Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old October 19th, 2013, 16:56   #1
dqman01
Default Vw jetta tdi air filter
Just had my two 2011 jettas serviced for the 40,000 mile service.the dealership only recommended to replace the air filter on only one of my cars,should I have the other jettas air filter replaced?is it a DIY job that I can tackle or has anyone have any tips on how to do it myself?
dqman01 is offline   Reply With Quote
Old October 19th, 2013, 17:21   #2
JSWTDI09
JSWTDI09's Avatar
It's easy. All you need are some metric Allen wrenches. I think it is a 7mm (IIRC). You loosen a couple of screws, lift off the air box cover, pull out the old filter and stick in the new one. Put the cover back on and tighten the Allen screws. That's all.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old October 27th, 2013, 00:40   #3
Ol'Rattler
Ol'Rattler's Avatar
Read your maintenance schedule. IDK but have heard that the replacement interval has been changed to 60K miles.
If you do need to change the air filter, it is a very easy 10 minute job with nothing more than a Phillips screwdriver.
IDK about the Allen wrench thing, but on my 2006, it is something like 6 Phillips screws to replace the air filter with an Allen wrench only needed to remove the entire air cleaner box.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old October 27th, 2013, 06:47   #4
Trimmy
My 2010 is like 6-8 phillips head screw. Took me longer to find the phillips head bit for 1/4" impact (was doing a complete service and my work bench was full of tool) then it did to change the filter.
Soon to come Trimbach's Diesel Performance (TDP)
Mine: Grey 2000 Golf TDI, 04 Duramax TDP tuning
Wifes: Grey 2010 Jetta TDI DSG, Totally Stock.
Have VCDS USB HEX-CAN and VE and CR Timing Belt tools in Dayton, Oh, Willing to perform any services needed.
Trimmy is offline   Reply With Quote
Old October 28th, 2013, 06:27   #5
kcunniff
Even so, it never hurts to have clean filters. I am not sure how the air quality in Huntley, IL is, but I would gather it's pretty low in particulates (dust). Point being: dustier locales require more frequent air filter changes compared with less dustier locales. If you often drive on unpaved rural roads, you could be kicking up dust or driving behind someone who is, and this has the same effect. 40,000 miles seems like high time to change an important air filter, in my opinion.
kcunniff is offline   Reply With Quote
Old October 28th, 2013, 10:17   #6
Votblindub
Votblindub's Avatar
Air filters are cheap, I'd do it at 40kmi or sooner. They're not tough to do, give it a shot.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old October 28th, 2013, 10:21   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The increased the interval to 60k (up from 40k) probably because much of the time the air coming into the engine is coming in via one of the two EGR systems.
No need to replace it early, and on the ice-cube's-chance-in-Texas that it was actually clogged up, you'd have a MAF error and the ECU would know something was up.
oilhammer
www.cardocautomotive.com
06 VW TDI air filter\housing perrya VW MKV-A5 Golf/Jettas 5 August 2nd, 2012 05:14
2004 Jetta TDI Air filter?? deltatech TDI Fuel Economy 2 September 16th, 2008 19:57
2006 Jetta TDI Air Filter CincyAudi VW MKV-A5 Golf/Jettas 42 July 15th, 2008 15:00
>> Does the jetta tdi K&N air filter fit other VW ? highender TDI Power Enhancements 2 February 13th, 2007 17:29
Cabin Air Filter for VW Beetle, Golf & Jetta 1999- ancient Private TDI Items for Sale/Wanted 1 July 9th, 2005 06:05
Page generated in 0.13934 seconds with 10 queries
[Output: 82.47 Kb. compressed to 71.54 Kb. by saving 10.93 Kb. (13.25%)]
