courtesy of google,
On the instrument cluster, you will see two buttons, one on each side. With the key off, reach in and press/hold the button on the right, keep holding while you turn the key to "on", release that button and press the one on the left
^ My 2012 has a push button start and if you simply press the start button quickly (do not hold down) it will turn on the accessories without cranking the motor. Press and hold and it will crank.
