Old October 29th, 2013, 18:52   #1
phaser
Fuel Economy: 50 MPG B-20
Default VCDS Port Test - CAN Not Ready
I'm trying to help a friend in Arkansas, 2004 Jetta TDI
See this thread: http://forums.tdiclub.com/showthread.php?t=398332
I shipped my genuine VCDS cable to him, and tried to assist over the phone tonight. He has the latest VCDS software, and running Windows 8.
When he does the port test, K1 OK, K2 OK, CAN Not Ready
Went ahead and selected his vehicle, and tried to scan for codes with auto function, and return message is: Function not supported by gateway.
So any ideas with what's going on with the VCDS and this car?
2004 Jetta BEW 5M - 490k - 50 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old October 29th, 2013, 22:49   #2
tadawson
Not a CAN bus car perhaps?
- Tim
tadawson is offline   Reply With Quote
Old October 29th, 2013, 23:04   #3
JSWTDI09
JSWTDI09's Avatar
Correct, a 2004 (Mk4) Jetta is not a CAN bus car. The error message about "K1 OK, K2 OK, CAN Not Ready" is correct and normal. When doing the autoscan he cannot do the "auto detect" because that only works on CAN bus (2005.5+) Jettas. He has to open the drop down box and choose his car/engine (a Jetta with an ALH engine) before he starts the autoscan. If this is what he did, I'm not sure what is wrong. One thing to try would be to try accessing individual controllers one at a time instead of an autoscan. You might learn something.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old October 30th, 2013, 02:55   #4
phaser
UPDATE
I assumed it was a North American Jetta and had him use 9M-Jetta IV as the chassis type from the drop down box.
I just ran his VIN number, it was built in Wolfsburg, Germany.
So the correct chassis type is 1J - VW Golf/Bora IV
Now able to scan.
Thanks for the replies.
Air Filter - EaA208
Old November 1st, 2013, 15:16   #5
wmgeorge
Fuel Economy: 32/47
I just got done using my VAG Scanner (official) for the first time. It was driving me nuts, it would test the USB port and connect one time and then lose the connection. Nothing in the instructions state that the green LED should be flashing to Red and back when its communicating correctly. But after I firmly pushed the connection into the car plug it started doing the flashing on and off, worked fine afterward.
Got the IQ adjusted and then changed the door locks to manual and then to unlock the car when the key is removed....Yeah!!!
The IQ was at 1.2 adjusted to 2.2 and my stuttering (sp) on slow down to idle went away.
Retired, Too many hobbies not enough time!
wmgeorge is offline   Reply With Quote
Help with VCDS test heartlandcycle VW MKIV-A4 TDIs (VE and PD) 2 September 10th, 2011 15:49
Express Card RS232 serial port for vcds BobZ OBD Scanners 5 June 29th, 2011 19:13
Not ready for ODBII test--Can vagcom help? dr_bartolo TDI 101 4 August 10th, 2007 15:48
No comm. at test port? can I get codes manually? cruciform VW MKIII-A3/B4 TDIs 6 January 24th, 2005 20:07
no reading from test port? can I test - test port? cruciform VW MKIV-A4 TDIs (VE and PD) 1 January 18th, 2005 10:03
Page generated in 0.13806 seconds with 10 queries
[Output: 73.05 Kb. compressed to 64.53 Kb. by saving 8.53 Kb. (11.67%)]
