Old January 4th, 2015, 19:14   #61
kbrenny
I never got around to installing the Numatics PLS-B filter on mine yet.
I was about to install it today and decided to go another route:
2 1/8" barb to 1/4" NPT
2 1/4" Female NPT to 3/8" female NPT
1 3/8" nipple 2 1/2" long
1 tampon
The tampon was very hard to get completely stuffed into the 3/8" nipple but it was just the right length and diameter so that it was extremely tight.
Now, when I need to replace it, I can just pull the fitting off the end and shove a new tampon in there.
Much cheaper to build, easier to source, and much cheaper to service when needed.
I will let everyone know how it works as time goes by.
If I forget to post results of performance / longevity here in the next few months just shoot me a PM to remind me.
kbrenny is offline   Reply With Quote
Old January 5th, 2015, 23:01   #62
dremd
dremd's Avatar
I'm not very well versed on EMP levels, would a 30 psi gauge be adequate for a VNT 17 car? Or would I have to run the fity,(spelling intentional)? If prefer the 30 for the wider active sweep area, but if need be I can consider the larger gauge.
Tesla Model S P85
03 Silver Premium Jetta Wagon ALH + 6speed MT
2013 Nissan LEAF Totaled
2006 Sprinter
2014 JSW (Went back to VW)
dremd is offline   Reply With Quote
Old January 5th, 2015, 23:27   #63
kbrenny
The 50 psi would be the better choice.
Upon spool up your EMP can be around 1.5 to 2 times your boost levels.
If you were running 22 psi boost you would see an EMP reading of around 33 to 44 psi.
My EMP does not reach the higher end of the 2x the boost, but only because I adjusted the VNT stop screw that way.
I am running 26 psi boost and I get 45 psi EMP very consistently on extremely hard accelerations, but only during spool up of the turbo.
When I spoke with Hewitt Industries while ordering mine they recommended the gauge never be pushed to, or past, it's highest listed value as it could damage the gauge or make it no longer accurate.
Old January 6th, 2015, 06:51   #64
dremd
dremd's Avatar
Much appreciated answer and explination (all of it).
I think I'll order one today.
Tesla Model S P85
2006 Sprinter
Old August 2nd, 2016, 17:01   #65
GoremanX
GoremanX's Avatar
Blast from the past! I'm adding my own contribution to this old thread.
I'm using a very similar setup on my BHW, except I chose the Hewitt Industries dual Boost/Fuel Pressure gauge, which also goes to 50psi. This allows me to run an AutoMeter isolator on the EMP line so I'm not running exhaust gas into the interior. The EMP line connects to the isolator in the plenum, and the isolator pushes on an antifreeze solution in a steel braided hose that hooks up to the threaded fuel pressure port on the back of the gauge.
Only problem is, when I ordered the gauge (and the oil pressure and pyrometer gauges), I misread the description and I ended up getting red backlighting instead of the white that I wanted D'oh!
GoremanX is offline   Reply With Quote
Old August 3rd, 2016, 20:44   #66
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
GoremanX - Thanks for the update. Do you have any pictures/part numbers to share of your install?
Some random updates over the last couple years...
What Kbrenney said about overpressurizing it is true. I pegged the red needle a couple times by accident and now it reads ~5psi high.
The Numatics filter seems to still be working well. It's fogged over and the tube to the gauge is black so maybe the filter media fatigued and broke? Have not taken the time to look into it.
Otherwise am still very happy with the gauge setup.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old August 3rd, 2016, 21:27   #67
GoremanX
GoremanX's Avatar
Fuel Pressure/Boost gauge is in the middle:
This is in my 2001 Audi A4. I don't have a video of it running yet because I'm still having setbacks with the TDI swap.
The rear of the gauge is more complex:
The ONLY good isolator available ANYWHERE is the one from AutoMeter, which uses -4 AN fittings. But all Hewitt Industries gauges use 1/8" NPT fittings. And because of the placement of the gauge, I needed a 90 degree elbow. But of course I couldn't find a 1-piece elbow/adapter, so I had to do it in 2 separate parts that look clunky. Oh well, it's all hidden from view anyways, and it did work fine when I tried it. I have the same arrangement on the oil pressure gauge, because I didn't want to run hot oil into the car.
The gauge can be found here:
http://www.hewittindustries.com/pres...oost_dual.html
I wish they had it in 60 or 80 psi just to avoid pegging the EMP needle, 50psi just barely covers my intended range (33psi boost means 50psi EMP under an ideal tune). There is an 80psi dual boost gauge available here:
but I'm not sure how well it would handle the fluid input of an isolator. As mentioned above, I'm not fond of the idea of running exhaust gas into the car. I drive my 2 year old daughter in there.
Old August 3rd, 2016, 21:54   #68
Fix_Until_Broke
That is a bit "clunky" as you say . Do you have a link to the AutoMeter Isolator you use?
This one maybe? https://www.autometer.com/media/2650-1124.pdf
I like the isolator idea - maybe it will keep the exhaust tube from freezing up in the winter (although it didn't freeze up last winter).
I did pause a bit when running the exhaust tube into the cabin, however figured that if any significant exhaust gasses were coming in through a broken tube, it would melt off in the engine compartment long before any significant amount of gasses built up inside the cabin since there would now be exhaust flow in the plastic hose.
I agree with using it for the engine oil - that would make a huge mess if it leaked!
I do wish the EGT gauge was a bit faster to respond.
Your setup looks good in the vents - Does your Audi have red gauges (my 03 TT and 04 A6 both have red backgrounds) so maybe it won't look out of place?
Old August 3rd, 2016, 22:13   #69
GoremanX
GoremanX's Avatar
Yep, that's the isolator I use. Hewitt Industries used to sell one, but apparently they had a high failure rate so they stopped selling them. Kinda odd for a company that sells only mechanical gauges...
I may have finally found a 1-piece AN to NPT elbow adapter, which would unclutter that setup. I'll order it tomorrow and find out.
My first car (a 1988 Toyota Tercel) had a tiny exhaust leak that managed to get sucked up by the cabin ventilation fan. The only way I noticed it was because I'd get super tired on drives longer than 1 hour. I almost died this way because I was close to passing out at the wheel. And this was a tiny N/A gas engine, not a turbodiesel with highly compressed exhaust. I'm not taking any chances with exhaust in the cabin. Those push-in plastic fittings don't inspire confidence.
The EGT gauge is only as fast as the thermocouple it's hooked up to. I went with a thermocouple that's well known for being very fast and accurate. Sadly, I can't remember the brand name or where I bought it. I'll try to remember to search more thoroughly tomorrow. I just know it wasn't a Hewitt Industries thermocouple.
(edit: found it, it's here - http://www.aircraftspruce.com/catalo...ickkey=1299199 - part number 10-01478)
My A4 has white gauge backlighting and red pointers. Only pre-facelift B5 A4's had red backlight. So these gauges look out of place
Old August 3rd, 2016, 22:28   #70
[486]
TDI(s): 02 golf ALH
you need a better turbo, my junky setup is running 38/45
Gauges are just a bourdon tube in there, nothing that is fluid or gas specific. use your boost gauge as an oil pressure gauge, use an oil pressure gauge on your air compressor.
My boost gauge is from a well pump, it has a vacuum scale labeled "well depth in feet"
[486] is online now   Reply With Quote
Old August 3rd, 2016, 22:37   #71
GoremanX
GoremanX's Avatar
I have no idea what my turbo can run. I have yet to run the build for more than 200 miles with a horrible tune, and the car's back on jack stands. It's a GTB1756VK which the seller tells me I should be able to run 35psi out of. I figured 33psi would give me the kind of performance I'm looking for with a little headroom. One of these days I'll be able to actually drive the damn thing.
There's no real way to pre-fill the tiny plastic tube with coolant for the isolator line. There has to be NO air in the line for the isolator to work right. The threaded port of the boost/fuel gauge is more adequate for that purpose. But if I can get a max of 45psi on the EMP line like you do, then the 50psi max isn't such a limiting factor after all
Old August 3rd, 2016, 22:43   #72
[486]
TDI(s): 02 golf ALH
There's no real way to pre-fill the tiny plastic tube with coolant for the isolator line. There has to be NO air in the line for the isolator to work right. The threaded port of the boost/fuel gauge is more adequate for that purpose. But if I can get a max of 45psi on the EMP line like you do, then the 50psi max isn't such a limiting factor all
My comment there was more in reply to this one:
"but I'm not sure how well it would handle the fluid input of an isolator"
Old August 3rd, 2016, 22:47   #73
GoremanX
GoremanX's Avatar
I get that, I'm just pointing out that there's more than one reason for my use of a fuel/boost gauge over a dual boost one. I didn't go into all the details in my earlier post for brevity.
Old August 15th, 2016, 09:23   #74
Rub87
Damn this is just what I need. now they need to make metric dials lol 0-3 bar boost and 0-6 bar for EMP
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old October 15th, 2017, 14:38   #75
Fix_Until_Broke
So, I've been noticing some "inconsistencies" with my pressure gauges and decided to plumb them all together in parallel with a reference gauge and see how they compare. This is probably something I should have done originally, but didn't so shame on me.
The results were not great unfortunately.
Stated accuracy is +/- 1% from Hewitt's website
I only found 1 of the 6 gauges to be anywhere near that accuracy
My test setup was relatively simple, but I have high confidence in it. I plumbed all 7 gauges in parallel and slowly adjusted the regulator on my air compressor until the pressure stabilized. Then I took a video of each gauge at the common pressure and then went back and watched the videos and entered each gauge's reading into a spreadsheet.
My reference gauge is the white one. I correlated that to a physical reference (U-Tube Manometer) at a handful of points up to ~25 PSI. It's not perfect, particularly at very low pressures, but it's pretty good.
The most concerning thing I noticed is the hysteresis in the movement - most of the gauges are sticky, some making 5+ psi jumps as the pressure is increased or decreased. Video's below of this phenomena.
All Gauges Video: https://youtu.be/daWKdKCLTyc
80 PSI Gauge Video: https://youtu.be/nfWXTBW7JFM
My intent is to share what I've found on the 3 gauges I have. For many applications, this won't be a problem, for others it could be. The information is here for you to make an educated decision.
Questions, comments and suggestions are welcomed
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 21:35
Best dual egt/boost gauge setup chiro05 Upgrades (non TDI Engine related) 9 October 4th, 2013 09:22
Looking for a dual needle boost gauge, max. 40 PSI Mark@MaloneTuning TDI Power Enhancements 22 October 16th, 2012 06:55
Any suggestions for a good 0-50 Boost/ EGT dual gauge? tothemax TDI Power Enhancements 24 December 7th, 2010 14:40
WTB: Westach dual boost/EGT gauge thursday Private TDI Items for Sale/Wanted 1 December 16th, 2007 12:51
Page generated in 0.13116 seconds with 10 queries
[Output: 150.05 Kb. compressed to 127.73 Kb. by saving 22.32 Kb. (14.88%)]
