Old February 11th, 2014, 14:45   #1
robertyateman
TDI(s): 1999.5
Default MAF CEL help
Hey i have a 1999.5 jetta tdi manual
so the problems i keep getting is this code 17553/P1145 - Mass Air Flow Sensor (G70): Short to Plus. My car also will go into limp mode if i punch the accelerator or go up a hill, ect. with my vagcom i went to ch 3 and under the actual was ~530 or something and it didnt move no matter the rpm.
i just recently tried a used maf from a 2001 so maybe it was toast to. the connections themself look good on the maf and the plug.
Any advice on were to troubleshoot i dont have a bently manual so i dont know the wiring diagram of the maf or fuses ect.
Thanks, Robert Yateman
robertyateman is offline   Reply With Quote
Old February 11th, 2014, 15:55   #2
robertyateman
TDI(s): 1999.5
tuns out pin 2 has 4.5v coming to it and pin 4 has 11.8v going to it so i image its either a grounding issue or bad maf ?
Old February 12th, 2014, 19:42   #3
Dimitri16V
Dimitri16V's Avatar
nope , voltages are right
the ECU always defaults to 5V in that pin when you disconnect the MAF
Use a MAF cleaner to clean the sensor . are you sure the plug is OK ?
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old February 14th, 2014, 12:03   #4
robertyateman
TDI(s): 1999.5
i tried my friends maf off his 2000 vr6 and it still through the code plus it was reading the same 530mg/H as the other two .
Old February 14th, 2014, 12:12   #5
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Have you checked for blockage at the snowscreen? Could also be a blown fuse or a bad wire. I've found no less than 2 nicked wires on mine.
Old February 14th, 2014, 12:23   #6
robertyateman
TDI(s): 1999.5
no i havent i removed the maf from airbox and let it suck fresh air and still the same readings. what fuses ? i am going to splice the ground wire from the plug and ground it myself see if that does anything.
Old February 14th, 2014, 12:26   #7
robertyateman
TDI(s): 1999.5
would that work or would it just mess up the ecu ?
Old February 14th, 2014, 12:48   #8
BobnOH
not-a-mechanic
It would be best to use the ground as it's designed, manually grounding certain wires will produce undesirable results. Try following the ground wire and the signal wires. Look for any breaks or bad connections.
Check fuses 12, 29, 32 and 34 first.
Old February 14th, 2014, 13:11   #9
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Check all your fuses.
oilhammer
www.cardocautomotive.com
Old February 14th, 2014, 13:16   #10
robertyateman
TDI(s): 1999.5
ok i just wired in a new plug and ill check fuses now ill let you know what happens in 10
Old February 14th, 2014, 13:40   #11
robertyateman
TDI(s): 1999.5
all fuses good. plug changed still same code g70 short to plus. I think im going to try and ground it out myself and see were that gets me because it seems really difficult to follow that wire.
Old February 14th, 2014, 14:16   #12
robertyateman
TDI(s): 1999.5
the headache is over i cut the green wire/ground and routed it right to the ground on the battery terminal. no codes and my maf reads the right mg/h
maf, cel bugablue TDI 101 1 February 20th, 2006 18:49
CEL ?? MAF??? Innkeeper Quebec 19 October 15th, 2004 06:49
How to get a MAF CEL? jettajim VW MKIV-A4 TDIs (VE and PD) 5 February 9th, 2004 07:48
New MAF but,,,New CEL florijetta VW MKIV-A4 TDIs (VE and PD) 4 March 11th, 2003 14:00
New MAF, CEL..... MacGuy VW MKIV-A4 TDIs (VE and PD) 0 March 22nd, 2002 20:00
Page generated in 0.14755 seconds with 10 queries
[Output: 103.15 Kb. compressed to 86.23 Kb. by saving 16.92 Kb. (16.40%)]
