Old January 3rd, 2014, 19:20   #1
barreto
TDI(s): 1.9tdi ve
Default camshaft tdi asv power
hello, I have a ibiza 6k with asv engine, which must gtb2060vklr material, 11mm head, nozzles hflo-x 0.341 and reprogramming to 2.1bar.
Wanted to put a cam but dont know which place you should get more gains, I thought of 260 º or 272 º dbilas what these say?
What other brands advise that has good feedback?
Another thing, usually mechanical meter hydraulic lifters instead of the ina?
Greetings and thanked tdi help the world.
barreto is offline   Reply With Quote
Old January 3rd, 2014, 22:48   #2
mk1-83
Fuel Economy: 1:15
Dbilas 260 are great no need to go mech lifters the oem hydr. Are fine
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old January 5th, 2014, 05:49   #3
barreto
TDI(s): 1.9tdi ve
But what is the difference of 260 º to 272 º?
Which gives more hp?
And mechanical lifters we usually get in tdi vp?
There is another camshaft from another brand with good feedback?
cumps
Old January 5th, 2014, 07:12   #4
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Camshafts are a compromise - Where in the power band do you want more power?
Very generally, the longer the duration, the higher in the power band it will make power (not necessarily more power) and the more you'll loose in the lower RPM band.
Bigger is not always better when it comes to camshafts
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old January 5th, 2014, 10:03   #5
barreto
TDI(s): 1.9tdi ve
2000 at 5300rpm
Old January 5th, 2014, 10:49   #6
Fix_Until_Broke
We all would like that
You'll probably have a +/-10% maximum effect over a ~2000 RPM wide powerband with a camshaft from one extreme to another with all the supporting modifications.
This is just my uneducated, anecdotal opinion - others with more experience may chime in an school me on this so take it for what it's worth - free advice on the internet
Old March 23rd, 2014, 07:13   #7
barreto
TDI(s): 1.9tdi ve
More opinion please, I want to buy a camshaft
The engine is open and can be changed in order to get any scoring camsahft.
Old March 23rd, 2014, 08:45   #8
mk1-83
Fuel Economy: 1:15
Im use a dbilas 250* / 250* 9.5 mm lift works good maybe get a dbilas 260 cam
Lupo 1.9 tdi
300+ HP 500 nm
Old March 23rd, 2014, 10:15   #9
jabcok20
TDI(s): golf mk1
Barreto how much hp you got on your setup with .341 nozzles?
AFN gtb3576klnrv 12mm
Stock AFN block , CR 17:1 , de143 , pump mod , porthead, GGU gearbox , strenghtened clutch.
jabcok20 is offline   Reply With Quote
Old March 23rd, 2014, 11:19   #10
mk1-83
Fuel Economy: 1:15
Dibilas 260 * 9.9 mm lift buy that one and its good
Lupo 1.9 tdi
300+ HP 500 nm
Old March 23rd, 2014, 14:00   #11
barreto
TDI(s): 1.9tdi ve
I don´t no, but maybe 270hp with 2.1bar.
I have camshaft stock.
Old March 23rd, 2014, 14:01   #12
barreto
TDI(s): 1.9tdi ve
What diference 260 or 272 ?
What have more hp 260 or 272 ?
Old March 25th, 2014, 12:55   #13
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
This is the cam I run:
11.17mm lift
225@.050 .440" intake
230 @.050 .440" exhaust
110 lsa
Excellent midrange power, but not good at low rpm. Power increase over previous 196/196 cam at mid to upper rpm. Power loss at low rpm vs. 196/196 cam
You may gain in one area, but lose in another. Depends where you want power
02 Jetta, 17:1 CR 81mm ASV, block girdle, ported head, custom Colt cam, IE rods, TT springs, cryo gears, Peloquin LSD, Raxles, FueLab Prodigy pump, 12mm/DE143, HFLOX 5 x 0.013, R32 intake, NX nitrous, 6+6 billet BatMo turbo, Bilstein PSS9 coilovers, BFI mounts
MKVII GTI 6MT, full build, 525hp daily driver. Soon EFR 9174
loudspl is offline   Reply With Quote
Old March 25th, 2014, 13:08   #14
Satiro
Satiro's Avatar
Excuse my lack of skills, if you use a cam that has a power improvement over stock in some rpm range, are you losing the same power in another rpm range? is it proporcional?
Rub87remap ARLpistons PD100rods Sputters ARLbolts Rosten'sMainStuds VitonSeals PortedHead Rosten'sValveSpring ASVpump 11mmHead DE143 11mmSprings GT18v Race520 BigFMIC fuelCooler LiftPump CRfuelFilter PD130Manifold Dbilas260cam BlackLifters OilCooler 312mm+porscheCalipers Sigma5SSK BilsteinEibach MK4RearBearings/Calipers EibachProKitSwayBars
Satiro is online now   Reply With Quote
Old March 30th, 2014, 02:17   #15
X-Man
X-Man's Avatar
personally I would go for 1.9SDI camshaft it is not easy to find but was proven to give good results
TDI turbochargers for less
turbos@xman750.co.uk - GTB1756vk, GTB2260vk, 1.9TDI hybrids and more...
www.facebook.com/XMan-Turbos
X-Man is offline   Reply With Quote
ASV down on power F2 Ed TDI 101 6 January 31st, 2015 17:07
ASV low on power HiRoller TDI 101 0 May 15th, 2013 11:35
110 Tdi Asv with low power squeak VW MKIV-A4 TDIs (VE and PD) 0 December 2nd, 2011 10:56
will AHF/ASV 110hp camshaft fit in ALH/90hp seninho TDI Power Enhancements 10 June 24th, 2008 09:36
ALH to ASV conversion - Power Mod by itself? peter pyce TDI Power Enhancements 4 February 20th, 2004 19:02
Page generated in 0.15132 seconds with 10 queries
[Output: 130.71 Kb. compressed to 109.52 Kb. by saving 21.19 Kb. (16.21%)]
