Old October 22nd, 2014, 20:34   #46
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Here's the Numatics PLS-B
Just waiting to get a connector to hook it up to the 1/8" lines on the EMP gauge.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old October 23rd, 2014, 09:58   #47
flee
Fuel Economy: 40-ish
The inline filter might get plugged pretty fast.
How an automatic water trap? I've used some small light ones for pneumatics.
http://www.amazon.com/Fafada®-Separa...ater+separator
I just like the looks of this one...
flee is offline   Reply With Quote
Old October 23rd, 2014, 10:13   #48
flee
Originally Posted by kbrenny View Post
If anyone knows the correct term for those push on fittings I would like to know.
We always call them 'air swages'.
I'm not sure where that term came from.
Old October 23rd, 2014, 11:41   #49
Fix_Until_Broke
We'll see how it works. The problem I think you'll have with all the other filters I've seen is that they're so big compared to the size of the soot particles which are less than 1 micron. Now they agglomerate together to be bigger particles and will eventually plug up the damping orifice in the back of the gauge which is roughly 500 microns.
I've always heard the fittings called as "Push to Connect"
Old October 23rd, 2014, 22:34   #50
vanbcguy
vanbcguy's Avatar
There really shouldn't be much flow in to the gauge, it is a closed off tube after all. Clogging of the filter shouldn't be much of a concern as long as it is mounted somewhat downstream.
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old October 23rd, 2014, 22:50   #51
[486]
TDI(s): 02 golf ALH
Thus my suggestion of a dip in the tube to collect moisture and act as a trap.
[486] is online now   Reply With Quote
Old October 30th, 2014, 20:36   #52
Fix_Until_Broke
Hopefully I can get the numatics PLS-B filter installed this weekend. I found tubing/adapters to make it go inline with my 1/8" tubing, just need to take a little time to install it.
I stumbled across these on Cole Parmer's website looking for something else at work the other day
http://www.coleparmer.com/Category/C...e_Filters/1267.
Cheaper per unit, but higher minimum's.
Old October 30th, 2014, 21:36   #53
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
I use the larger one for vacuum system in electronic soldering tool. (fume extractor on desoldering gun)
Is pretty weak for pressure on tdi, i dont test but with my mouth, the filter wall bend a lot.
Smaller filter (diameter like one way vale on TDI) are stronger, is possible this filter hold the pressure you need.
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old October 30th, 2014, 21:51   #54
Fix_Until_Broke
The pressure rating is 60 psi at 25c for the 50mm ones and is 87 psi at 25c for the 15 and 25mm ones. Probably good for most single turbo applications
Old November 1st, 2014, 09:27   #55
Fix_Until_Broke
I bought the adapters and come to find out that the tubing on the HI gauge is just a bit bigger than 1/8" so the 1/8-1/4 adapters I purchased don't work
It must be 5/32 or metric - that's what I get for assuming instead of measuring...
I'll get the right adapters ordered on Monday and have them Tuesday then hopefully be able to get this installed.
Old November 1st, 2014, 09:44   #56
kbrenny
When I was installing mine the salesperson at Stuart hose gold me the tubing was 4mm.
When I asked him how he could tell without looking at it he responded "It is marked on the push lock fittings"
I never noticed it until he pointed it out.
kbrenny is offline   Reply With Quote
Old November 1st, 2014, 14:23   #57
Fix_Until_Broke
Well, 5/32 is within 0.0015" of 4mm and I can't find a 1/4" to 4mm adapter so we'll get one of those.
Old November 2nd, 2014, 10:12   #58
INA
TDI(s): 2.5 TDI
Try any parker fittings place. They usually have M4 to imperial barb fittings.
Issam N. Abed
iABED Industries
iABED Email
INA is offline   Reply With Quote
Old November 2nd, 2014, 12:40   #59
JFettig
JFettig's Avatar
I use 5/32 for 4mm all the time in my machines and fixtures.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old November 22nd, 2014, 12:30   #60
Fix_Until_Broke
I got this installed last week finally - Ignored the max temp limit and put it under the hood, but it's winter so it'll be fine for a while. I cleaned out the tubes with brake cleaner and compressed air until they were clean.
Once I cleaned it out the gauge a month or so ago, I noticed that it buzzed a lot on the exhaust side. So much so that I pulled the car over just a few blocks from home and filled the tube with brake cleaner and it damped the signal nicely. I did not have this buzz when new so maybe things have loosened up a bit in the gauge?
So, I left it in for a week and took a few pictures of it this morning. I did notice that it was freezing still and given the water in it, it's no surprise. However, the filter itself is keeping the soot out of the gauge.
Dirty tube
Clean tube
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 21:35
Best dual egt/boost gauge setup chiro05 Upgrades (non TDI Engine related) 9 October 4th, 2013 09:22
Looking for a dual needle boost gauge, max. 40 PSI Mark@MaloneTuning TDI Power Enhancements 22 October 16th, 2012 06:55
Any suggestions for a good 0-50 Boost/ EGT dual gauge? tothemax TDI Power Enhancements 24 December 7th, 2010 14:40
WTB: Westach dual boost/EGT gauge thursday Private TDI Items for Sale/Wanted 1 December 16th, 2007 12:51
Page generated in 0.15854 seconds with 10 queries
[Output: 147.77 Kb. compressed to 125.94 Kb. by saving 21.84 Kb. (14.78%)]
