The 5w30 and 5w40?European car formula
If your car doesn't have advanced aftertreatment like a DPF -- your `97 doesn't -- there's no need for a low SAPS oil. Non-low SAPS oils (not calling them high-SAPS) will have higher quantities of anti-wear compounds which almost invariably contain P or S, like ZDDP and MoS2. I'd rather have maximum wear protection in my older vehicle than the latest letters on the API classifications.
If we are talking API oils, CJ-4 oils, since 2006/2007, have no issues with protection. For Euro oils, pick a 0w40 or 5w40 and run it with no hesitation.Alright. Good to know.
It just crossed my mind and I couldn't find any info on it here and though others may wonder.
North American owner's manuals might list API CF-4, owing to what was current at the time in which they were printed. IMO, people are under a false sense to base their oil buying decision on simply having the latest API classifications without knowing more about the whys and whats of each succeeding classification - and they're not expected to; it is the supposed experts at the sales counters and professionals servicing their cars who should know this and give appropriate advice to the owners.All the current gasoline categories (including the obsolete SH), have placed limitations on the phosphorus content for certain SAE viscosity grades (the xW-20, xW-30) due to the chemical poisoning that phosphorus has on catalytic converters. Phosphorus is a key anti-wear component in motor oil and is usually found in motor oil in the form of zinc dithiophosphate. Each new API category has placed successively lower phosphorus and zinc limits, and thus has created a controversial issue of obsolescent oils needed for older engines, especially engines with sliding (flat/cleave) tappets. API, and ILSAC, which represents most of the worlds major automobile/engine manufactures, states API SM/ILSAC GF-4 is fully backwards compatible, and it is noted that one of the engine tests required for API SM, the Sequence IVA, is a sliding tappet design to test specifically for cam wear protection. Not everyone is in agreement with backwards compatibility, and in addition, there are special situations, such as "performance" engines or fully race built engines, where the engine protection requirements are above and beyond API/ILSAC requirements. Because of this, there are specialty oils out in the market place with higher than API allowed phosphorus levels. Most engines built before 1985 have the flat/cleave bearing style systems of construction, which is sensitive to reducing zinc and phosphorus. Example; in API SG rated oils, this was at the 1200-1300 ppm level for zinc and phosphorus, where the current SM is under 600 ppm. This reduction in anti-wear chemicals in oil has caused premature failures of camshafts and other high pressure bearings in many older automobiles and has been blamed for pre-mature failure of the oil pump drive/cam position sensor gear that is meshed with camshaft gear in some modern engines.
Does it actually have the "-4" or is it just CF? That's the way it used to be. I can't remember seeing an oil with VW50x and an API other than CF....
I'm currently using Castrol Syntec 0W-30. The bottle states it meets VW 505.00, ACEA A3/B4 but "only" API CF-4...
It's an MB 229.5 oil, it has to be goodYou're right - CF (don't have the empty bottles anymore, just going by what's on the interwebs ). Oh noes, my engine is going to blow up!
Based on the comparison tool from Lubrizol, that doesn't seem to be the case. I'm curious as to what data suggests the CI-4+ certification has better wear protection than the newer CJ-4?LOW SAPS = Lower Protection, DPF emissions friendly
HIGH SAPS = Higher Protection, NOT DPF Friendly....
"SAPS" ...or the "additive package" that protects the engine from wear......isn't friendly with DPF's, thus a Emissions Friendly "LOW SAPS" version available.
Regarding older API certs, CI-4+ had higher engine wear protection than the new CJ-4 standard....for similar reasons.
