Old January 7th, 2014, 08:53   #1
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
Default Car not starting - help
Hello
i have a 09 JSW that is not starting.
It sounds like it is hydrolocked.
The car has been off in my driveway since friday afternoon, i'm in chicago we had snow all weekend and now we have polar temperature (-15), i tried to start my car last night and did not start, the error i get is Oil Pressure low which is the same i had when the car was hydrolocked because of the iced IC issue. I had the upgrade for that from VW but i guess it did not fix it
Anyway because of the amount of snow and the bitter cold i have to chance to clean the IC, any other suggestions?
I did not force the car to start as i was afraid.
C.
09 JSW, Build date 04/09
E brillera' per sempre, la stella di Firenze...
Claudio is offline   Reply With Quote
Old January 7th, 2014, 08:55   #2
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
forgot to mention the last 2 tanks have been with PS white + biodiesel
Old January 7th, 2014, 09:28   #3
philngrayce
Fuel Economy: 53/43/49 ('02 Jetta 5 sp)
Biodiesel at -15 is not very good. Do you know what percentage BD you have?
Still, that shouldn't cause a low oil pressure warning, unless that is just because it didn't start. You could try warming the filter, fuel lines and intake with a hair dryer. But if the tank and lines are gelled, it will only run for a moment anyway.
philngrayce is offline   Reply With Quote
Old January 7th, 2014, 09:34   #4
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
i believe is B11, is the only thing you find in IL (well, pretty much, but 100% of all fuel station in my area have B11 because of a tax break).
I had PS white for the last 2 tanks, that should have helped with the gelling.
That's why i believe it is the IC frozen.
it is supposed to go above freezing on friday, i will try again then i guess.
i'm using my wife T&C today (which by the way started at the first attempt at -12 yesterday after sitting all night in the driveway at -20) and will work from home tomorrow
Old January 7th, 2014, 13:57   #5
Claudio
Claudio's Avatar
TDI(s): 09 Jetta SW
lol i went to menards to get some D911 just in case, and the shelf was empty!
Need help car not starting wal1809 TDI 101 14 July 31st, 2012 17:27
Car not starting after new seats? keks TDI 101 6 May 19th, 2012 20:37
Car not starting..... konkapot TDI 101 15 July 9th, 2009 12:07
car not starting, any help out there please? shufti VW MKIII-A3/B4 TDIs 15 August 9th, 2007 18:59
Car not starting....HELP!!! tverhoeven VW MKIII-A3/B4 TDIs 30 May 19th, 2006 14:10
Page generated in 0.14560 seconds with 10 queries
[Output: 68.77 Kb. compressed to 60.63 Kb. by saving 8.13 Kb. (11.83%)]
