Originally Posted by tadawson
Dry bearings that bind as the blower motor warms up. Clean and lube it and see if that helps.
- Tim
And probably continuing to use it in this condition will burn out the resistor pack thermal fuse, or the blower power supply fuse.
Try the lube the bearings route or replace the blower/motor. It's pretty easy deal.
2004 Cadillac SLS (wife's)
