Old November 14th, 2013, 13:55   #1
gearheadgrrrl
Fuel Economy: Other than the JSW, hard as I try, can't seem tio get below 40 MPH!
Thumbs up Consumer Reports: Golf most reliable TDI!?
'Twas paging through the december issue of CR at the library yesterday and starting on page 60 they had graphs of the various new cars predicted reliability. Now I hadn't seen the data broken down like this online, so I studied it intently, being as I'm in the market for a new one and debating between the current A6s and the coming A7s, with an outside chance of acquiring a Passat instead. The data is presented in bar graph form, so I dug out my little ruler and measured as best I can, and all these numbers are percentages of unreliability above (+) or below (-) that of the average new car.
Golf TDI: +15%
JSW TDI: +10%
Jetta TDI: -5%
Passat TDI: -20%
Hmmm... I could argue that German assembly quality is showing, but IIRC the JSW is built in the same mexican plant as the Jetta. Looking for more data, I looked at the results for the gas versions of these cars.
Golf gas: +35%
GTI gas: -55%
JSW gas: +20%
Jetta gas: +5%
Passat gas: no data
The relationships are pretty similar for the gassers, with the exception of the Golf beating the JSW by a bit wider margin. But the GTI is an outlier- Is the turbo TSI engine that unreliable?
After preliminary digesting of these stats, I'm tempted to believe that German assembly does yield a better product, and maybe I should grab an A6 Golf TDI before as A7 production will be moved to Mexico. Then again, the Mexican built JSW barely trails the German built Golf. Or is their a problem with the A6 Jetta sedan, being that it's recently evolved away from the Golf and JSW?
Discuss...
GearHeadGrrrl
gearheadgrrrl is offline   Reply With Quote
Old November 14th, 2013, 14:08   #2
Ski in NC
Fuel Economy: 48-52 typical
These numbers leave alot to be desired. I do not think they differentiate between major problems and minor problems. For example: If two Passats each had a failed cupholder, that would count worse than one JSW with a blown turbo. 2 vs. 1. So what counts as a hit against reliability? Honestly I don't know... It is not easy to boil down failure data into something that can be represented into a single bar graph. Car how old? Cost of failure? Car immobilized? Miles driven?
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old November 14th, 2013, 14:13   #3
bubbagumpshrimp
bubbagumpshrimp's Avatar
x2.I wonder if the -5% for the diesel Jetta is that the interior in these cars are absolute $h1t. i.e. People taking the cars into the dealership for complaints about various rattling items.
I would imagine that those numbers are simply the rate at which a given vehicle is taken to the dealership (not normal maintenance related) compared to the competition. Those numbers are really completely meaningless without the context that they were gathered (i.e. Minor issues like rattling are included).
bubbagumpshrimp is offline   Reply With Quote
Old November 14th, 2013, 14:39   #4
It may not be reliability per se, but if the car rattles, if accessories fail or give trouble, if something (like a fuel door or sunroof) doesn't work, it still requires a service visit and an inconvenience to the owner. So although reliability may not be the right term, it could be that Golf owners have fewer warranty visits to the dealer than other models.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old November 14th, 2013, 16:11   #5
Humanaquarian
Humanaquarian's Avatar
I tend to agree that German made Vdubs are of a better quality build than elsewhere. I had the Jetta, assembled in Mexico... Many many problems due to improper installation, wiring etc... My A6 Golf is a solid brick of awesomeness!!!
My History with VW
67' Bug
63'Ghia
2000 Jetta
2013 TDI
Humanaquarian is offline   Reply With Quote
Old November 14th, 2013, 18:51   #6
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I've noticed very little fit and finish differences between my JSW and Golf.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old November 14th, 2013, 21:54   #7
TDI2000Zim
TDI2000Zim's Avatar
Fuel Economy: 0.0 mpg
RELIABILITY is a design issue.
When a car is only made reliable in one factory, then there is something wrong with the entire design, including the production methods.
TDI2000Zim is offline   Reply With Quote
Old November 16th, 2013, 07:25   #8
AlcoC420
AlcoC420's Avatar
Originally Posted by gearheadgrrrl View Post
... JSW TDI: +10% ... JSW gas: +20% ...
This caught my eye and could be a result of sampling. The last time I looked, 85% of JSWs sold in North America are TDIs, leaving the gassers in a small minority. Perhaps the result is because there are significantly more TDIs sold, hence a greater likelihood of problems with them.
2010 Jetta Sportwagen TDI 6M
AlcoC420 is offline   Reply With Quote
Old November 16th, 2013, 08:17   #9
KonaJack
TDI(s): 2011 VW Golf
From everything I have read, the soon-to-be phased-out 2.5 gas engine is the most reliable in the VW stable. Probably because it is far less complex than the TDI and TSI engines. It is also far less expensive to manufacture so it helped VW keep prices down on the North American models it was used in. Unfortunately, it is substantially less fuel-efficient, which is the primary reason it is being nixed.
KonaJack is offline   Reply With Quote
Old November 16th, 2013, 08:53   #10
I think the 2.slow in the Jetta S is probably their most reliable engine.
Old November 16th, 2013, 10:01   #11
03_01_TDI
Banned
TDI(s): Na
Three types of lies:
Basic lie,
Damn lie, (you can keep your insurance plan)
And statistics.
Many variables at play from demographics of owners to which dealership sold more types of cars.
03_01_TDI is offline   Reply With Quote
Old November 16th, 2013, 11:13   #12
TDI2000Zim
TDI2000Zim's Avatar
That was damned funny !!!!!!!
But, I have the 'funny' feeling that we TDi owners are getting the 2nd Treatment from our favorite manufacturer.
I happen to think it is really Bosch'es Fault (wow, that sounds almost Freudian, but it ain't!!!), but as long as we are kept in the dark, Bosch may as well be the perfect hpfp manufacturer on God's Green Earth.
Old November 16th, 2013, 14:39   #13
Softrockrenegade
Softrockrenegade's Avatar
Those numbers don't make much sense from at least this forums perspective. The passat is in its third MY amd I have seen way less problems reported than golfs and jsw's
Softrockrenegade is offline   Reply With Quote
Old November 16th, 2013, 14:50   #14
showdown 42
TDI(s): 2012 touareg
I have concluded the CR reports aren't worth the paper they are written on. Saying a Jetta TDI and a Golf TDI are different in performance and reliability makes no sense,same engine same specs. If they are talking about other issues I might buy into it.
showdown 42 is offline   Reply With Quote
Old November 16th, 2013, 15:24   #15
RebelTDI
I have an MK5 (2010 TDI) and anMK6 (Hybrid). Both made in Mexico. I really like both cars, but the I have to agree that the interior of the MK6 is inferior to the MK5. My MK6 has the soft touch dash, but the rest is hard plastic and the fit and finish leave a lot to be desired. I already had the plastic door panel on the driver's side replaced because it was warped up above the window sill. There are other areas where the plastic trim does not fit well. Plus, there is a rattle or tapping sound from the rear passenger side that occurs depending on the road surface. Hopefully, they'll bring the quality up on the MK7s. Sometimes you don't appreciate fit/finish issues until you've had the car for awhile.
RebelTDI is offline   Reply With Quote
Consumer Reports review of 2015 Golf TDI in MT General VW Discussion 20 November 20th, 2013 07:25
Consumer Reports: MKVI Golf TDI TDInownow VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 16 February 4th, 2010 18:36
Consumer Reports bashes Jetta, Golf, New Beetle! 3030vision TDI 101 35 December 7th, 2004 13:11
New Consumer Reports favorable to Golf, TDI, Passat... blue909 General VW Discussion 7 March 11th, 2001 21:52
Consumer Reports Likes the Golf Karl Roenick VW MKIV-A4 TDIs (VE and PD) 24 November 28th, 2000 10:40
Page generated in 0.17281 seconds with 10 queries
[Output: 130.24 Kb. compressed to 108.84 Kb. by saving 21.40 Kb. (16.43%)]
