Old October 21st, 2013, 16:39   #1
phaser
Fuel Economy: 49 MPG B-20
Default SOLVED - ESP Light on, dangerous brakes randomly pull left or right
Solved - see post 19
A friend just moved to Arkansas, and called with the following problem.
04 Jetta TDI, 155k miles
ESP light flashes, and the brakes will randomly, on their own, engage, and pull hard left or right with no braking input from the driver, and without warning.
Dangerous to say the least.
Any ideas? Bad sensor?
2004 Jetta BEW 5M - 470k - 49 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old October 21st, 2013, 16:55   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Park the car and scan for codes.
Possible problems include (but are not limited to) YAW sensor and STEERING WHEEL position sensor.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old October 21st, 2013, 16:58   #3
phaser
Bill
Could the ABS be related?
Air Filter - EaA208
Old October 21st, 2013, 17:11   #4
40X40
Experienced
Absolutely!
The ABS is used by the ESP system to activate the brakes individually to help maintain control of the car.
The ABS light can be on because one or more of several parts of the system are acting up. A code scan will help narrow the list of suspects.
Bill
Old October 21st, 2013, 18:03   #5
phaser
Absolutely!
Bill
Got some additional info. When he has the car up on jacks, and spins the FRONT wheels fast, the esp light comes on, stays on, and goes off when the car is set back on the ground.
Thoughts?
I put him in touch with autenje (vag-com locator) in Little Rock to see if he can arrange a scan.
When the either the left or right brake kicks in, it's a sharp hard pull.
My friend has parked the car. He's scared to drive it anywhere.
Air Filter - EaA208
Old October 21st, 2013, 18:16   #6
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
DO NOT drive it anymore. You may cause a serious acciendent or injure yourself. One thing i always take seriously is braking components. sharp pull means the abs system is operating when it shouldnt.Get it towed. Might just be sensors or could be a new ABS pump. Scan first to find out the problem
Dannyboy is offline   Reply With Quote
Old October 21st, 2013, 18:31   #7
Losha
Losha's Avatar
Never seen such a odd ball issue, but most likely you have bad wheel speed sensor or faulty abs module that acts up and applies brakes to random wheels. As others suggested, get ABS module scanned.
VDUB Auto Repair www.vdubauto.com
Malone Tuning Dealer for SD, ND NE, IA, MN
'06 Jetta TDI DSG - Malone tune, Bilsteins B6, H&R Sport Springs, GLI front end, HID
Losha is offline   Reply With Quote
Old October 21st, 2013, 18:40   #8
phaser
Is there a speed sensor on all four wheels?
Air Filter - EaA208
Old October 21st, 2013, 18:44   #9
Dannyboy
Dannyboy's Avatar
That is a very strange fault,usually when you have faulty wheel sensor the abs system doesnt operate but you still get fully brakes ,they just lock up if you brake too hard. thinking more along the lines of what 40X40 said, YAW and poistion sensors playing havoc. could even be just one of the connectors to these are slighty loose causing intermited connection
Old October 21st, 2013, 18:46   #10
Dannyboy
Dannyboy's Avatar
Yes all four
Old October 21st, 2013, 18:50   #11
40X40
Experienced
http://en.wikipedia.org/wiki/Electro...bility_control
http://bostonvolkswagen.blogspot.com...ogram-esp.html
Not all of the above will apply to the car in question, but it is an interesting read nonetheless.
Bill
Old October 22nd, 2013, 16:03   #12
Zak3
it already happened on a friend audi a3, it was YAW sensor (under steering wheel) who was sending wrong information and make car act like that, to drive normally but without ESP, you can remove connector from YAW sensor, the ESP light will come on but no more random breaking.
Zak3 is offline   Reply With Quote
Old October 22nd, 2013, 16:54   #13
ta79pr
ta79pr's Avatar
TDI(s): 02 TTQ (BEW)
Fuel Economy: avg. 43
its still drivable if you pull the ABS/ESP fuse right, or is there more to it?
ta79pr is offline   Reply With Quote
Old October 22nd, 2013, 23:14   #14
phaser
This would be great. Can anyone confirm this?
What about turning off the ESP at the dash switch?
If either idea could make the car safely drivable to get to a TDI shop, this would help my friend out immensely.
I'm also loaning him my VCDS cable to scan.
Air Filter - EaA208
Old October 27th, 2013, 11:17   #15
phaser
This doesn't work. My friend pulled the fuse, and it just sets off all kinds of alarms.
Turning off the ESP at the switch didn't work either.
Still waiting for him to do a scan, and get any codes.
Air Filter - EaA208
Brake lights randomly come on and Brakes lock up when driving trdillon1 TDI 101 4 September 17th, 2010 22:13
Pull or push to left???? Dumanehu TDI 101 4 March 26th, 2005 09:23
No power from idle, dangerous when the light turns manfish VW MKIV-A4 TDIs (VE and PD) 5 October 1st, 2003 17:04
Cast on left foot...Is driving dangerous? TDI Golfer General VW Discussion 7 December 8th, 2002 18:57
Y2K Jetta - Pull To The Left... Help Please PLO231 VW MKIV-A4 TDIs (VE and PD) 11 September 8th, 2000 06:58
Page generated in 0.15856 seconds with 10 queries
[Output: 137.02 Kb. compressed to 115.32 Kb. by saving 21.70 Kb. (15.84%)]
