Old March 4th, 2015, 19:30   #16
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Originally Posted by psulik1 View Post
Hi, I just did this and wanted to offer my notes for anyone that may take a stab at this.
First it took me start to finish about 4 hours, I am not a mechanic but I know my way around a bit.
After all the controls/radio etc. were removed I got to the box. I didn't remove any screws or nuts like people mentioned, I just started prying and working the tabs and just worked my way from the sides/bottom and up. Took some careful prying but I got it. I didn't remove the back half, that's what the screws/nuts hold but I didn't see it necessary. I then cleaned the doors and applied the aluminum tape that was mentioned. It was mostly blind application because most of the doors are out of sight but I put a lot on trying to work my way from the top to the bottom, lots of overlap, I figured a little more may go a long way.
Snapped and assembled all back together and sure enough heat!
Not that I am an expert but if anyone ever has any questions feel free to contact me via PM and I would be more than happy to answer questions via phone or email.
I am familiar with the HVAC aluminum tape. So you didn't use any foam after you used the tape on the door panels?
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is online now   Reply With Quote
Old April 6th, 2015, 11:16   #17
Jesse_Boyer
All: I've done this on 4 cars by pulling the dash and one via the shortcut method. Only one car had the HVAC box removed entirely, the other 4 done in-car. All using using high-heat aluminum tape with decent success, no replacement foam. (granted, I likely never had a car with fully intact foam and cannot tell you how it should feel.) Anyway, on the 'shortcut car' I had less heat than desired, A/C wasn't as cold as desired. I wanted to make sure the air-flow was sealing properly between the doors and case for temperature control and directional purposes; I re-did the 'shortcut car' on Saturday. This car hadn't been directing airflow well and I wanted to investigate. While this can be done via shortcut method, I'll tell you where I went wrong when I did it. Learn from my mistakes.
First big error:
I failed to get the center vent blow-molded plastic snapped properly to the HVAC box on the top. This has to hook at the bottom of the HVAC box, slide into the plastic directional elbow which feeds the vents, and snap to the tab on the top of the HVAC box. The 'tab' which retains it folded over on itself and held the two sealing surfaces apart. Not only did this slightly warp the plastic piece, but it obviously didn't seal against the box, causing a great deal of airflow to leak into the dash and not be directed to the vents. Note this when you're re-installing. That tab needs to lock onto the heater box (all while fitting inside the components above to direct airflow to the vents.)
Now, the tape-vs-foam debate. The aluminum tape will certainly block the holes in the doors, but it won't seal around the perimeter. This is why I like the foam method better. You're able to seal VERY well between the case and doors when they're closed. Its still tight, but you can put the foam over the 'edge' of the door with the door partially opened and use your fingers to 'bend' it around to the other side. The top and bottom of the doors, use your best judgement to add a little extra foam beyond the door (1/8"-1/4" above.) This creates a foam edge that seals against the plastic HVAC box, sealing very nicely. (don't over do it or the door won't seal on the other surface, creating a gap.) One later of 1/8" foam did the trick nicely. In my opinion, the car has an insane amount of airflow compared to my wife's ALH which I fixed with just aluminum tape, no foam. Fan setting one with all the air-flow out the vents is almost excessive.
Personally, I'd rather pull the dash to have a little better access for blend door foam application, have access to replace the foam between the dash and defrost vents, the dash and center vents, seal a little better between the ductwork for the rear vents, etc.
This is the foam I used for the door foam:
http://www.menards.com/main/plumbing...837-c-8589.htm
For the ductwork connections, I used a closed cell 1/2"x1/2" meant for sealing around doors, windows. Similar to this stuff, but I thought it was 1/2" x 1/2":
http://www.menards.com/main/doors-wi...344-c-3624.htm
'03 Nemo Blue S6, AirLift, Garage queen/spare.
'02 Black S6, 01e swap, muffler delete, permanent smile maker.
'00 A6 2.7t 6sp. Message me for parts requests
'01 allroad 6sp, parts car. Message me for parts requests
Jesse_Boyer is offline   Reply With Quote
Old April 7th, 2015, 08:58   #18
DanVito
Tongsli: What are the specifics on the foam you ordered, i.e. thickness, density, sheet size?
DanVito is offline   Reply With Quote
Old April 8th, 2015, 15:03   #19
tongsli
Originally Posted by tongsli View Post
http://www.mcmaster.com/#catalog/120/3574/=twr0ip
I ordered this foam from McMastercarr adhesive backed, 1/8 thick extra firm foam
Extreme-Temperature Textured Silicone Foam, Adhesive-Backed, 1/8" Thick, 12" x 12"
Extreme-Temperature Textured Silicone Foam, Adhesive-Backed, 1/8" Thick, 12" x 12" EXTRA FIRM
http://www.mcmaster.com/#catalog/121/3592/=wo0wzi
8608K522
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old April 8th, 2015, 19:55   #20
79TA7.6
79TA7.6's Avatar
Location: Live: Wilbur/Creston; Work: Moses Lake Washington
So is the one 12 x 12 sheet enough to do both doors? Not really sure what the door sizes are.
2003 Jetta 5 Speed 301K miles. Malone stage 3. Titan 502 big hole injectors. VNT17 turbo. BuzzKen 2.5" down pipe. Ventectomy, EGR and cooler delete, Euro Switch, Home made custom HID.
79TA7.6 is offline   Reply With Quote
Old April 8th, 2015, 22:10   #21
tongsli
I don't know. Haven't installed it yet. Doh!
Old April 9th, 2015, 09:19   #22
Jesse_Boyer
I know the 2" wide stuff I used wasn't easy to get in the right place, so I imagine a piece the exact size of the door might be a bigger task.
While it might be large enough to do one side of both doors, I would certainly have more on hand. When you stick it to the door, aren't happy with the position, pull the piece off, you're not going to be sure about the condition of the adhesive. I know I threw away about twice as much insulation as I actually stuck to the doors. Stick it to the door, not happy, pull it off, throw it away. I'm not taking it apart again and don't want to question the adhesive.
Also, for the price of the stuff listed from McMaster, you can buy the roll from Menards for far less. Additionally, the roll is 720 sq-in vs 144 sq-in. You can screw up a LOT and still have plenty left-over to fix all the rattling panels
Old April 15th, 2015, 21:27   #23
lapse
Fuel Economy: 49/43/38
What exactly is the shortcut method?
lapse is offline   Reply With Quote
Old April 16th, 2015, 05:13   #24
Jesse_Boyer
Leaving the dash in place as this thread describes.
Old April 16th, 2015, 09:15   #25
lapse
I was hoping for some quicker
Old April 16th, 2015, 09:38   #26
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
This is the quicker, see Post#1.
Old April 16th, 2015, 21:51   #27
Jesse_Boyer
Yeup, pulling the dash will take an extra 90-120 (estimated) by the time you pull the wheel, steering column mounts, etc. You'll have better access to the doors this way, but its still not entertaining. If you'd like to spend WAY more time, you'd pull the HVAC box itself, split, and do the work on the bench.
Old May 10th, 2015, 16:53   #28
WAKeele
Fuel Economy: Good enough to never go back to gas!
Question
So I take it my current Jetta is well past the point of blowing foam -- my last one I got a little bit of it in the early stages of third-hand ownership -- so while I'd welcome better temps on both ends, my problem looks to lie in an inoperative blend door.
One morning about two weeks ago now, as the car warmed up to normal operating temp, so did the air coming out of my vents (as usual). I turned the temp control all the way to cold (even though the fan was never on to start with). This did absolutely nothing. Even turned on the AC, but still really hot air. Figured it was the thermostat stuck closed. Replaced it with a new one since they are pretty darn cheap. Didn't help a lick. So I'm guessing the it's the blend door? Anybody with experience with this situation? Would this potentially be enough to solve the problem, or would there be more I may need: http://www.amazon.com/Valeo-509573-A...dp/B001D23ZMY/ I can't have my car down for more than the weekend, so I'll need everything on hand when I decide to tare into things.
And of course I'm going to try this fix while I'm in there.
WAK
2002 Jetta TDI--318,XXX miles--manual (Sachs G60/VR6 clutch & flywheel)--Dieselgeek Panzer Skidplate, Ventectomy, FrostHeater, Bilstein TC Sport struts, Bosio Sprint 520 injector nozzles, Unitronic Stage 1+ Performance Software
WAKeele is offline   Reply With Quote
Old May 11th, 2015, 06:45   #29
Jesse_Boyer
WAK,
Before you assume its the solely foam related, make sure your temperature lever arm is properly rotating the doors. These fail from time to time and it causes the temps to behave like you're experiencing.
Watch this:
https://www.youtube.com/watch?v=6U9ZdkAjdhQ
Does yours behave similarly? If its spreading apart like the video shows, its likely not turning the doors like it should. If so, report back and I'll give you a little shortcut on fixing this...
Old May 19th, 2015, 08:30   #30
supton
supton's Avatar
Fuel Economy: 53/46/33
I concur, the arm that moves the blend door likes to fall off on mine. I removed the console to make it easier to snap back in (but it's still a real pain). Do not be fooled by the temperature knob: when the arm falls down, the knob feels exactly the same. The same amount drag etc.
IIRC you can acess the arm by removing a small kickpanel on the driver side footwell, and you can stick your hand up there to find it--it helps to feel around while rotating the temp knob. The Bentley is kinda helpful here also, in letting you know where it is and how to get to it.
'04 Jetta Wagen 5spd GLS, 314kmiles, Koni Red's, SBC stage 2 clutch, VNT17, RC2 sold
'11 Camry base 6spd manual, 95k, wife's
'10 Tundra double cab, 4.6L, 95k, mine
supton is offline   Reply With Quote
Looking for write up or DIY on how to repair the AC blend door on my 2003 Jetta TDI. ericgray1 VW MKIV-A4 TDIs (VE and PD) 0 July 14th, 2013 18:47
heat issue after blend door repair Woodworker VW MKIII-A3/B4 TDIs 3 March 10th, 2013 17:17
No Cabin Airflow Except Defrost! Blend Door? VTJoe79 VW MKV-A5 Golf/Jettas 0 December 26th, 2012 10:27
09 Jetta Cabin temp doesn't change - blend door issue? sweetie82om VW MKV-A5 Golf/Jettas 13 September 19th, 2012 07:26
Blend Door Foam - '96 Passat B4V No Heat diesel300dmanual TDI 101 19 December 8th, 2008 05:55
Page generated in 0.18044 seconds with 10 queries
[Output: 137.49 Kb. compressed to 116.07 Kb. by saving 21.42 Kb. (15.58%)]
