Old October 5th, 2014, 19:11   #31
[486]
TDI(s): 02 golf ALH
Originally Posted by Fix_Until_Broke View Post
8' of tubing coiled up in a 6" circle under the dash and still get sooty water up in the gauge. Not exactly the same idea, but pretty close.
It oriented in such a way that it is the low point in the line, and there is a single low point in the entire thing?
[486] is online now   Reply With Quote
Old October 5th, 2014, 19:19   #32
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
That's the "not exactly" part...the coil is generally horizontal, but it is at the low point between the exhaust manifold and the gauge.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is online now   Reply With Quote
Old October 5th, 2014, 19:26   #33
[486]
TDI(s): 02 golf ALH
Try thinning it down to one loop, oriented vertically, and put an inch of water in the bottom.
Old October 5th, 2014, 22:16   #34
kbrenny
Just out of curiosity in colder climates, such as Wisconsin or Minnesota, would that water freeze?
Could it do any damage to the tubing?
How long would it take to return to liquid once the cabin was warmed up?
Could you use something liquid other than water with a better freeze point?
kbrenny is offline   Reply With Quote
Old October 6th, 2014, 06:05   #35
Fix_Until_Broke
Yes, it'll freeze.
It has not done any damage to the tubing I've used (vinyl, plastic, etc)
It takes ~15 minutes after you start getting heat depending on how cold it is
The water is from the exhaust gas - it's not put in there intentionally.
Old October 6th, 2014, 09:23   #36
andy2
andy2's Avatar
The filter is BD part #135.They are 6.79 CAD + tax.
andy2 is offline   Reply With Quote
Old October 9th, 2014, 16:16   #37
kbrenny
I tried to order some filters from BD today and they had to search for the part number as #135 did not come up.
The filter is referred to as a "scrubber" and the part number he came up with was 1200210.
Total cost was just over $15 for 2 filters plus shipping.
I also received my Hewitt gauge today and I did not get a invoice with a breakdown of prices but the total was $135 for the gauge, stainless EMP install kit, and shipping.
I will post pics this evening of the stainless EMP install kit.
The kit is not a solid stainless tube / pipe, but rather a 15" braided stainless hose with 1/4" npt threads on one end and swaglock fitting on the other end.
Old October 9th, 2014, 20:09   #38
andy2
andy2's Avatar
I knew I should have asked them myself.
Glad you got to the bottom of it I was wondering about that 3 digit part # as most BD part #'s were 7 digits.
I wouldn't be surprised if the one you receive is different than the one I have as mine was used in one of their kits from 10 years ago.
Let us know if its different.
Old October 9th, 2014, 21:43   #39
kbrenny
Here are pictures of the braided stainless Exhaust pressure install kit:
The part number is 721-300-015. The tech support guy said they use these all the time to connect to exhaust manifolds on diesels.
The ends of the hose are AN fittings with adapters to 1/4" NPT and 1/8" push to connect or push in fitting.
If anyone knows the correct term for those push on fittings I would like to know.
Old October 9th, 2014, 22:00   #40
Fix_Until_Broke
Cool stuff - Thanks for posting the info on their exhaust connection, good to know.
Old October 11th, 2014, 00:11   #41
kbrenny
While the Hewitt industries EMP install hose is a quality part, I don't recommend it for the TDI's (at least not for the ALH).
I tried to install it today and it is about 6 or 7 inches too long, and not long enough to make a loop back to the firewall. The hose is also very stiff and does not like to do any bending.
I tried to find 1/8" stainless steel tubing but could not find any local.
On my way home I had a bright idea so I stopped at an AutoZone and picked up a 3/16" inverted flare steel brake line and 2 fittings to adapt from the inverted flare fitting to 1/8" NPT thread.
All together the brake line and 2 fittings were less than $11, I also needed a 1/4" to 1/8" NPT bushing and a 90 degree 1/4" NPT street elbow.
Everything went together very easily and I used a rubber cushioned metal clamp to hold the line using the same bolt that holds down the turbo oil feed line to the exhaust manifold.
Here are some pics of the install:
Old October 11th, 2014, 03:22   #42
struikie
struikie's Avatar
TDI(s): BMW 335d E91
good looking gear !
JW
| 2007 BMW 335d | 3.0 6cil BiT + DPF | 385bhp 740Nm |
| 2009 VW Polo Highline | 1.6 TDI CAYC + DPF | 138bhp 304Nm | SOLD |
| 2005 Audi A4 B7 | 2.0TDI BLB | 245bhp 510Nm | SOLD |
| 1997 Audi A4 B5 | 1.9TDI AHU | 230bhp 430Nm | SOLD |
| 1992 Audi 80 B4 | 2.3e NG | 133bhp 186Nm | SOLD |
struikie is offline   Reply With Quote
Old October 11th, 2014, 20:26   #43
kbrenny
in case anyone needed the part numbers for the brake line and adapter fittings I used, here they are:
12" brake line part number PAX-312 Autozone SKU 216028
Brass 3/8-24 inverted flare to 1/8 NPT adapter fitting part number BLF-57C Autozone SKU 844613
Old October 12th, 2014, 22:28   #44
kbrenny
Gauge in action:
Old October 22nd, 2014, 16:54   #45
andy2
andy2's Avatar
I received a "snubber" from BD and it's a fitting used for dampening the exhaust pulses to the gauge.
The filter I was after has been obsolete for years now.They don't use a filter anymore.
The BD tech guy said people have made their own using 3/8" NPT fittings and a small tampon.I can't remember all the details but I think you'll get the idea.The benefit is that you can change the "element" once a year (for example) at a low cost.
If someone makes one please post a picture up here.
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 21:35
Best dual egt/boost gauge setup chiro05 Upgrades (non TDI Engine related) 9 October 4th, 2013 09:22
Looking for a dual needle boost gauge, max. 40 PSI Mark@MaloneTuning TDI Power Enhancements 22 October 16th, 2012 06:55
Any suggestions for a good 0-50 Boost/ EGT dual gauge? tothemax TDI Power Enhancements 24 December 7th, 2010 14:40
WTB: Westach dual boost/EGT gauge thursday Private TDI Items for Sale/Wanted 1 December 16th, 2007 12:51
Page generated in 0.21612 seconds with 10 queries
[Output: 135.66 Kb. compressed to 114.80 Kb. by saving 20.86 Kb. (15.37%)]
