms to slosh fuel in tank and work air to filler. Topped off and repeated until I could get no more air out. Addition of about 1.2 gallons to already full tank resulting in 'superfull' tank.
(note: I will try to add the pictures later today)
Please excuse the picture quality, some of these are not the best.
Near end of run this afternoon I was:
122.0 miles on the clock
Computer showed 810 miles left in tank
At the end of the run I was 127.x on the clock
Computer showed 820 miles left in the tank
(no clear picture - took one but it smeared and I didn't notice until I looked just now)
Analysis: I am about 47 miles above that necessary for 900 mile tank. I don't think fuel level is down to sending unit yet. See 'superfull above'.
2012 - No mods. First Mk6 in 800 mile club & 1000 mile club (Totaled and retired)
2015 - No Mods.
Scoutx is offline   Reply With Quote
Old May 9th, 2014, 21:40   #2
Scoutx
Evening trip.
195.4 on the clock
Computer shows 785 to go.
Analysis: I should be about 75-80 miles over that needed for 900 mile tank
I'm not sure if I'm down to the sending unit yet, but should be so above may be 'accurate' as far as the computer is concerned, but based on past experience, you drop quicker towards the end of a tank so subtract 20-30 miles for end of tank drop off.
Now if I can just hold it together for a bit over 700 miles more..... wish me luck.
2015 - No Mods.
Old May 10th, 2014, 04:42   #3
SirSipsAbit
SirSipsAbit's Avatar
Originally Posted by Scoutx View Post
Evening trip.
195.4 on the clock
<insert picture #2 here>
I concur a loss of 20 or so miles at the end. I did make it 103 miles with the low fuel light on.
Good luck
SirSipsAbit is offline   Reply With Quote
Old May 11th, 2014, 01:06   #4
PressEnter[]
PressEnter[]'s Avatar
Good luck!
Best Tank - 812.5 miles, 56.17 mpg
PressEnter[] is offline   Reply With Quote
Old May 11th, 2014, 03:20   #5
Tuco
TDI(s): 2010 Jetta
Honestly, I'll be impressed if you crack 800 at that elevation.
Tuco is offline   Reply With Quote
Old May 11th, 2014, 19:46   #6
Scoutx
I've already done 800 mile tanks....twice.....once to show it could be done in a Mk6 and later when I was running late but still had the range..but proves it can be repeated.
2015 - No Mods.
Old May 11th, 2014, 19:50   #7
Scoutx
Update: Had to pick up my in-law today.
Trip there, I topped out at 1010 (note did have 1015 indicated for awhile, and one brief spike to 1020) mile range combined between actual and remaining range provided by the computer.
Trip back however, didn't allow me to maintain much hypermiling so I lost a good part of my cushion, but 900 is still probable so continuing the run.
Note: Lost two blips on fuel gauge, one just before end of trip so should have about 3/4 of tank left
357.7 on the clock
600 remaining range indicated.
PS having a pain trying to get Verizon's online album to work so I can transfer pictures from my phone, but still working on it. Plan to call customer support tomorrow to get the issue resolved. Last time I get a phone that doesn't allow direct download to my PC via USB or memory card.
2015 - No Mods.
Old May 12th, 2014, 18:56   #8
Bill W
Sign up for Dropbox. A basic cloud service that's free and enables picture uploads between multiple devices.
In any case, I'm excited to see if you can get to 900!
Bill W is offline   Reply With Quote
Old May 12th, 2014, 19:07   #9
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
I subscribed to this thread and been trying to get the best mileage I can with this car, 2013 jetta tdi
So far...110kph,19deg C cruise on
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old May 12th, 2014, 22:03   #10
Scoutx
Yes! Yes! Yes!
Perfect run...regained much of my cushion & established a personal best for MPG.
Take that you Mk4 guys with your 60mpg and bathtub sized fuel tanks...
Anyway, end of morning run.
420.9 miles on the clock
675 range indicated.
2015 - No Mods.
Old May 12th, 2014, 22:06   #11
Scoutx
Evening Run.
479.6 on the clock
Range at 520 miles
Note: Dropped to 5/8ths at 475 miles.
2015 - No Mods.
Old May 12th, 2014, 22:14   #12
Scoutx
Let me take a moment here to comment...that doing this sort of hypermiling is a PITA and it might all come to naught if conditions fall apart. T'storms today and tomorrow...Rain on Fri.... Rain may well spell the end of this, or at the very least kill any slight chance that may exist for a 1,000 mile tank, assuming the computer is at all accurate.
Pray for me.
2015 - No Mods.
Old May 12th, 2014, 22:23   #13
Scoutx
You've got a chance to run an 800 mile tank there. A lot depends if you can improve a bit on your economy over the next 1000km. Otherwise you may come up short and/or have to drive really deep into the tank beyond zero miles remaining.
2015 - No Mods.
Old May 12th, 2014, 23:06   #14
JASONP
JASONP's Avatar
Just out of curiosity how many miles are on your jetta?
I'm currently at 33,000 kms or 20,500 miles , I'm afraid to push it past the fuel up now light .
I used to have a 2010 GSW (3271lbs) and acheived this once, I suspect the jetta (3210 lbs) will yield about the same or better mileage in another 30-40 k
That's 72.1mpg below
Old May 13th, 2014, 01:22   #15
apples12
i only just cracked a 600 mile tank on my 2.0tdi golf! (I should add that was with 52l of diesel until the light first flashed on)
currently at 114,000 miles and doing a lot of motorway mileage, what kind of speeds are you doing to get that 900 tank? i'd be more than happy to get 650/700!
the 600 tank was probably 480/500 motorway miles sitting at 70-75mph with maybe a bit faster at moments.
apples12 is offline   Reply With Quote
60 MPG / 900 Mile Club / 1000 Mile Club aggiegrad TDI Fuel Economy 646 March 9th, 2019 20:37
900 mile tank my old tdi romankunakhovich TDI Fuel Economy 8 January 9th, 2014 09:35
900 mile per tank club. psd1 VW Passat Family (NMS and B7) TDIs (2012+) 130 October 1st, 2013 18:24
900 mile club Lightflyer1 VW MKV-A5 Golf/Jettas 20 April 29th, 2011 13:32
Page generated in 0.17519 seconds with 10 queries
[Output: 128.48 Kb. compressed to 106.52 Kb. by saving 21.96 Kb. (17.09%)]
