Old October 12th, 2013, 10:37   #1
mk4rally
Default Wheel bolts conical vs ball for application?
I'm just wondering, the factory ball seat bolts fit fine on stock wheels but I'm running steelies..
With my wheel spacers I need all new bolts, wasnt sure if for plain black steelies, if ball seat is still the best option, or if conical is better because it will work with my aftermarket wheels in summer.,,,
I was told that the factory rims need ball seat bolts, which are fine... but what about normal steelies? They take either just as happily? Don't want to spend $100 twice for two sets of wheel bolts....
thanks.. please advise
mk4rally is offline   Reply With Quote
Old October 12th, 2013, 12:01   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
If the steels are vw then they're the same ball ended things, it's usually just after market wheels that take the conical ones.
Seatman is offline   Reply With Quote
Old October 12th, 2013, 12:13   #3
mk4rally
plain black steels.
no idea as to source
and im not sure about the difference, like if you use conical but should have used ball.. how bad/what effect results?
I ought to buy two sets just to be safe really.. and just avoid the problem, but its also possible that im using aftermarket black steelies with ball seat bolts right now, and they seem fine...
not an issue im familiar with.
Old October 12th, 2013, 16:01   #4
Seatman
Seatman's Avatar
They wont seat properly and might wear the holes down or something I'd imagine.
Old October 12th, 2013, 16:48   #5
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
The steel wheels (I've not ever seen cone seat steel wheels) will be more forgiving of a contact difference (cone seat into spherical socket) than would an alloy wheel.
The VW factory alloys with which I have familiarity (mark2, mark3, B4, B5) all used the ball seat as well.
Aftermarket, non-VW, alloy wheels might use cone seat.
Svante Arrhenius 1896
Old October 18th, 2013, 08:28   #6
Votblindub
Votblindub's Avatar
This.
Steelies are ok with most things, the holes in them are relatively flat and there's room for either cone or ball. Aftermarket wheels are a whole different story. You should be ok with either.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old October 18th, 2013, 09:07   #7
captaincaveman
Just be careful. I have seen 2 wheels run off (1 off each of 2 different vehicles) from using ball seat on aluminum cone seat wheels. The contact pattern was about a 1/8" ring that was actually doing all the holding.
captaincaveman is offline   Reply With Quote
Mk4 Conical Wheel Bolts PduBerer Ontario 2 April 3rd, 2013 09:25
Used mk4 alternator & pulley, Poly dog bone bushing, Conical Lug bolts, Hub rings etc Last_Wolf Private TDI Items for Sale/Wanted 26 December 26th, 2012 12:25
Removing bolts for removal of control arm/ball joint deadend9009 TDI 101 8 October 17th, 2008 18:02
Part number for ball-joint bolts? dkuster VW MKIV-A4 TDIs (VE and PD) 3 April 17th, 2007 17:51
FS: H&R 20mm Spacers W/ Ball Seat Extended Bolts letterman52 Private TDI Items for Sale/Wanted 0 January 14th, 2007 18:42
Page generated in 0.14301 seconds with 10 queries
[Output: 80.90 Kb. compressed to 70.08 Kb. by saving 10.82 Kb. (13.37%)]
