mannytranny
I've got the engine and trans securely bolted into the sidekick...now I'm starting to look at the wiring mess. A fellow TDIer was kind enough to email me the pinout and I'm thinking (read: hoping) that there are a few things I can do without. So, do I need the following?
pin 17 clutch switch
pin 20 brake light switch
pin 28 A/C relay (car has no A/C)
pin 34 and 35 cruise resume and set (no cruise)
pin 37 A/C on switch
pin 44 brake light
pin 66 cruise switch on
Can I just remove these wires from the loom or might this cause problems? My biggest concern is the clutch switch...not sure how the ECU uses that signal. I'm using the stock starter and ignition that is in the sidekick and it seems to take care of things fine. (ie no starter allowed to turn without clutch depressed)
Thanks in advance for the advice!
pin 44 brake light
