Old October 15th, 2017, 17:49   #76
GoremanX
GoremanX's Avatar
I tend to agree with those findings. I have the 80psi and 50psi versions of these gauges. In general, I found that the 80psi one is jittery and unreliable, especially in the lower range. Its response using my MightyVac was extremely disappointing.
The 50psi version is much smoother and more reliable across the entire range. I haven't over-pressured mine yet so mine still works right However it's also MUCH louder than the 80psi gauge. The buzzing drives me nuts. I need to add some kind of buffer inline to reduce that buzzing noise.
Ideally I'd prefer to find a 2-needle electric gauge somewhere, but I don't think those exist.
GoremanX is offline   Reply With Quote
Old October 15th, 2017, 18:26   #77
[486]
TDI(s): 02 golf ALH
My gauges rattle pretty good if I don't run restrictors in the lines to them, so having sticky movement isn't as much a concern IMO, the pressure pluses of each cylinder should be continually knocking the gears loose in there.
The one that saw overpressure, looks like it's good and linear, I'd bet the pinion just skipped a couple rack teeth at the end of travel, should be able to gently pull it over the stop and click it over a couple teeth in the other direction, if you can't access the internals directly.
[486] is offline   Reply With Quote
Old October 15th, 2017, 21:27   #78
GOFAST
GOFAST's Avatar
TDI(s): vento afn
How did you conect the EMP line ?
Motor oil to ?
-----KEEP ON MODIFYING-----
GOFAST is offline   Reply With Quote
Old October 16th, 2017, 04:11   #79
Rub87
Ive found pretty much the same in my 50 psi one. the rattle is bad. I spend a few hours trying find an optimal restrictor for my emp line. in the end around 0.6mm was the best I could get between slow response and rattle but still at some rpm it rattles pretty badly
also the green needle is pretty much behind at low pressures. luckily I have a electric EMP sensor connected to the ecu so I can log boost and EMP precisely.
Imo the only boost gauge that you can trust and doesn't rattle is a genuine VDO 0-3 bar.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old January 2nd, 2018, 19:03   #80
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
So I've been running an EMP gauge of some sort or another for over 10 years and have had the water in the tubes freeze which will cause the EMP to not read until the interior of the car gets warm enough to melt the water. Sometimes this causes the EMP gauge to rise to 10-20 psi due to the expansion of the water when it freezes.
Got in my car this morning, gauge read 40 psi until it warmed up (80 psi gauge). Ok, no big deal. Get in the car after work and glance at the gauge and it looks like the boost gauge is reading a few psi high. Nope Exhaust needle is wrapped around all the way to the peg and now reads ~20 psi high once it thawed out.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old January 2nd, 2018, 21:55   #81
Mongler98
i never understood why anyone would use a gauge that needs to have the fuel, boost or anything come to the gauge. its a tell tale sign of cheep and bad design. Auber gauges are so far superior to anything on the market aside from a stand alone like a heltek dash unit or equivalent.
Old January 3rd, 2018, 06:05   #82
Fix_Until_Broke
An analog gauge is much easier to read compared to a series of seven segment displays which seem to be all that Auber offers.
Can you explain why a mechanical gauge is cheap and bad design?
Old January 3rd, 2018, 15:13   #83
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Why dont you guys use the stepper motor gauges? A little bit more expensive but work nicely.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old January 3rd, 2018, 17:26   #84
Mongler98
Auber is much more reliable and you can fit many gauge displays 2-3 of them in the space it takes for one average gauge of the round typical type. Auber multimeter gauges have a relay in them and can be programmed to do whatever you want in any application. No taking fluids or boost into the dash. All 12v systems with 5v sensors. All you can do with a standard cheap gauge is read temps or pressures or other various values like RPM and what not. With Auber you can have things like water/ meth, NOS, C3H8, defuel, and blow off valves, bleeders, timers, you name it all run off 1 or more gauge. For instance I have a water meth injection system I built that runs in 2 stages off 2 gauges, boost and EGT, I also ran a defuel on my MK3 tdi on the brake switch sensor and EGT relay. You can’t do jack with anything else. The displays are not hard to read what so ever, they also outlast any gauge I have ever had to date. Also the customer service is great with them too.
I feel that if you have to take the metered whatever to the gauge, it was built so cheap that they could not afford to put in a circuit to output 5v readout from a sensor.
I tried a few various brans for an air fuel gauge and they all crapped out. I talked with Auber about helping me make a multimeter read out work and we got it working great. They sent me some instructions on how to program it to output a value of 1-15 for the voltage and resistance given from a BOSCH O2 sensor. Cost me $40 and is working flawlessly unlike the cheap POS $150 to$200 gauges that innovate made and there supposed to be the best. NOT
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 20:35
Best dual egt/boost gauge setup chiro05 Upgrades (non TDI Engine related) 9 October 4th, 2013 08:22
Looking for a dual needle boost gauge, max. 40 PSI Mark@MaloneTuning TDI Power Enhancements 22 October 16th, 2012 05:55
Any suggestions for a good 0-50 Boost/ EGT dual gauge? tothemax TDI Power Enhancements 24 December 7th, 2010 13:40
WTB: Westach dual boost/EGT gauge thursday Private TDI Items for Sale/Wanted 1 December 16th, 2007 11:51
Page generated in 0.15635 seconds with 10 queries
[Output: 100.42 Kb. compressed to 87.04 Kb. by saving 13.38 Kb. (13.32%)]
