Old November 1st, 2013, 12:27   #1
RikAmirnov
Banned
TDI(s): 98 Käfer
Default Bad mileage ?
Im getting roughly 34 MPG[800km/55L] ( city/hwy combo) why so bad ?
99.5 ALH MT
regular service no CEL, Fresh new intake, tuned, no EGR, Nice tyres,
any advice ?
RikAmirnov is offline   Reply With Quote
Old November 1st, 2013, 12:34   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
How much of each city / highway? Does the engine get up to temp? First time going into winter with a TDI?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old November 1st, 2013, 14:24   #3
RikAmirnov
Banned
TDI(s): 98 Käfer
First official winter,
I let it warm up 10mins before going anywhere unless its warm from a previous drive,
60/40 city/hwy and when its on the highway no more than 75km at a time
Old November 1st, 2013, 15:00   #4
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
What MPG were you getting before?
TDIs get less MPG in cooler weather. There's no need to idle, startup, wait a minute or so and drive gently until it's warm. I assume in your city driving the engine gets up to temp? How many minutes or km of city driving each day?
Old November 1st, 2013, 15:21   #5
cleaver
cleaver's Avatar
How are you measuring your fuel consumption? are you venting when you fill up?
Diagnosing Limp Mode
IMO, best place to buy VW parts in Canada: contact Brian @ www.roselandtech.ca
cleaver is offline   Reply With Quote
Old November 1st, 2013, 19:42   #6
RikAmirnov
Banned
TDI(s): 98 Käfer
I am has removed the vent , but i pour slowly and wait for the foam ( if any) to go away
fuel consumption number of Litres filled /KM driven ( from ODO)
Timing is retarded , as for previous consumption about the same but it was before my overhaul filters,intakes, tuning...
until 3/4 tank i get 350km after 850km once light turns on
Old November 1st, 2013, 23:55   #7
jay_fyp
jay_fyp's Avatar
Get a frostheater, you'll have close to operating temperature right when you start the car. This greatly improves your mpgs in the winter especially and even can be used in the summer. I installed one a few days ago and the mpg gain was/is significant.
2013 Golf
2004 Golf
jay_fyp is offline   Reply With Quote
Old November 2nd, 2013, 12:06   #8
mrcowden
^^^ +1 What jay_fyp said. ^^^
When I plug in my FrostHeater, I get mileage very close to the summer numbers. Without it, I'm usually down about 10-18% depending on how far I drive. Thinking of adding an oil pan heater so it has plenty of oil flow at cold starts as well.
mrcowden is offline   Reply With Quote
Old November 2nd, 2013, 18:10   #9
MichaelB
Fuel Economy: very good
[QUOTE Thinking of adding an oil pan heater so it has plenty of oil flow at cold starts as well.[/QUOTE]
You are probably using a full synthetic oil I hope. Don't worry about oil flow from cold starts unless you live in Antarctica.
MichaelB is online now   Reply With Quote
Old November 3rd, 2013, 14:50   #10
naturist
#1, letting it warm up for 10 minutes before driving is part of the problem, not part of the solution. Firstly, it won't warm up much at all just sitting there idling, and second, you are getting ZERO Km per liter, aka infinite liters per 100 Km while it is sitting there idling.
#2, you are no on winter diesel, which is going to increase your liters/100 Km usage by about 10% all by itself.
#3, city usage is hard on the fuel usage. Diesels are best cruising for long distances.
#3b, city usage involves time spent in low gears, sitting at traffic lights, and applying the brakes frequently, all of which waste fuel. Which is why city is hard on fuel usage.
#4, do you make many short trips? Doing so also kills fuel usage because the engine and driveline do not get a chance to heat up properly. During the cold drive, it uses more fuel. Another reason longer drives are better.
2001 Green Jetta TDI
2005 Khaki Jeep Liberty CRD, now deceased
2012 BMW X5 35d
naturist is offline   Reply With Quote
Old November 3rd, 2013, 15:29   #11
BlankThis
BlankThis's Avatar
Fuel Economy: suck, squeeze, bang, smoke
How hard have you been driving? Diesels are great that you can drive them hard and still get great mileage but if you always have your foot in it, your numbers will drop.
[360k] - | GT1749VB | DLC764s | Southbend Stage 3 daily (soon) | WIX 24770 + CAT 1R7050 | DG Sigma 5 | 25th anni. e-codes | W8 console | NewSouth boost gauge | Koni Yellows/SRT.Ts w/ Neuspeed Sport springs | 1.8T pancake (soon) | PD150 intake w/ racepipe (soon) |
BlankThis is offline   Reply With Quote
Bad Mileage until unplugging battery, after 1 tank, bad again IDoSeaDoo VW MKIV-A4 TDIs (VE and PD) 45 December 23rd, 2013 08:07
bad mileage again.. any one else? Andrewh VW MKV-A5 Golf/Jettas 125 February 20th, 2009 08:58
Bad mileage MooseWagen 22 TDI 101 6 December 31st, 2007 19:26
Can a bad fuel cutout valve cause bad mileage?? TDikook TDI Fuel Economy 0 August 19th, 2003 01:54
Newbie with bad bad mileage... OrangeGrl TDI Fuel Economy 15 May 28th, 2003 21:28
Page generated in 0.17200 seconds with 10 queries
[Output: 102.90 Kb. compressed to 87.19 Kb. by saving 15.71 Kb. (15.27%)]
