Old April 18th, 2014, 06:35   #1
LynnPlaggs
Fuel Economy: 46 city 52 hwy
Default Help with instrument cluster
Had someone back into front of car (no damage) and now instruments (tach,speedo, fuel and water temp gauge)don't work.
All warning lights still functioning along with odometer.
Vag Com lists Open + - checked fuses and they are OK- Any idea where to look next
LP
LynnPlaggs is offline   Reply With Quote
Old April 18th, 2014, 06:37   #2
South Coast Guy
Fuel Economy: Good
Sounds like there was damage; you may not have found it yet.
South Coast Guy is offline   Reply With Quote
Old April 18th, 2014, 06:57   #3
ta79pr
ta79pr's Avatar
TDI(s): 02 TTQ (BEW)
Fuel Economy: avg. 43
Perhaps the outside temp sensor, assuming you have one, got crushed and the wires shorted and those other sensors share the same reference signal.
ta79pr is offline   Reply With Quote
Old March 1st, 2018, 13:21   #4
Robert6401
Robert6401's Avatar
LP
Did you ever find out what the issue was?
Bob
1986 MkII Jetta 1.6NA, stock
2006 MkV Jetta 1.9TDI, stockish, with Dan's magic touch
Robert6401 is offline   Reply With Quote
Old March 3rd, 2018, 16:28   #5
AndyBees
AndyBees's Avatar
LP
Which one of your vehicles are you talking about?
You are probably right.
The 2002 Jetta/Golf have a common splice (number 269 in the schematics) that numerous sensors ground through then on to the Cluster. Installing the 02 ALH engine and Cluster in my Vanagon, was when I made the discovery and use of splice 269.
So, OP, you probably need to look further as there appears to be little doubt that damage occurred.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old March 3rd, 2018, 17:45   #6
jettawreck
jettawreck's Avatar
Thread was started almost 4 years ago, but good schematic work Andy.
2004 Cadillac SLS (wife's)
Old March 3rd, 2018, 20:26   #7
AndyBees
AndyBees's Avatar
Dang! .........LOL
Well, maybe Robert will benefit!
Old March 5th, 2018, 02:46   #8
JB05
Fuel Economy: 43/41/40
Where exactly is this 269 splice? I've read about it before trying to diagnose my erratic fuel gauge. I know it's not the sender in the tank since that has been changed once already along with the in-tank pump.
JB05 is offline   Reply With Quote
Old March 5th, 2018, 05:48   #9
AndyBees
AndyBees's Avatar
Splice 269 is buried in the instrument panel wiring harness.
Based on my experience, I seriously doubt that the connection (269) is the problem. My point is that numerous sensors ground through that splice with one wire going to the Cluster at T32/7. The schematics seem to indicate that the wires all come together at one point. I cannot say that is the case for certainty.
-Windshield washer level
-Brake Fluid level
-Fuel tank level
-Coolant tank level
-Malfunction Indicator (for those equipped)
-maybe others..
Old March 5th, 2018, 09:41   #10
JB05
Thanks, Andy. I forgot to mention that I added a separate ground at the tank itself for the sender, but that did not work. Problem must be in the cluster. I've learned to live with it since the gauge has always acted up since I bought the car brand new in '04.
I changed the stepper motor in the cluster with a used one I picked up on e-bay, but that did not help.
Old June 15th, 2018, 06:00   #11
pugman
Fuel Economy: 47.5/37/35
This past week the clock stopped working with the Odometer/trip Odometer. Everything else still works. Could this be a ground as well and where would I find it? Car has over 362K miles on it.
'03 Silver Jetta Wagon GLS TDI Reflex Silver
'03 Silver Jetta GLS TDI Reflex Silver
pugman is offline   Reply With Quote
Need Some Instrument Cluster Help Mr_Deezy TDI 101 2 January 17th, 2012 14:33
Instrument cluster rgrenier TDI 101 3 December 14th, 2009 08:18
HELP -Instrument Cluster firefly.123 TDI 101 2 February 3rd, 2009 10:00
Looking for instrument cluster gpagra Private TDI Items for Sale/Wanted 0 October 7th, 2007 06:38
What is Instrument Cluster? Fatdaddys VW MKIV-A4 TDIs (VE and PD) 5 April 10th, 2006 19:59
Page generated in 0.16459 seconds with 10 queries
[Output: 104.27 Kb. compressed to 88.38 Kb. by saving 15.89 Kb. (15.24%)]
