Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old November 28th, 2013, 17:06   #1
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Default Bosch compact: Pressure in diesel engines
”Over the next decade, the vast majority of diesel engines will manage with injection pressures of around 2,000 bar. Although 3,000 bar is not unrealistic, it will be limited to racing cars and high-performance diesel engines.”
Old November 28th, 2013, 18:49   #2
GoFaster
Moderator at Large
All well and good but I wonder if they'll be trying that using a CP4.1 pump ...
Seems like a number of later model engines have backtracked from the piezo injectors and backed off the pressure a little to avoid grenading that thing - or even chose a last-generation pump design (Cruze).
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old November 29th, 2013, 01:45   #3
Mechnurse
Fuel Economy: 42+
I wonder what engines they plan on using this in? Great if this works as designed but with sub standard lubrication all bets are off!
97 Passat TDI sedan PP520 RC1
00 Passat 1.8T APR stage 1
05 Passat TDI Unchained Tip VB mod Vented Steel GP's RC2
Mechnurse is offline   Reply With Quote
Old November 29th, 2013, 08:25   #4
Ski in NC
Fuel Economy: 48-52 typical
I wonder how close they can get to meeting PM specs without using a DPF. That was mentioned as a possibility in the text.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old November 29th, 2013, 12:30   #5
TDI2000Zim
TDI2000Zim's Avatar
Fuel Economy: 0.0 mpg
I suspect that GM knows something we don't.
The CP1H may be the key to avoiding the present crisis.
TDI2000Zim is offline   Reply With Quote
Old November 29th, 2013, 17:54   #6
jgeorge
Went to the Audi Canada official unveiling of the 2015 A3 sedan last night. New HPFP being used which is to be more efficient, and adds a little more horsepower and torque. Good news. Could not get which model pump as my answer came from one of the corporate reps who was on hand. Also at this time urea will not be used but that may change. It depends on how the testing goes for Canadian emissions. The TDI will arrive late August 2014 with the gasser versions being released April-May 2014. Very attractive car. Audi expects to sell a lot up here.
jgeorge is offline   Reply With Quote
Recommendations for compact diesel beater pickup? mrchaotica Non VW Group Diesels 17 December 9th, 2009 17:01
WSJ: Bosch's Johannes-Joerg Rueger On Why Diesel Engines Are Hip TDIMeister TDI News/Tech 6 October 9th, 2008 13:39
Compact Sports Diesel- Polo now with 130hp TDI VW Derf TDI News/Tech 15 December 28th, 2003 17:30
Do the PD engines use a Bosch MAF? Karmann-diesel VW MKIV-A4 TDIs (VE and PD) 3 October 17th, 2003 06:53
CGI (Compact Graphic Iron) for use on new V6 Ford Diesel VW Derf Non VW Group Diesels 3 March 8th, 2002 00:26
Page generated in 0.13201 seconds with 10 queries
[Output: 74.81 Kb. compressed to 65.49 Kb. by saving 9.32 Kb. (12.45%)]
