Old November 7th, 2013, 17:08   #1
Diesel126
Default Adblue vs Blue Def
Is VW Adblue the same as blue def? The dealer is telling me that using anything but VW Adblue could damage the Adblue system causing engine light and or Adblue system failure. The blue def I am using has the same ISO standard that is listed on the VW Adblue tank. The car is in for repair for this reason and the dealer is telling me that someone put water in the tank or a low grade Adblue.
( blue def) The car runs fine just getting the count down to not restarting.
2011 Touareg TDI
Diesel126 is offline   Reply With Quote
Old November 7th, 2013, 17:46   #2
40native
There's a lot of difference in the quaility of the DEF fluid out on the market but as long as you're buying a good quaility ISO certified DEF in a sealed container you should be fine. Contamination is the biggest issue with DEF. VW can only deny warranty strictly related to the part failed so if like your HHFP went out they can't use DEF as an excuse to deny warranty of a totally un-related part.
40native is offline   Reply With Quote
Old January 11th, 2014, 22:55   #3
MichaelB
Sez who?
MichaelB is online now   Reply With Quote
Old January 11th, 2014, 23:15   #4
kydsid
TDI(s): 2012 Passat
Option 1: Dealer Service Advisor is up selling for the Parts Counter. A slimy tactic at best and one that borders on fraud depending on what is said.
Your are correct about the ISO standard. Def is mostly water in the first place and degrades over time.
Option 2: they are telling the truth. But I'd ask them what proof they have. Ask them for their lab report that states the def is out of spec.
504/507 Oil retail source list - http://forums.tdiclub.com/showthread.php?t=360912
kydsid is offline   Reply With Quote
Old January 11th, 2014, 23:27   #5
MichaelB
Thank-you
Old January 12th, 2014, 00:14   #6
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
If the vehicle is still under warranty, ask if they opened a VTA with Techline?
It is a pretty common issue for the DEF to freeze if the temperatures are at or below 10*
If it freezes, this could cause the problem you are explaining. Then when they take the vehicle into the shop, the AdBlue thaws and they never take that into account for the diagnosis.
Fixmy59bug is offline   Reply With Quote
Old January 15th, 2014, 12:55   #7
bonno
Where can I buy good quality DEF that is not AdBlue? I am in Seattle area and looking for a major Consumer to sell it. My dealer only sells half gallon bottles (i think that is the size).
bonno is offline   Reply With Quote
Old January 15th, 2014, 12:57   #8
compu_85
Gadget Guy
compu_85's Avatar
All the parts stores near me (Autozone, Advance, CarQuest, etc) have it.
-J
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
Past:
Old January 15th, 2014, 16:22   #9
N41EF
Walmart sells DEF in a 2.5 gallon "box". Same stuff at the LAPS.
2009 MB ML 320 Bluetec
Gone Diesels: 2011 Golf TDI turned in 12/8, Beetle,2001 Beetle, 1983 MB 240D
N41EF is offline   Reply With Quote
Old January 15th, 2014, 17:49   #10
waltzconmigo
TDI(s): none
are def and adblue different? i was under the impression that they were both just generic names. ???
ciao,
waltz
waltzconmigo is offline   Reply With Quote
Old January 15th, 2014, 17:51   #11
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
It's all the same stuff. You can use any DEF (diesel exhaust fluid) or AdBlue in your diesel with SCR. The cheapest place is on the pumps at truck stops... generally around $2.50/gallon or less.
Trusted TDI Mechanics Map || TDIClub Chat
Old December 1st, 2017, 17:36   #12
ashu
TDI(s): Passat 2012
Fuel Economy: 37 combined
Peak Blue Def is ISO 22241 but generic walmart DEF is not
ashu is offline   Reply With Quote
Old December 2nd, 2017, 06:31   #13
hskrdu
I didn't know that! Any solution to this? I'm surprised I haven't seen more posts about it from our members in the frozen tundra.
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is offline   Reply With Quote
Old December 2nd, 2017, 07:39   #14
compu_85
Gadget Guy
compu_85's Avatar
Yes, it is. That's why the tank includes heating elements.
-J
Present:
Past:
Old December 2nd, 2017, 09:50   #15
joetdi
https://www.jmesales.com/commonly-as...ust-fluid-def/ This is info on DEF. It does freeze if it gets cold enough and is normal.
joetdi is offline   Reply With Quote
VAGCOM/VCDS Info needed for 2011 Audi Q7 DEF (AdBlue/ DrSpalding TDI (Diesel) Emissions 3 August 21st, 2014 17:38
Gumout Pro DEF fluid Tigerpb TDI (Diesel) Emissions 3 November 1st, 2013 17:13
DEF spill at dealer silvrmax04 VW Passat Family (NMS and B7) TDIs (2012+) 45 May 15th, 2013 01:15
VCDS (VAGCOM) and AdBlue/DEF/SCR level information DrSpalding Audi SUVs (Q7 & Q5) 0 November 30th, 2012 13:13
AdBlue/DEF... CalDrvr Fuels & Lubricants 35 November 25th, 2012 18:45
Page generated in 0.17308 seconds with 10 queries
[Output: 128.21 Kb. compressed to 107.31 Kb. by saving 20.90 Kb. (16.30%)]
