Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old November 19th, 2013, 15:42   #1
japedo
Fuel Economy: Better then anything I have owned prior:)
Default Intercooler icing
I am new to VW and have been reading lots on their strengths and weakness's. In regards to the intercooler icing problem, i have a question/ theory.
I have had 5 turbo volvo's with air to air stlye intercooler's similar to the MK6 jetta. Volvo intentionally puts a small hole in the bottom of the intercooler. The hole is tiny, about the size of a small needle. so there is very little boost lost.
I found out about this tiny pin hole in the volvo's intercoolers one day when i noticed my car had developed an oil leak. It was leaking out of the pin hole. Talked to a mechanic who said my PCV system was clogged and thats why i was also getting the oil in the intercooler, and he was correct as cleaning the pcv/flametrap system stoped the oil from makeing its way to the intercooler.
Maybe Volvo designs it this way to drain moisture as well? I'm not sure.
So after reading about intercooler icing on mk6 Jetta's, I wonder if a simmilar pin hole in the bottom of the intercooler would allow the accumulated water to drain when the ice thaws.
In saying that, I have had my car for 6 weeks and havent had the splash guard off the bottom of the car to actually look at the intercooler, maybe it is set up a little different and the "pin hole" wouldn't work.
It would be hilarious if it was that simple to fix though! interested to see what you all think of this theory.
.... Posted this in a longer thread and didnt get any feedback so gave it its own thread, hope that's ok. Thanks!
japedo is offline   Reply With Quote
Old November 19th, 2013, 16:07   #2
I800C0LLECT
Doesn't seem like a bad thought imo. :thumbs up:
Car stereo log: Jetta Hybrid w/ GB10, GB25, GB60, GB10D4 -- AudioFrog
I800C0LLECT is offline   Reply With Quote
Old November 20th, 2013, 08:40   #3
opticalmike
Perhaps a guy could punch a small hole in the bottom hose to check and see water come out. if no water escapes a guy could put a small screw in the hole to plug it.
mkvi jtdi nav/dsg sedan
opticalmike is offline   Reply With Quote
Old November 20th, 2013, 08:55   #4
japedo
Yes that may work, I was thinking using a tiny drill bit and makeing a hole in the intercooler just in front of where the lower hose attaches to the intercoller.
And you could always use a screw or something to plug it if you wanted. But I doubt the tiny hole would leak enough boost to affect the cars performance.
I could be wrong.
I still have another 10k kms to go before my first oil change, will have a better look then.
Old November 20th, 2013, 14:15   #5
bennybmn
That's how lots of small air compressors decompress the line between the head and the tank, a leak somewhere. That's also why mine takes FOREVER to hit 150 PSI... Something removable would be ideal, but a pain to do after every drive in the cold
Side note: What are some symptoms of icing?
____________________________________________
Euro Switch, Dual horns and powder coated Portos so far... TC off switch soon!
bennybmn is offline   Reply With Quote
Old November 20th, 2013, 15:01   #6
ebrobb
I had not even heard of this before, I did a quick search and came up with a whole bunch of threads on it, not sure how I missed it. But not looking forward to this as we are just getting into winter driving, what a PITA!!
I haven't had time to read much on it, but it seems the main problem is with the EGR being fed back into the intercooler....Can the EGR be shut off using VCDS??? I did this on my 01 so as to save the turbo and intake from being plugged with crap. But I'm sure the computer's are much more sophisticated now, and it's probably not even possible. Just wondering, I might have found the answer with more time to read up on it.
Maybe a winter front is the answer, keep the intercooler warmer, so as to keep the water vapor flowing thru.
Seems like it's been a known problem since 2010 or so, you would think VW would just hang the new parts on the new cars, without them having to be retrofitted on a case by case basis.
ebrobb is offline   Reply With Quote
Old November 20th, 2013, 15:06   #7
Softrockrenegade
Softrockrenegade's Avatar
Hard start , no start , worst case moisture forms or the ice melts and you take a slug of water into your engine causing hydrolock.
Softrockrenegade is offline   Reply With Quote
Old November 22nd, 2013, 11:16   #8
bennybmn
I had no problems last winter, and I was worried because there was SO much humidity after the blizzard with the ice melting off the roads, but this year is supposed to be colder too...
Old November 22nd, 2013, 17:15   #9
JBell
TDI(s): None
When inquiring with VWoA about our '12 TDI, they informed me that the vehicle had the modification needed to not worry about condensation build up in the intercooler.
I looked in the bay and unless they are doing something different than previous years, it looks exactly the same as all of the other unmodded ones.
JBell is offline   Reply With Quote
Old November 22nd, 2013, 17:36   #10
Revpeach
TDI(s): 2012 Jetta
Fuel Economy: 43
I have a '12 Jetta and when I pulled the IC hose to install my frost heater at 35k miles, the hose was perfectly dry. I went through all of last years WI winter without any problem. My car sits outside and not in a garage.
Revpeach is offline   Reply With Quote
Old November 22nd, 2013, 18:20   #11
Bigwhitebeast
Bigwhitebeast's Avatar
TDI(s): 2012 Jetta
I purchased my 2012 Jetta in May of 2012 so near the end of the model year and it did NOT have the updated intercooler set-up. My car gave me the hard start scenario after it was -17 degrees one day and in the 40's the next. The dealer said since it was running they wouldn't do the update I raised hell and they said they would do it just to keep me happy I haven't had an issue since but we haven't had the real cold weather either.
2012 Jetta TDI - commuter vehicle
2001 Dodge Cummins - 852 ft/lbs of torque
Bigwhitebeast is offline   Reply With Quote
Old November 22nd, 2013, 19:30   #12
tomo366
TDI Lifer
tomo366's Avatar
It is getting to be that time of year and these cars are a year older......expect to see a lot of this in the coming months
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old November 23rd, 2013, 12:31   #13
Savageman69
Savageman69's Avatar
no mk6 jettas come with anything to stop this....heck even the fix that they do after you push them for it doesnt work...i know mine still got water in it....mines fixed now and more fun lol
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler
Savageman69 is online now   Reply With Quote
Old November 26th, 2013, 09:49   #14
detroitmike
detroitmike's Avatar
i think it was 2micron that was working on a drain valve connected to the IC pipe that was easily accessable via an operating rod.
Power Service Diesel Fuel Supplement every tank
detroitmike is offline   Reply With Quote
Old November 26th, 2013, 12:02   #15
RDC98tdi
RDC98tdi's Avatar
Fuel Economy: Best Tank: 49.5 MPG, Best 80mi trip: 59mpg
Yup, there are at least 3 of these open in the top of this sub forum now. It's funny how no one reads the other discussions before posting
RDC98tdi is offline   Reply With Quote
intercooler icing on the A3? palewhitemale Audi A3 14 February 22nd, 2013 18:33
Best way to prevent intercooler from icing? tbone1989 TDI 101 36 February 15th, 2013 15:52
2010 Jetta Intercooler Icing Again!!!!! nukemech TDI 101 8 January 30th, 2013 13:54
Passat Intercooler Icing? TurboDieselPoint VW Passat Family (NMS and B7) TDIs (2012+) 9 December 13th, 2012 10:55
Intercooler Icing / Water buildup NickBeek VW MKVI-A6 Jetta Sedan (~ 2011+) 10 March 15th, 2012 22:55
Page generated in 0.17660 seconds with 10 queries
[Output: 127.38 Kb. compressed to 106.19 Kb. by saving 21.20 Kb. (16.64%)]
