Old November 3rd, 2013, 20:18   #1
Turbo_Boss
Turbo_Boss's Avatar
Default Jetta MK4 ATF oil dilema
Hello guys,
I really appreciated your help.
I have a 2002 Jetta MK4 1.8T Automatic Transmission with 60,000kms and I going to change the Transmission filter and fluid.
VW Jetta specs for my ATF oil are VW G 052 162 or VW TL52162
I was checking the LIQUI MOLY brand and found two ATF that meet this specs
Top Tec ATF 1200 and Top Tec ATF 1200G The one with the G say: Top Tec ATF 1200 yellow
Here are the PDF Specs
Top Tec ATF 1200
http://www.liqui-moly.de/liquimoly/m...%201200_EN.pdf
http://www.liqui-moly.de/liquimoly/m...0yellow_EN.pdf
So my question is whats the difference? One is Yellow color and the other is Red. Whats your advice?
Also, has any of you has use this ATF Brand? Any advise?
THX,
Isaac
Turbo_Boss is offline   Reply With Quote
Old November 3rd, 2013, 20:55   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Any ATF, be it from VW, LiquiMoly, Pentosin, etc., etc. that meets the spec should be okay. However, you should try www.vwvortex.com. as this is a TDI website and the last time I checked, the 1.8T was a gasser, not a diesel.
-George Bernard Shaw
Old November 3rd, 2013, 21:20   #3
Turbo_Boss
Turbo_Boss's Avatar
Hello 1854sailor,
Thx for your reply. Here in my country nobody sells Pentosin. I can Get Castrol, Penzoil, Motul and Liqui Moly.
I decide to post here in order to get expertise help regarding the best ATF oil for my transmission and I am pretty sure that even that my car is a gasser, it use the same automatic transmission as the the one on the MK4 TDI.
Again, thank you for your time and help.
Cheers,
Isaac
Old November 3rd, 2013, 22:36   #4
Lensdude_com
Lensdude_com's Avatar
Fuel Economy: 50 mpg average (Imperial)
I found LiquMoly Top Tec 1200 Synthetic ATF: For models with 01M 4-speed automatic transmission*** Special synthetic transmission fluid, meets specifications of VW/Audi part number G052162 as required for this model. 1 Liter bottle. 3.0 Liters of fluid required for filter change, 5.3 Liters are required for a dry fill. $13.25 at German Auto Parts dot com
Lensdude_com is offline   Reply With Quote
Jetta 2002 Mirror dilema Hobhancock Private TDI Items for Sale/Wanted 4 June 3rd, 2006 12:34
Brake Dilema/Timing Belt Dilema jjr VW MKIV-A4 TDIs (VE and PD) 14 May 24th, 2005 07:31
Oil change dilema Fluid137 TDI 101 14 November 9th, 2004 02:31
First oil change dilema Dieter Fuels & Lubricants 8 July 16th, 2001 02:45
Jetta oil & ATF question jettajim VW MKIV-A4 TDIs (VE and PD) 4 June 21st, 2000 05:22
Page generated in 0.12361 seconds with 10 queries
[Output: 65.71 Kb. compressed to 58.79 Kb. by saving 6.92 Kb. (10.52%)]
