Other items to consider: (just to add to the confusion...)
If you trust the quality of concrete in your garage (I'm not that trusting), there's also the MaxJack - Princess Auto, I believe, used to carry it for not that much more than some of your choices... http://www.dannmar.com/dannmar-products/two-post-lifts/maxjax.asp
Then there's also a portable unit: http://www.bendpak.com/Shop-Equipment/QuickJack/BL-3500.aspx
And if you really want to go all out, you can see how much a "real" lift would cost - I think you'll be surprised at how more-or-less affordable some of them are... http://www.liftsuperstore.com/
(Or Princess Auto "real" lift: http://www.princessauto.com/pal/en/Vehicle-Lifts/2-Post-Vehicle-Lift/8316283.p )
Yuri
$1600 includes delivery in Canada:like the bendpak portable units.
Great deal!!! (If only one could have that much confidence in the integrity of their poured concrete garage floor...)The Max Jack is available at Costco for $100 cheaper than PA and includes delivery:
http://www.costco.ca/Dannmar-MaxJax™-2-post-Portable-Auto-Lift.product.10344259.html
You could support it by installing a 1/2" steel plate under the posts. Say 2' x 2'. Bolt the posts to the plates, then the plates to the floor. It would add a significant amount of stability and reduce the strain on the concrete.Great deal!!! (If only one could have that much confidence in the integrity of their poured concrete garage floor...)
Yuri
Depends... are you related to the mayor?you think the township would mind if i also put anchor holes in the sidewalk that spits my driveway outside for the nice summer days to use out side.
What's the point of a lift if you can't get unimpeded access to the underside of the car?
Only one worth buying of the ones listed here is the Danmar Maxjax unit.
Yeah. You can get 4 really nice floor jacks for much less than the Bendpak portable and will work just as well.
If your going to lift it, Lift it.
We all have our crosses to bear. I wish I had a 2 car garage. I only have a one car garage. I seriously considered buying a lift like these (it was on CL used for under $800), but I did not want to have to drive up over the "hump" every time I pull into the garage.I wish i had a single double-garage door instead of two single-garage doors
Well if you have to go with any of them, I'd go with the scissors lift.what do you guys think of these
Most if not all of them are from China. And most do not carry a lift certification (mine does not). A minimum for a real lift in my opinion is something like an asymmetric Mohawk A-7, but you are looking at about $5000 in the US (I called them...ouch).And if you really want to go all out, you can see how much a "real" lift would cost - I think you'll be surprised at how more-or-less affordable some of them are...
Unless you are short, you can't stand under any of these consumer lifts. My other friend has a full sized 2-post consumer lift and at 6' 1", I cannot stand upright under the car.Plus your still going to have to lay on your back to get the work done, instead of standing up.
Many owners of those lifts place 1/8" thick aluminum plates under the area that the rollers travel on, to prevent wear.A couple of those have rollers so as you are lifting the car, they roll across the floor. Will your floor handle that?
Which is why I went all out with my installation.If only one could have that much confidence in the integrity of their poured concrete garage floor.
what was your cost for the install?Which is why I went all out with my installation.
All pricing with tax from my MS Excel spreadsheet...what was your cost for the install?
custom plate footing?
concrete work?
etc
I have a standard-sized two-car garage.Your Max Jax a permanent installation? Or do you wheel it around in/out when needed?
