Old November 14th, 2013, 14:21   #1
mimmik
Default 2010 JSW check engine/glow plug lights, codes P0045 & P0047
Hi to all - I searched the forum a bit and didn't come up with much (and am a bit of a TDI beginner anyway) so I'm hoping for some advice.
I have a 2010 JSW (manual & 34,150 miles and about 8 months after the 3yr warranty ended) and the check engine light and blinking glow plug light came on a few nights ago after driving for apx 30min. I was about a mile from home so kept going and noticed nothing different except for no 'oomph' - is that what is called limp mode? There is no real acceleration, though I didn't push it and I'm not driving it except back from the dealer and to another garage (about 2 miles).
With much grumbling, my local dealer agreed to scan it for free (they wanted me to pay $112 to scan it and diagnose) and they came up with codes P0045 & P0047. The tech was really nice and thought it might be a wiring/connection issue (i.e. chewed through by a rodent, etc), but of course couldn't really say for sure. I know the codes have to do with the turbocharger/solenoid from this site http://www.carobdcode.com/p0045-volk...ontrol-circuit, but it only talks about the CEL and not the blinking glow plug light. I did confirm both brake lights are working.
Anyone with similar experiences or have an idea of what it might be? I'm not excited about forking out a lot of $ now that the 3yr warranty is up, so I'm hoping whatever it is may still be under the 5yr warranty (my ignorance of car stuff shows here). The dealer said if the problem is wiring then it would not be covered. I have checked with the 2 nearby Colorado TDI gurus from your list (Anuthee and Frey's Foreign Cars) and they are both very booked, so I'd be without a car for a lot longer than I would be if the dealer worked on it. No good answer.
For some background in case it's related, they did replace my HPFP (twice) just over a year ago after I started hearing a strange sound (kind of a metallic 'whooshing/scraping' from the front end through the air vents), and since I bought the car new in 2010 I've had the repeated 'hiccup'/hesitation around 2000rpm, which I posted about a year ago or so. I still have both issues but have been told that they are likely just 'characteristics' of the car and are probably nothing.
Thanks and let me know if I can provide any more info and I will if I can!
mimmik is offline   Reply With Quote
Old November 18th, 2013, 18:15   #2
mimmik
Ended up having the dealer do a diagnosis today and they say they 'found a broken wire inside the wiring connector for turbo wastegate solenoid valve. They need to re-pin the wire into the connector housing. The estimate is $142.00 + taxes and shop supplies.'
Bummer that it is wiring since that isn't covered anymore. Bummer that a car that isn't even 4 yrs old already has a broken wire - how does that happen??
Am planning on letting them do the work unless anyone who happens to read this tonight and thinks otherwise?
Old November 18th, 2013, 22:58   #3
jahlov420
Fuel Economy: 45 mpg combo driving
i had the same type of thing happen. it was two tiny wires that went to this solenoid valve. one of them was broken. the part was about 10 bucks from the dealer and i did it myself.
p.s. my friend used to work there and they scanned it for free and the guy just told me what to do.
jahlov420 is offline   Reply With Quote
Flashing Glow Plug/ Check Engine Lights shiggs101 VW MKV-A5 Golf/Jettas 10 July 30th, 2015 20:05
Glow Plug and Check Engine lights question cdnalpina TDI 101 8 September 23rd, 2009 10:18
Check engine & glow plug lights, what does it mean? Karen Abse VW MKIII-A3/B4 TDIs 6 February 10th, 2006 07:52
Engine & Glow plug lights on dec942 TDI Power Enhancements 6 November 2nd, 2005 16:02
Glow Plug lights blinking and now Check engine Got Haggis? VW MKIV-A4 TDIs (VE and PD) 6 May 24th, 2004 10:26
Page generated in 0.12027 seconds with 10 queries
[Output: 59.88 Kb. compressed to 54.50 Kb. by saving 5.38 Kb. (8.99%)]
