Old December 5th, 2017, 18:47   #16
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Originally Posted by ashu View Post
Peak Blue Def is ISO 22241 but generic walmart DEF is not
Sez who?
Adblue and DEF are one and the same. Brand doesn't matter. DEF is made to an ISO standard (ISO 22241) and is a commodity item and used worldwide. I buy my DEF at my local Walmart* store and have used enough over the last few years to cover over 120k miles of driving.
Bottom line is DEF is DEF is DEF is DEF... is DEF.
Originally Posted by VeeDubTDI
It's all the same stuff. You can use any DEF (diesel exhaust fluid) or AdBlue in your diesel with SCR. The cheapest place is on the pumps at truck stops... generally around $2.50/gallon or less.
What VeeDubTDI said.
I recommend not using bulk DEF fill pumps at truck stops and only fill from an AdBlue bottle or fill from a 2.5 gallon jug with a funnel. What I like to do is fill once from a 1/2 gallon AdBlue bottle and then cut a hole in the bottom of the bottle and use it as a custom funnel to fill from a 2.5 gallon jug of DEF.
The issue with filling from a bulk fill pump at a truck stop is the DEF tank can get damaged from the "water hammer" effect upon the tank going full. DEF gets blown out through the air stone vents when the tank gets full and the vents can get clogged after the DEF crystallizes as it dries up. The tank then gets collapsed and cracked during the next DEF pump-out by the SCR system. Gravity filling with an AdBlue bottle or 2.5 gallon jug with a funnel is safe to do.
BMW dealers have been replacing cracked DEF tanks under warranty because of dealers using bulk fill pumps until BMW issued a Service Information Bulletin (SIB) warning not to do a DEF fill if the level in the tank is above a certain level. The bottom line is only gravity fill with an AdBlue bottle or 2.5 gallon jug with a funnel. I DIY all DEF fills in my BMWs.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old January 1st, 2018, 13:42   #17
cruisin
cruisin's Avatar
TDI(s): 2006 Jetta
Fuel Economy: 2 wheels or four?
At what point will the warning light stop flashing.? We just stopped by a Walmart and added a about a half gallon after having the light come on while going home from vacation.
1979 BMW R80S
1985 Honda Rebel 250
1986 Honda Rebel 450
2000 BMW R1200C
2000 BMW R1100RT
cruisin is offline   Reply With Quote
Old January 1st, 2018, 15:15   #18
scooperhsd
If the car was telling you that you had 1500 miles (or so) of DEF , you should fill it. When I did my own first fill, I bought the .5 gallon bottle and a 2.5 gallon at VW - after I emptied the bottle, I cut the bottom off and used it as a funnel for the 2.5 gallon. This time, I just bought the 2.5 gallon Peak at Walmart and filled it up with my funnel.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old January 1st, 2018, 15:44   #19
tomo366
TDI Lifer
tomo366's Avatar
When someone with a Vag com or VW Machine hooks up a machine and resets it
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old January 1st, 2018, 16:13   #20
scooperhsd
No - What I said - you just have to put in "enough" DEF. .5 gallon will not do it.
Old January 1st, 2018, 16:43   #21
bizzle
bizzle's Avatar
I tried filling from a 2.5g jug and it was more of a pain in the butt than I want to deal with. I used the adapter filler from idparts. If someone wants to buy it for like $15 bucks PM me because I'm just going to do 1/2 gallon at a time which is easier on my wrists.
bizzle is offline   Reply With Quote
Old January 1st, 2018, 17:57   #22
cruisin
cruisin's Avatar
TDI(s): 2006 Jetta
OK. made it home but never shut the engine off just in case. Once home I filled the additive tank completely full, then followed the procedure in the manual of turning key on and waiting 30 seconds before restarting. still have orange flashing wrench with dripping bottle above it.
When the warning first appeared today, I didn't look down in time to see the mileage it said until no restart. The second time I was ready for it; it said 500 miles to no restart, then 450 then 400-350-and finally 300. We are home and I will be calling dealer 45 miles away tomorrow. The car starts but still with the blinking warning lights.
just a point of reference; this is on a 2015 Passat TDI.
1979 BMW R80S
2000 BMW R1200C
2000 BMW R1100RT
Old January 1st, 2018, 21:34   #23
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
Note to self... never buy a car with this crap system in it.
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old January 2nd, 2018, 02:46   #24
cruisin
cruisin's Avatar
TDI(s): 2006 Jetta
yep. Once this episode is cleared up I will be looking to get rid of the Passat. It totally pisses me off that manufacturers design in this kind of BS just so they can make more money on service and parts. The Can Am Spyder we bought earlier this year is the same way and may also get dumped off quickly along with the Passat.
I've owned a 2004 Pontiac Vibe since spring of 2009 and have yet to have problem with it other than replacing front wheel bearings. But at 195K miles something is going to wear out. I've also owned several BMW motorcycles since April of 2000. Now, with over 330K miles behind me on those, I have only had one major parts failure. The final drive on my R1200C began leaking at the seal. It seems the main bearing had begun to come apart and caused the seal failure. I parked it, bought parts for about $150 and rebuilt it myself in about 4 hours. That occurred at 112K, proof that quality manufacturing can be accomplished without all the BS some companies are pulling just to make more service dollars. This will be the last VW I ever buy and I will make sure as many as possible know of the problems that can come with them; hopefully before they waste their money on one.
1979 BMW R80S
2000 BMW R1200C
2000 BMW R1100RT
Old January 2nd, 2018, 04:44   #25
scooperhsd
Wait for a couple years and you'll need to do this on your gas cars as well....
It's called MAINTENANCE - I suppose you never read your owner's manual to see what was needed. Other modern diesel vehicles also have this need for DEF. If you want to blame anyone - blame CARB for emission standards that required the manufacturers to have to use this to meet the standards.
Old January 2nd, 2018, 06:27   #26
cruisin
cruisin's Avatar
TDI(s): 2006 Jetta
Our service writer made a strong point when I took it in for the thirty day check up after purchasing it in early September. He said the system would tell us when there was 1500 miles to go and to get it taken care of as soon as possible after seeing that. The damn thing didn't sound off or light up until 550 miles to the no start notice. This happened on New Years Day and the only thing open was Wallyworld. Luckily, we were only about 250 miles from home and it would still restart after I filled the additive tank and followed the procedure in the manual. It still won't stop flashing the warning though. I'm thinking if they can't get a fluid sensor and warning system right, what else did they get wrong.
1979 BMW R80S
2000 BMW R1200C
2000 BMW R1100RT
Old January 2nd, 2018, 07:01   #27
tomo366
TDI Lifer
tomo366's Avatar
No problems here.....except on the 30K Service VW spilled Def all over inside the trunk.....
I do it myself now
Old January 2nd, 2018, 10:58   #28
scooperhsd
I'd call it a one time problem. At least you did listen to your service advisor and put SOME DEF in when you did see a warning on it. It's possible that your DEF heater has malfunctioned as well and that could explain part of why it didn't register at 1500 miles. Regardless you are correct to get it to the dealer to find out what is wrong.
My 2015 Golf hasn't had an issue with adding DEF - if there was a systemic problem affecting lots of cars, you would see it on here. As I said - I think your car does have a problem, but it is not very widespread.
Old January 2nd, 2018, 11:07   #29
tomo366
TDI Lifer
tomo366's Avatar
if you want a new model Diesel car in the USA from now on you will have to deal with an SCR system! it is a fact of life these days!!
Old January 3rd, 2018, 18:51   #30
tdidieselbobny
tdidieselbobny's Avatar
A few weeks ago my dash dinged and it said add adblue-1500 miles till empty(or whatever it says). I added 3 gallons and all was well-no more reminders,etc..... till this morning. Started car up, it dinged again,but now it said 600 miles till no start. This was on my way to work,so after work I stopped by WalMart and bought a 2.5 gallon jug of the Peak DEF and a gallon of the Supertech DEF. I opened the 2.5 gallon jug in parking lot and put spout on and started to put it in. After maybe 30 seconds,it splashed out of the filler hole,I added maybe a quart total. So I get in car and do what manual says,30 seconds after hitting button I start it and the yellow exclamation mark is still in dash,along w/ maintenance wrench that goes out. Drive home after a couple more stops and the yellow exclamation point goes out. I start car up tonight and no reminders or exclamation marks come on dash, so keeping fingers crossed.
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 30k miles....'16 Kubota BX1870 MMM/FEL, 178hrs!And now an '03 Jetta TDI 5spd w/ 427k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
VAGCOM/VCDS Info needed for 2011 Audi Q7 DEF (AdBlue/ DrSpalding TDI (Diesel) Emissions 3 August 21st, 2014 17:38
Gumout Pro DEF fluid Tigerpb TDI (Diesel) Emissions 3 November 1st, 2013 17:13
DEF spill at dealer silvrmax04 VW Passat Family (NMS and B7) TDIs (2012+) 45 May 15th, 2013 01:15
VCDS (VAGCOM) and AdBlue/DEF/SCR level information DrSpalding Audi SUVs (Q7 & Q5) and other V6 TDIs 0 November 30th, 2012 13:13
AdBlue/DEF... CalDrvr Fuels & Lubricants 35 November 25th, 2012 18:45
Page generated in 0.17803 seconds with 10 queries
[Output: 136.58 Kb. compressed to 114.40 Kb. by saving 22.18 Kb. (16.24%)]
