Old November 11th, 2013, 07:19   #1
bassman5066
Default My 1991 Golf Build Thread
OK, so lets start with a little background information on this car. It's not my daily, so I have given it the title "The Weekender". A friend of mine was the previous owner, and he just had a son, wedding, and honeymoon, so let's just say he needed the cash.
He did most of the grunt work to get the 1Z TDI swap up and running. Donor car was a 1996 Passat. He also deleted power steering and A/C :facepalm: when installing the motor. Timing belt was replaced, and had a fresh SBC stage 2 endurance clutch, and had BFI stage .5 motor mounts with a G60 trans mount. It had the stock Garrett turbo with a stage 3 Malone tune, PP764 nozzles, EGR delete, and Saab 900 FMIC.
Upon taking ownership, I replaced the MK2 fuel tank with a MK3 and got the proper sending unit in there to use the MK3 cluster. I also ran all new lines from the tank to the bay and installed an inline lift pump. I also replaced all the vacuum and boost lines, glow plug harness, and PCV tube. There were a few other odds and ends to be cleaned up to make this swap look nice. I also installed oil pressure, temp, voltage, boost, and EGT gauges. Because who doesn't love gauges?
Now for the bad. Within a week of ownership, the #3 injector bore started leaking compression, and I quickly found out there was a crack in the head causing this leak. I managed to get it to seal by torching the copper injector washer before torquing it down to get a little extra crush on it. This lasted me 6+ months of weekend driving, as well as a trip to NH and ME for TDIFest 2013. During that time, I also had a nice rear main seal leak that has been driving me crazy, and I also noticed oil pressure starting to wane. To the point that I switched to Rotella T3 conventional to keep the pressure in a comfortable range for my own peace of mind.
So, now that you understand "the bad", that brings me to my build. I had to replace/repair the head regardless, and I had to pull the trans (rear main seal) regardless. So, "while I'm there" has spiraled into a huge winter long build of my motor, a larger turbo, AWIC, and plenty of other goodies.
At TDIFest 2013
__________________________________________________ ____________________________________
Now, for my goals for this build:
Motor: The idea is, I want to build it to take whatever I can throw at it. Its a 1Z from a 96 Passat.
PD150(ARL) Pistons (19.0:1)
Rosten Rods
Eurospec block girdle (not sure on this one yet, would like some input)
New head with local machine shop P&P.
Stage 3 colt cam
PD Oil cooler
PD150 intake manifold
11mm IP
Still undecided on injectors (currently have PP764s, will probably start with them set for the highest pop setting)
Air/Water IC (from siliconeintakes.com)
Garrett GT2259 turbo (internal wastegate)
3" straight pipe exhaust (
I think thats it for now (I'm sure I'm forgetting something)
Transmission:
LSD and the "add a 6th gear" kit- will be coming later after the car is on the road..
02J shift tower and box
Will probably get dieselgeek short shifter eventually
Vehicle:
Restore A/C and power steering
Restore cruise control
Swap front end to quad round
Battery and washer fluid in trunk
Shave bay complete with paint
Complete custom harness and wire tuck in bay
5 lug conversion from MK3 VR6 front and rear brakes
SS brake lines
Get rid of my junk Raceland Coilovers
Install upper strut bar
Upgrade sway bar - VR6
Install BFI rear beam brace
Rear beam poly inserts
Turbo, manifold, and my 90 degree T3 adapter.
Turbo is Garrett GT2259, and is an OEM variant from a HINO 5.0L heavy equipment engine. - $740 shipped
Manifold was a generic 8V VW manifold from eBay - $75 shipped
T3 adapter was designed by me and manufactured by eMachineShop.com - $50
These pics also show the porting required to get a nice smooth transition from the manifold through my adapter into the turbo.
Old vs New turbo
T3 vs OEM manifold port size
The MK2 Golf 1Z build thread
bassman5066 is offline   Reply With Quote
Old November 11th, 2013, 07:20   #2
bassman5066
11/10/13
Pulled the motor:
How she will sit for the winter
Lots of odds and ends removed
Old November 11th, 2013, 07:20   #3
bassman5066
I was really happy to find out that despite my rear main seal leak, the clutch was dry. Not sure if I'm going to reuse. It only has 15k on it at most.
Look at that cute little turbo.
Lots more to come. I will keep the thread updated. Any input is appreciated.
Old November 11th, 2013, 08:47   #4
oldpoopie
oldpoopie's Avatar
Why go waste-gate turbo if you are using a pd150? How will you control it?
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old November 11th, 2013, 08:57   #5
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
He is using PD pistons in a 1Z
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old November 11th, 2013, 08:58   #6
darkscout
Grammar Scout
darkscout's Avatar
TDI(s): 2003 Golf
The only thing that is PD150:
PD Oil cooler
Everything else is 1Z/AHU.
[Review]: ECS Mk4 Rear Hatch Pop Kit. 0/5 stars for Rear Hatch Popping. 5/5 stars for inflicting head trauma.
It's all just cheap chinese **** with a fancy vortex bling bling spin that attracts people
darkscout is offline   Reply With Quote
Old November 11th, 2013, 09:00   #7
bassman5066
PD150 pistons and manifold. Block, head, fuel system, and computer is 1Z so boost will be controlled by the N75 and a mechanical boost controller.
Why go waste gated? Why not is what I have to say to that. Short answer is top end flow.
Edit: Thanks to Chris (GTiTDI) for inspiring me to think outside the vanes
Sent from my XT1080 using Tapatalk
Old November 11th, 2013, 09:02   #8
GTiTDi
GTiTDi's Avatar
Originally Posted by bassman5066 View Post
why go waste gated? Why not is what i have to say to that. Short answer is top end flow.
Sent from my xt1080 using tapatalk
:d
MK2 GTI build
schnellsnailFB
Old November 11th, 2013, 09:11   #9
oldpoopie
oldpoopie's Avatar
Blaasdhuujdjjhhhhhhhh............
Thats what my brain did up there..... I get it now.... Boy i need to read more carefully.
Still though, why not upgrade to vnt control like frankencar did with his BV43
Old November 11th, 2013, 09:18   #10
GTiTDi
GTiTDi's Avatar
why not upgrade to vnt control?
MK2 GTI build
schnellsnailFB
Old November 11th, 2013, 09:30   #11
bassman5066
Lol yes, the sheeple.
Theres a reason I went with this HINO OEM variant of the GT2259. Garrett's off the shelf aftermarket version of the 2259 has a .56 A/R turbine and the HINO has a .47 so I'm hoping to retain low end response that way rather than switching to VNT.
Old November 11th, 2013, 10:08   #12
oldpoopie
oldpoopie's Avatar
Old November 11th, 2013, 11:38   #13
darkscout
Grammar Scout
darkscout's Avatar
TDI(s): 2003 Golf
Then why not ask him why he's not adding a DPF or Urea injection. VNT helps with some things but there's something to be said about the reliability and simplicity of a WG.
Old November 11th, 2013, 12:00   #14
GTiTDi
GTiTDi's Avatar
exactly, VNT is more of an emissions device to limit smoke output IMO, and is by no means the best for high performance flow...
MK2 GTI build
schnellsnailFB
Old November 11th, 2013, 12:05   #15
bassman5066
Yea. My aim is to have it spool almost as fast as a 2260V but be able to flow more exhaust on the top end of the RPM section.
Edit: Chris I just saw your comment. I'm sure you know I don't care about smoke with this build.
MKIV Golf Audio Build Thread Farfromovin Upgrades (non TDI Engine related) 52 November 11th, 2015 20:25
Dieselpower04's Golf TDI build thread dieselpower04 Golf TDI Picture Gallery 185 October 17th, 2013 12:24
golf accident repair /build thread g2beater Upgrades (non TDI Engine related) 9 April 23rd, 2013 07:19
my 2011 golf tdi 4 door 6 speed build (?) thread k0mpresd VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 July 5th, 2012 21:44
My Golf GT TDI Build Thread dieseldragon VW MKIII-A3/B4 TDIs 0 October 13th, 2010 11:29
Page generated in 0.18241 seconds with 10 queries
[Output: 145.42 Kb. compressed to 123.41 Kb. by saving 22.01 Kb. (15.13%)]
