Old February 14th, 2014, 12:42   #1
motoracer47
TDI(s): Jetta
Default Speed Sensor Question
Hi,
I realize this question if going to be somewhat vague, sorry about that.
Looking at a 2001 Jetta (ALH) that the seller says needs a speed sensor. They say the car runs fine, and its not in any sort of limp mode. From researching this on the web, I am getting conflicting results. Here is what I have read so far.
That the VSS is on the diff portion of the casing, and cannot be removed without transmission disassembly.
That the VSS is on the diff portion of the casing, and CAN be removed from the transmission. (without disassembly)
That there are other speed sensor(s) inside the transmission that require that the transmission be disassembled.
That often when a code is thrown for a speed sensor, that it is actually the TCM, and a TCM replacement fixes the problem.
I have not looked at the car yet, so I do not have any codes. I don't own a VAG-COM yet, but I do have a program called CARPORT that uses VAG K+Can Commander 1.4 interface, that can read VAG specific codes. (its similar to VCDS, but maybe not as advanced)
I guess my question is, if there are speed sensors inside the transmission, what codes will I see that signifies this?
Next question..Can the VSS on the diff be changed without disassembly of the transmission?
If its easier to wait until I pull the codes, no worries, I can do that, just thought Id ask incase someone knew for sure.
thanks for any help
motoracer47 is offline   Reply With Quote
Old February 14th, 2014, 12:58   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
On both the manual and automatic gearbox bolted to the ALH, the VSS is the same, and is easily removed from the top of the diff.
The VSS drive however, is bolted to the top of the case, and requires removal of a bolt to the clamp to slide out, and that is just the driven gear. The gear that drives that is pressed on to the diff carrier assembly.
So what exactly are you talking about here?
There are also speed sensors at each wheel, the crankshaft, and the automatic trans also has its own speed sensor.
oilhammer
www.cardocautomotive.com
Old February 14th, 2014, 14:18   #3
motoracer47
TDI(s): Jetta
Amazingly fast response!! thanks
Well, not exactly sure. I have not actually looked at the car yet, only going by what the seller mentioned in the ad. It is probably best for me to wait until I see it, pull some codes, and drive it to see what the symptoms are. I know the seller has been driving the car this way for some time, and that whatever the problem is, apparently does not affect the drivability of the car or cause limp mode. Logic would tell me if it was a simple fix, it would have already been done, but maybe not.
You answered my question perfectly about the VSS.
Doing a little more research I found a thread that shows pics of the removal of the top portion of the VSS, and the driven gear (once bolt and clip removed) from the top of the trans casing. The same thread mentioned that the drive gear that is pressed on the diff can be removed without cracking the case. It requires removing the passenger side axle and flange.
All that sound correct?
Heres a linky to the thread http://forums.tdiclub.com/showthread.php?t=336952
My main concern is that there was some speed sensor not accessible from the outside of the transmission. But from further searching, it appears G22, G38, and G68 are all accessible externally.
If it ends up being the engine speed sensor, or a wheel speed sensor, I don't think I will have any issues, as they look (assuming?) easy to replace.
(when I searched, I only searched MK4 sub forum, expanding that to the entire site returned many more results...my bad)
Old February 14th, 2014, 15:17   #4
djd58
djd58's Avatar
pull the speed sensor and check the gear, if the gear on the diff is bad the gear on the sensor will be chewed up, if it is chewed up the trans will have to come out to change it
03 Jetta GLS TDI 5 Speed,01 Golf GLS TDI 5 speed, 11mm , RACE 520's' GTB2260VK, PD 150 intake, Race pipe, FMIC, Malone stage 5, .681 5th, Wavetrac LSD, 2011 golf TDI 6 speed, 2012 Passat TDI SEL premium, VAG-COM owner
djd58 is offline   Reply With Quote
Old February 14th, 2014, 15:46   #5
motoracer47
TDI(s): Jetta
djd58..
So this (below) is not true? (Btw, this is an auto trans car)
As far as the plastic gear on the diff carrier, if it is a auto trans,it's possible to change without removing trans. I did one 2 wks ago on a Jetta that kept having VSS fault & trans going in limp mode. On the auto trans, remove pass side axle & flange. Measure depth, mark location of lock ring. Remove retainer,unscrew lock ring & you'll see a metal retaining ring-plastic gear goes behind it,pop out retainer & your ready for new parts. Always repace metal retainer & plastic gear
Btw, I don't own this car, its a car im looking at buying, so pulling the VSS probably isn't a possibility
Just trying to get a feel for the various things that it could be so when I test drive it and pull codes, I have an idea of what Im looking at.
Regardless, Im going to go check it out this weekend, will report back with what I find. (symptoms and codes)
Old February 14th, 2014, 17:25   #6
AndyBees
AndyBees's Avatar
Below is a pic of a modified VSS which is located on the outside of the tranny as Oilhammer described.
Key word "modified" because the gear has been cut off. It was my intent to couple it with the speedometer cable. But, as you can see I was able to "screw" it on the ticker box ......... for my ALH Vanagon project... thus, the reason it is modified.
I hope this visual helps!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old February 14th, 2014, 19:34   #7
djd58
djd58's Avatar
I have replaced stock carriers with LSD's several times, and the gear that drives the speed sensor is behind the right side bearing which is pressed on, as far as my experience the only way to change them is to split the transmission, but then again I throw automatics away in favor of manuals, I have done 4 manual swaps on mk4 TDI's
Old February 15th, 2014, 04:47   #8
jimbote
jimbote's Avatar
02j and 01m speedo drives are threaded into the case not bolted lke the older 020 ... and the manual and auto speed sensors while functionally the same are different ... 01m auto sticks straight up while the 02j is a 90* job .... to the OP if the drive gear on tne trans is bad (01m auto) you need to remove the diff carrier and press the passenger side diff bearing off to replace the gear... this can be done in the car but requires subframe removal ... if it's the driven gear or sensor they can both be replaced in about five minutes
jimbote is online now   Reply With Quote
Old February 15th, 2014, 05:01   #9
jimbote
jimbote's Avatar
the drive gear (worm) that is installed on the carrier cannot be removed without pressing off the passenger side diff bearing ... the diff has to be removed for this... the diff can be removed (01m auto only) without dropping the trans .. however the subframe has to be dropped, axles have to be removed, axle flanges and bearing retainers for the diff as well as the diff cover .... but it's easier to drop the auto trans ... i can have one out now in under 30 minutes (lots o' practice ) ... i did the whole "replace the drive gear in the car" thing in the very first 2.0 beetle i ever worked on years ago .... (i wouldn't do it that way again)
Old February 18th, 2014, 18:32   #10
motoracer47
TDI(s): Jetta
Sorry to just get back to this thread. Again, awesome info everyone, very informative. I didn't get a chance to look at the car this weekend, had an emergency with work
Anyhow, all of this info will definitely make it a bit easier to try and figure it out when the time comes.
1 last question. Is the pic below of an 01M transmission?
Again, thanks for the help.
Old February 19th, 2014, 04:48   #11
oilhammer
oilhammer's Avatar
Yep, that is the ubiquitous 01M in all its glory. A sight I have seen countless times over the last 20+ years. I think I'm getting better and pulling the 02E out now, though.
oilhammer
A Question for all the experts. Vehicle speed sensor. JIMMY-JAMES VW MKIII-A3/B4 TDIs 0 October 27th, 2010 00:08
Speed Sensor Question bcmedic13 VW MKIV-A4 TDIs (VE and PD) 0 January 19th, 2010 14:39
How to disconnect the speed sensor cable from the speed sensor? Charchrist New Beetle TDI Picture Gallery 3 November 12th, 2008 19:27
speed sensor question Mapo VW MKIV-A4 TDIs (VE and PD) 0 January 26th, 2004 11:23
MIL Question - Speed Sensor Recently Replaced mikeyworks VW MKIV-A4 TDIs (VE and PD) 2 November 20th, 2002 04:55
Page generated in 0.13374 seconds with 10 queries
[Output: 109.52 Kb. compressed to 93.30 Kb. by saving 16.21 Kb. (14.81%)]
