hskrdu
This is done on a mark IV Golf, there may be differences for wagons, and it will not apply to all other marks. If you complete the mod, and find yourself wasting washer fluid just to see it work over and over, please do not blame me.
This is partially a documentation of the mod, and partially my rambling discussion of the process. Hopefully it helps someone do the same, without all the searching.
I’m a big fan of having a rear wiper. When I drive (her) Jetta sedan, I find myself pushing the right stalk forward to clean off the rear window, only to be reminded that there isn’t one. As much as I like the rear wiper, the older standard wiper arm and blade did not exert the best pressure on the glass (often leaving smears unless I had a fairly new rubber blade insert). There is a Polo rear wiper available (similar to the aero/euro front wiper) that improved the contact pressure, but it used the same stationary single rear washer jet, which is prone to leave some portion of my window dry enough to streak and remain a bit ugly. The jet can be slightly adjusted with a needle, but I couldn’t significantly improve the result on mine.
When my Golf’s rear washer spray started to fail, I decided to investigate my options. Time for a solution!
