Old December 17th, 2013, 13:11   #1
SoCATDI
Default Help! Need to add TRANSMISSION fluid to my '05 TDI Passat
We just had to replace to the power steering pump and in that process of taking off the front of the car, etc....we had to disconnect the transmission fluid line to replace the power steering pump. In that process I lost some transmission fluid. Since there is no place to check this fluid, HOW DO YOU ADD the transmission fluid in this car? ANY help would be appreciated!!
SoCATDI is offline   Reply With Quote
Old December 17th, 2013, 13:29   #2
abctdi
abctdi's Avatar
There is a fill port on the trans pan as well as a drain port.
Now is a good time to R&R the fluid unless you did it recently.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old December 17th, 2013, 14:40   #3
truman
There are 2 plugs in the tranny pan. The front one is the drain and the rear is to fill.
You have to jack the car up level, remove front plug/drain, then replace front plug. Remove rear plug and there is a tube that determines fluid level. Pump new fluid up through the tube until it overflows, then replace plug. You are also supposed to check temperature, since fluid expands. Temp is supposed to be about 113F IIRC. Exact temp is not critical- IMO.
truman is offline   Reply With Quote
Old December 18th, 2013, 05:30   #4
50harleyrider
Look at the really nice thread in myturbodiesel.com. It's pretty much as truman says with nice photos.I'd recommend doing the full fluid change to hopefully add some life to your GMR. http://www.myturbodiesel.com/1000q/b5/auto-transmission-ATF-fluid-change.htm
50harleyrider is offline   Reply With Quote
need help 05 passat tdi transmission shot chandlerz32 VW B5 Passat TDIs 17 April 19th, 2011 16:12
05 Passat - Transmission fluid&filter change interval AtlantaPassatTDI2005 TDI 101 5 March 25th, 2010 21:32
Wanted 05 Passat TDI Transmission obxwrangler Private TDI Items for Sale/Wanted 3 March 25th, 2010 21:31
How do I add Auto Transmission Fluid to 2002 Golf? TDIChuck VW MKV-A5 Golf/Jettas 1 September 5th, 2005 23:58
Transmission Fluid level on 04 TDI Passat DonC VW B5 Passat TDIs 5 May 9th, 2004 13:47
Page generated in 0.15918 seconds with 10 queries
[Output: 62.44 Kb. compressed to 55.78 Kb. by saving 6.66 Kb. (10.67%)]
