Old December 30th, 2015, 22:02   #46
psulik1
psulik1's Avatar
I know there was some debate about the FOAM v. tape, I used the HVAC tape and it worked fine, HEAT HEAT HEAT. Maybe with the FOAM you get a better seal but **** man for the work I did ( pain in the ass but not bad ) and the tape I used the heat was more than enough. Works just fine, Chicago winters.....
psulik1 is offline   Reply With Quote
Old February 20th, 2016, 19:21   #47
JETaah
Fuel Economy: 53 max, 42 min, average 46
The longevity of this fix is more about the adhesive than the blocking material....how well it can hang on to the materials in the temperature extremes. If you could apply the blocking material from the opposite side of the door it would be more secure. It would be pushed against the door with the air flow.
I did it anyway using the aluminum backed 1/8 foam pipe wrap tape. We shall see.
What is the longest that this has worked for anyone so far?
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old February 21st, 2016, 16:48   #48
tdidieselbobny
tdidieselbobny's Avatar
Did the blend doors on my son's '01 Jetta today. Not too bad,found a sh*tload of broken plastic pieces when taking everything apart-a few I caused,the rest was done before our ownership. I ended up breaking the big tab on bottom of blend door cover. I was able to do it without unplugging the radio,except for antenna connection. Both blend doors were PERFECTLY clean. I used HVAC foil tape to cover both doors. The 2 screws on the blend door cover are 6mm hex,but I had a long enough screwdriver to get them that way.I used one of those grabber thingys to get the screw back in hole,but the plastic ear on the right side of cover ended up breaking...to solve the broken tab on bottom,I drilled a hole through cover and box,then used a ziptie to fasten it-worked pretty good. I took car down road and started to get heat in about 1-1/2 miles,way better than the zero heat before I did the doors. Son is REALLY happy now..... the PO took the car to a garage last March w/ no heat complaint-they changed the t-stat and coolant, so I don't know if he realized it still had no heat or not-we bought the car in June, the A/C worked good,but the heat sucked in the fall,but no foam was coming out of vents.
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 24k miles....'16 Kubota BX1870 MMM/FEL, 100hrs!And now an '03 Jetta TDI 5spd w/ 423k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old May 6th, 2016, 18:36   #49
Golf3D
When I got my 2000 Golf several years ago I replaced the A/C compressor and several related components hoping it would keep the cabin cold in the hot Florida weather. Yet with perfect high and low side pressures, tinted windows and a silly beige dash cover it never got better than marginally cool. And even with mild winters here, the heat was useless.
After reading this and many other threads about the vent door foam I finally took the plunge this week and had Scott Krout in Jacksonville perform the repair. He disassembled the dash, removed the remaining foam, cleaned everything out and recovered the doors with specialized tape for A/C systems. Now I have REALLY COLD air coming out of the correct vents using the rotary control and the heat works too! With another brutal Florida summer coming up I'm happy I spent the money and this is fixed now.
So if you have weak A/C from random vents, no heat and bits of foam blowing on you, it seems you can NEVER achieve proper cooling and heating unless you or a guru does this repair!
Golf3D is offline   Reply With Quote
Old May 9th, 2016, 09:25   #50
Lightflyer1
Lightflyer1's Avatar
Yep. I need to do this on my Beetle soon.
2015 Beetle TDI.
Old May 31st, 2016, 12:28   #51
Chunlicious
TDI(s): 2003 Jetta
Is there a picture or video of the "quick method" of accessing this area?
Chunlicious is offline   Reply With Quote
Old June 11th, 2016, 09:40   #52
Chunlicious
TDI(s): 2003 Jetta
So, I was able to do this repaid on a 2003 MK4 Jetta 1.8T. Here is a video that should help if someone is still a bit confused. I could not find one like this. Took my under 4 hours + trip to Home Depot.
https://youtu.be/bxPMzzLmEuM
Old June 12th, 2016, 20:17   #53
Perfectreign
That's the best video link I've seen. Perfect!!
Kai Ponte - www.perfectreign.com
2006 Chevy Avalanche WBH LS
2016 Chevy Malibu Hybrid
Perfectreign is offline   Reply With Quote
Old June 29th, 2016, 22:33   #54
Aquaticmind
Aquaticmind's Avatar
Location: Wheeling, WV via Athens Georgia via, Bainbridge Is. Wa, via Carbondale IL, via Asheville NC
Fuel Economy: good
Hi folks,
I was driving to the beach today and suddenly my vent started blowing hot air instead of cool air with no change when I moved the hot/cold air dial (the AC was off, but it had been working earlier). I haven't seen or had any issues with the vents blowing foam, but I need to find a way to stop the hot air so I can use my AC and not roast. The black interior and a hot Georgia summer demands AC.
Does it sound to you folks like I have an issues with the foam on the blend door or is it possible that the cable that controls the hot / cold mix for the air has just become disconnect. If it's the later, is there fix?
~James
2003 Wagen, 2" lift, auto front springs, panzer plate, pp520 injectors, RCII+, ASR
Aquaticmind is offline   Reply With Quote
Old June 30th, 2016, 05:35   #55
JETaah
Are the radiator fans turning when the A/C is switched ON?
Is the center of the compressor pulley turning?
Could be unrelated to the blend door if it happened all of a sudden.
Old June 30th, 2016, 06:24   #56
Aquaticmind
Fuel Economy: good
I haven't checked the radiator fan yet, but I replaced my fans last summer. What was really striking was that it didn't make a difference at all where I had the air temp setting, and it was a cool night so without the AC evening being on, I should have been able to cool night air through the vents.
Old September 4th, 2016, 11:38   #57
Perfectreign
So, I decided enough was enough and took the plunge yesterday. Fall is the hottest time of the year for us in LA, so I've been driving my Avalanche since the Jetta has no cooling ability.
I almost took the plunge on a Passat lease yesterday. Even cheaper than the 2015 lease my beautiful young bride has at $98/month.
However, I thought let's get it done. The tutorial was fantastic. One thing I wanted to comment on, though. Need to have small hands. The space in there is very tight.
Using some aluminum tape and blindly trying to stick my hand through the tiny door, I was able to cover two of the doors. I know there's supposed to be three, but couldn't find the third.
...with the door going to the floor.
IMG]http://gdurl.com/MHAf[/IMG]
One thing I noticed was the the prior owner had a dentist appointment in September 9, 2002. I hope it went well. I found this card from a dentist in Deepinharta Texas with an appointment date of 2002. It was wedged in behind the air controls and up against the plastic panel which gains access to the blend door. The appointment was for a Gaylen (or Gaylan).
So, thank you to the OP and the rest for the great instructions. I now have cold air and will have heat if it ever gets cold.
Old September 30th, 2016, 07:56   #58
PaCrazyLady
TDI(s): 1999.5 Jetta
I'll be attempting this fix tomorrow on my 99.5 Jetta. While I'm not a mechanic, I hope my perserverance pays off in what could be a costly repair if shop does it. My question is, after reading some posts and other articles and watching YouTube, there was some indication that the cover over the blend door can pop off?? Am I understanding that correctly?
Also, is this a multi day job or can I tackle it in 6-8 hours?
I've only had the car a couple weeks and have no service history on it, so I'm trying to show it some TLC in hopes that it'll last me another 60-100k miles.
PaCrazyLady
PaCrazyLady is offline   Reply With Quote
Old September 30th, 2016, 08:49   #59
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by PaCrazyLady View Post
I'll be attempting this fix tomorrow on my 99.5 Jetta. While I'm not a mechanic, .......................................
PaCrazyLady
That might be good, mechanics hate this job (a close second to electrical issues).
I've maintained and repaired my own vehicles for 40 years, also Not A Mechanic. I would give myself 2 or 3 days for working out and resolving various roadblocks you will encounter. The 3rd time you pull the HVAC unit it will take 3.5-5 hours. The first time will be closer to 10.
Your best weapons are patience and resourcefulness. Don't forget to pull the negative battery cable before starting.
Old September 30th, 2016, 12:58   #60
Perfectreign
I did mine in about four. The blend door cover literally pops off with tabs. You just need to have a firm grip and pull, realizing there's about eight tabs holding the door in
Looking for write up or DIY on how to repair the AC blend door on my 2003 Jetta TDI. ericgray1 VW MKIV-A4 TDIs (VE and PD) 0 July 14th, 2013 17:47
heat issue after blend door repair Woodworker VW MKIII-A3/B4 TDIs 3 March 10th, 2013 16:17
No Cabin Airflow Except Defrost! Blend Door? VTJoe79 VW MKV-A5 Golf/Jettas 0 December 26th, 2012 09:27
09 Jetta Cabin temp doesn't change - blend door issue? sweetie82om VW MKV-A5 Golf/Jettas 13 September 19th, 2012 06:26
Blend Door Foam - '96 Passat B4V No Heat diesel300dmanual TDI 101 19 December 8th, 2008 04:55
Page generated in 0.16040 seconds with 10 queries
[Output: 134.35 Kb. compressed to 112.89 Kb. by saving 21.46 Kb. (15.97%)]
