Old January 10th, 2014, 11:33   #1
nptdi
Default 2002 Jetta TDI fuel filter replacement
How much pressure should I apply to get the return valve reseated? I have the filter changed, O-rings replaced, and all the lines hooked back up. Should I unhook all the fuel lines, remove the filter and try to reseat the valve prior to putting it in the engine? I can not get it in! I have been on here for an hour and can't find the answer. So alas, a new thread is born.
nptdi is offline   Reply With Quote
Old January 10th, 2014, 11:36   #2
nptdi
Oh, and the reason I haven't already pulled the lines from the T(return valve) is because they are stuck on there pretty good and I didn't want to risk cracking anything.
Old January 10th, 2014, 12:10   #3
nptdi
ISSUE RESOLVED:
before I removed the line from the return valve I was almost pushing as hard as I could with one hand while still supporting the filter with my other and I could not get it in. I removed one side and it popped in without too much fuss. All and all not a hard project but I sure hate those compression clips, or whatever they are called. Trying to remove them with needle nose pliers is a pain. Car cranked up and drove fine post filter replacement. If air got in the system would it have already presented itself?
Botched fuel filter replacement - 2010 Jetta TDI Physio13 VW MKV-A5 Golf/Jettas 9 August 17th, 2013 06:13
2002 vw jetta tdi engine cranks no fuel in line i changed the fuel filter wade TDI 101 3 December 5th, 2012 04:19
2006 Jetta TDI fuel filter replacement gwasko TDI 101 4 December 4th, 2009 10:50
2006 Jetta TDI Fuel Filter Cartridge Replacement biojetta Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 7 December 16th, 2008 17:53
2002 jetta tdi fuel filter Orrin VW MKIV-A4 TDIs (VE and PD) 5 July 26th, 2004 14:02
Page generated in 0.13369 seconds with 10 queries
[Output: 56.42 Kb. compressed to 51.30 Kb. by saving 5.12 Kb. (9.07%)]
