RDC98tdi
I commute 80 miles each way to work and back. She's run like a dream since day 1, albeit with a bit of crankiness when it gets below 30*. So this morning, outside temp was around 25-28* and 40 miles into my trip, flashing glow plug indicator and limp mode. Oh sh*t, oh sh*t.. But I noticed my coolant temp was hovering around 200, boost was hovering around 4 PSI, engine was smooth and quiet as ever at around 2100 RPM.
I put the clutch in, take it outta gear and shut the car off coasting for a second (no one around in front or behind for at least half a mile) and start it back up, this time with the actual CEL on and glowplug light still blinking (sh*t I broke it worse?) I then scanned the codes with Torque (love this app) and got a P0236 and P0237. I had another few miles till the next exit so I cleared the codes and voila, power was back! Until I pressed the pedal down a bit more..
I finally manage to limp to the nearest exit a couple miles away rolling about 60-65 mph in a 70 zone, let the EGT' settle to around 400* and shut her off for a few minutes. Started up, same codes, but just the glowplug light blinking. I know this usually means stop car immediately, but fluids were all at normal levels, temperatures were in range, car was not making bad sounds, and I could limp the remaining 35 or so miles to work at 65-70 no problem. Also, boost gauge was showing VACUUM, as well as slight amount of boost. Seems like low voltage at one of the sensors?
I called Paramedick on the drive there and I will be stopping by after work today. It should take 30-45 minutes to get there from work.
So, I live in Louisville KY and I bought the car from Bachman VW there. I am working in Lexington KY (80 miles away) and there is a Don Jacobs VW here. So, should I call my dealership and see if my warranty will cover it being towed to Don Jacobs and worked on? Or should I drive to Versailles after work? I have no issues with Paramedick at all, he's helped me with my last Jetta TDi a few times, but wondered if it might be something I should let the warranty pay for?
I know it isn't VCDS (can't do that while driving), but the codes are
P0236: Turbocharger Boost Sensor (A) Circ Range/Performance
P0237: Turbocharger Boost Sensor (A) Circ Low Input
I am wondering if the voltage going to or from the sensor is just going low for some reason. Possibly loose connection, water or salt in there, or a possible vacuum leak? I will get it scanned with VCDS this evening.
