Old October 27th, 2013, 20:44   #1
Btonns
TDI(s): 2006 Jetta
Arrow Annoying brake problems
I am new to the forums. I have a 2006 Jetta TDI with 125k. I just had my mechanic replace the outer cv joint boots.
My front brakes were squeeking, so I had the rotors turned (before I knew VW rotors should not be turned). Also, I scuffed up the front pads with 400 grit sandpaper. I used silicone anti-squeal on the back of the pads. The squeeking went away for about 30 mins.
I ordered new Textar pads and rotors suggested by id Parts. I throughly cleaned the new rotors with brake cleaner, scrubbed the calipers, and hardware. I put silicone anti-squeal on the backs of the pads. I did a bed-in procedure as well.
Brakes now started squeeking 100 miles later. I drive over 500 miles per week for work, so it is quite annoying. I have replaced brakes on several BMWs in the past, so I am not a complete noob. I have Hawk pads on my e36 M3 that has over 30k miles and they never squeek at all. I was hoping to save some money by going with Textar.
I normally use copper anti-squeal, but Napa only had the silicone anti-squeal available.
I would appreciate any input or advice to help get rid of the squeeking.
Thank you!
Btonns is offline   Reply With Quote
Old October 31st, 2013, 17:34   #2
Btonns
TDI(s): 2006 Jetta
Any ideas before I start throwing more parts at it?
Old November 1st, 2013, 07:20   #3
Barnitz
Barnitz's Avatar
TDI(s): 2006 Jetta
Did you check the back brakes? VW Jettas are notorious for wearing out back brakes before fronts.
2006 Jetta 5-speed, GTB1749V from Darkside, Stage 2 Franko6 Cam, SBC Stage 2 Endurance Clutch with SMF, Malone Stage 2 custom tune w/Dynamic Idle and EGR Delete, Dieselgeek short shifter, EGR Cooler Deleted with Block-Off Plates, H&R Touring Cup Kit, ECS Dogbone Insert, Raxles
Barnitz is offline   Reply With Quote
Old November 1st, 2013, 20:14   #4
Btonns
TDI(s): 2006 Jetta
The pads are fine on the rear, but I am suspecting that I may have a warped rear rotor. I have new rear brake pads and rotors on the way. I am also going to check to see if the e-brake cables are adjusted too tight. Besides that, I do not know what else could be causing the squeaking.
Old November 1st, 2013, 20:53   #5
mctdi
TDI(s): 2010 Jetta
Are the guild pins moving freely?
Ben / mctdi
10/24/2015 => 300,262 miles
5/29/2010 Jetta 12 miles [new],
R.I.P. 2004 Golf 362,993 miles,
mctdi is offline   Reply With Quote
Old November 1st, 2013, 20:56   #6
MyAvocation
MyAvocation's Avatar
From your description the problem is not in the rear. With the amount of driving you do (long periods of pads floating on rotors) my assumption is one caliper is binding, causing excessive glaze on one pad. You can remove the glaze of one side to isolate which wheel, but I was taught to replace calipers in pairs to avoid uneven wear.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old November 10th, 2013, 18:01   #7
Btonns
TDI(s): 2006 Jetta
I replaced my rear rotors and pads as well. I noticed some resistance on the rotors, so I adjusted the parking brake cables. I used this guide and a Craftsman multi tool:
http://www.myturbodiesel.com/1000q/a...t-vw-jetta.htm
It only took about 10 minutes to get access to the cables.
So far I have driven about 30 miles with no noise. I'm keeping my fingers crossed!
Replaced my Brake Master Cylinder - Now Brake Problems!!!! HELP copatdir6 TDI 101 13 October 11th, 2013 13:44
A few annoying electrical problems DBogo VW MKIV-A4 TDIs (VE and PD) 12 November 2nd, 2012 10:53
Really annoying problems with Instrument Cluster. stevetwigs VW MKIII-A3/B4 TDIs 11 October 26th, 2010 10:22
Annoying brake sqeakiness MOGolf VW MKIV-A4 TDIs (VE and PD) 1 September 20th, 2002 00:38
Annoying fit and finish problems Lotfw TDI 101 4 August 15th, 2001 08:42
Page generated in 0.11702 seconds with 10 queries
[Output: 79.11 Kb. compressed to 68.70 Kb. by saving 10.41 Kb. (13.16%)]
