Old November 24th, 2013, 07:15   #1
vwfern
Default Water Level Sensor False Reading
I've got an '02 jetta wagon 5spd with about 184k miles on it. For the past several winters I've been getting a water level alarm as soon as I start the car when the engine is cold. Once it warms up a little and I turn it off and re-start the light doesn't come back on. The light does not come on when the engine is warm.
I've replaced the temp sensor and thermostat and flushed the coolant. The coolant level is good.
Thoughts?
vwfern is offline   Reply With Quote
Old November 24th, 2013, 07:36   #2
Rxfire
Rxfire's Avatar
Yep, common with ours when cold, too. Same deal, drive to end of driveway, turn off, turn back on, all is well. I slightly overfill coolant during winter, seems to help
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old November 24th, 2013, 09:51   #3
Genesis
Fuel Economy: 53/48/42
Replace the expansion bottle. The probes get gunked up, are nearly impossible to clean successfully, and the bottle is cheap. Mine did this as well and a new bottle stopped it.
Genesis is offline   Reply With Quote
Old November 24th, 2013, 16:21   #4
Seatman
Seatman's Avatar
Fuel Economy: No idea
Or if you're tight clean it with an old toothbrush, that seems to have worked well for a number of people but I think the tank is cheap anyway.
Seatman is offline   Reply With Quote
Old November 24th, 2013, 16:34   #5
Genesis
I tried that and it helped for a little while but you can only get to part of the probes with the brush (not the bottom half) and the problem comes back.
Old November 24th, 2013, 19:18   #6
MT204
TDI(s): 05 JETTA
Funny thing.
A couple of days ago the wife said she started the car (first really cold morning) and the low fluid light came on. She turned it off to look in the owners manual to be sure but when she started it up all was, and has been fine.
About an hour later got a call from the kid. He wants to know what the one warning light was (same year TDI). He shut the car off, when he started it all was well again.
Both had correct amount of antifreeze in them.
MT204 is offline   Reply With Quote
Old November 24th, 2013, 21:10   #7
halocline
Mine does the same thing, I tried cleaning the sensor probes, didn't work, someday soon I'll replace the coolant expansion tank.
halocline is offline   Reply With Quote
My situation about TDI, temp gauge. Actual overheat or false reading? Colexius TDI 101 10 March 1st, 2013 07:15
Can Vag-Com adjust fuel level reading? shizzler OBD Scanners 3 August 4th, 2010 12:44
Windsheild Washer Water Level Sensor - P/N Request scooter VW MKIV-A4 TDIs (VE and PD) 0 July 29th, 2008 09:01
Fuel Gauge isnt reading correct level cfm56 VW MKIV-A4 TDIs (VE and PD) 6 June 20th, 2007 05:26
At What Water Level Will a B4 Float? NadaGasser TDI 101 10 June 17th, 2004 13:16
Page generated in 0.12549 seconds with 10 queries
[Output: 77.67 Kb. compressed to 67.46 Kb. by saving 10.20 Kb. (13.14%)]
