Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old November 6th, 2013, 05:31   #1
dp653
Fuel Economy: '05 gets 33/40, '10 around 43
Default Looking for a Turbo Actuator for a BEW engine w/stock Borg Warner kp39 Turbo
Long story short, my 2005 TDI Jetta wagon has needed a bit more babying since I bought it in June than I'd like to put into a car right away but, I really love it and know that it's a solid vehicle it's just... about that time in it's life (177k miles) some bigger problems start to surface. Or so that is what I am telling myself.
The Borg Warner Actuator that comes stock with my vehicle is not sold separately. If anyone knows of where I might be able to find a used one in good condition I would look like this guy -> for weeks.
Sorry for the double post between here and the private parts for sale forum. Can't seem to figure out how to delete this thread. Oops
dp653 is offline   Reply With Quote
Old November 6th, 2013, 06:56   #2
r90sKirk
r90sKirk's Avatar
yes, it is sold separately see link -
http://www.idparts.com/catalog/produ...oducts_id=2054
Honest TDI Enthusiast Performing Competent TDI Work
2013 Passat TDI SE 151k Opera Red, 2000 Golf TDI 461k Bright Green, 2015 GSW (6MT) Pure White 49k, 1977 BMW R100RS 166k Silver Ice,
r90sKirk is offline   Reply With Quote
Old November 6th, 2013, 07:26   #3
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Quote from the idparts product description:
"Please note that this WILL NOT FIT the Borg Warner KP39 Turbo that's OE on the BEW engine, or the BRM turbo."
-George Bernard Shaw
Old November 13th, 2013, 20:48   #4
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I have a good used one. $100 bucks.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old November 18th, 2013, 23:38   #5
Matt-98AHU
Matt-98AHU's Avatar
It will fit... with some modifications. I've done it before. Not that fun.
It involved removing the Garrett-style adjuster from the new actuator rod, then using a coupler nut and two jamb nuts along with a threaded rod (all 6mm x 1.00) to extend the actuator rod. Then two more jamb nuts to tighten against the VNT lever on the turbo.
Then take the old actuator and bracket out and drill out the spot welds holding the actuator to its bracket. Drill new holes as needed to line up with the two studs on the Garrett actuator, use two nuts to fasten it to the bracket. Install assembly on turbo and use your a mityvac to adjust the actuator as needed...
I've done it before with good results. It also takes almost as much time as it would to just replace the whole damn turbo :P
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old November 24th, 2013, 14:27   #6
dp653
This is what I've heard, if I knew how to do it myself I'd do it for the cost savings alas, I do not. Thank you for the response!
Borg Warner KP-39 turbo off 2005 BEW ctnatureboy Private TDI Items for Sale/Wanted 2 March 3rd, 2013 12:51
Borg-Warner Turbo info from factory 87homebuilttdi TDI Power Enhancements 10 October 3rd, 2011 13:02
Borg-Warner KP39 Turbocharger (A4-BEW) 3hone Ontario 8 June 28th, 2010 19:51
FS: Stock BEW Turbo - KP39 2004 hobbyshop Private TDI Items for Sale/Wanted 1 September 1st, 2008 11:22
Borg Warner KP39A Turbo??? Sootman TDI Power Enhancements 1 September 27th, 2004 03:36
Page generated in 0.13435 seconds with 10 queries
[Output: 78.77 Kb. compressed to 69.11 Kb. by saving 9.66 Kb. (12.27%)]
