Old September 27th, 2013, 08:08   #1
fatbuck1911
Default EGR block off plate
i have a 98 jetta AHU, which block off plate do i need?
http://www.idparts.com/catalog/produ...roducts_id=780 thos one that doesnt have an ETG probe?
or
http://www.idparts.com/catalog/produ...oducts_id=3070 this one does?
and what is an ETG probe?
fatbuck1911 is offline   Reply With Quote
Old September 27th, 2013, 08:15   #2
csstevej
An EGT probe is a probe that is installed in the exhaust gasses to monitor exhaust temps. Usually people have this if they have their cars modded to watch that they don't over temp their turbos.
You would want the first one you listed.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old September 27th, 2013, 08:40   #3
fatbuck1911
will an ALH intake manifold fit on an AHU
Old September 27th, 2013, 08:42   #4
baja_brewer
Yes, as will the PD intakes
baja_brewer is offline   Reply With Quote
Old September 27th, 2013, 15:59   #5
WardB
WardB's Avatar
TDI(s): 2000 NB
Will the block off plate cause a fault code?
slow car fast
WardB is offline   Reply With Quote
Old September 27th, 2013, 16:34   #6
Curious Chris
Fuel Economy: 47/42/38
Most likely yes as the EGR lowers the MAF reading as it introduces exhaust gases after the MAF. Of course a tune can eliminate the fault code. I have RC4 and the block off plate + EGT as I am tuned up to 150 hp.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old September 29th, 2013, 07:01   #7
fatbuck1911
when i install the block off plate what should i do with the vacuum line that goes to the egr
Old September 29th, 2013, 07:28   #8
paramedick
paramedick's Avatar
....except that the intake opening is turned the wrong way. You can purchase a PD130 or 150 intake that will turn in the correct direction.
Stick a screw in the vac line. Better yet, do so just a few inches from the N18 valve.
Better yet? Leave the EGR functioning. With today's ULSD fuel, you may never have to clean it again.
An all TDI Family!!
Old September 29th, 2013, 08:03   #9
fatbuck1911
can i take the line off and leave that valve open? and i don't like the fact that exhaust is going into my engine even if the fuel is clean.
Old September 29th, 2013, 12:26   #10
paramedick
paramedick's Avatar
Just disconnecting the vacuum line and plugging it will accomplish the same thing. Leave the cooler connected to help your car warm faster in winter.
An all TDI Family!!
Old September 29th, 2013, 14:55   #11
Vince Waldon
Vince Waldon's Avatar
There's a wonderful long discussion about this in this other thread about removing the EGR... oh, wait....
http://forums.tdiclub.com/showthread.php?t=395942
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old September 29th, 2013, 18:37   #12
fatbuck1911
well i figured it was dead cuz no one responded to my last post....i got those block off plates. im just confused what to do with that vacuum line. i know he said to shove a screw in it but what about the nozzle on the egr that it connects to could i just leave that open and call it a day?
Old September 29th, 2013, 18:43   #13
TDI_
TDI_'s Avatar
Fuel Economy: Cool Stuff
yup most pics i seen here (including mine) is just let go. you are done with just blocking with plates and shoving a screw
Very First TDI_ 1998 Jetta (300)7,000 Miles On The Clock and Going Up Fast!!!
TDI_ is offline   Reply With Quote
Old September 29th, 2013, 18:46   #14
fatbuck1911
lol FINALLY THANKS MAN
Old October 1st, 2013, 10:57   #15
fatbuck1911
AFTER HOURS of blood sweat and tears and rage and going to auto zone to buy a stripped bolt removal kit and later on using a dremmel tool and cutting the whole pipe off i am finally done but not my car does this funny whisteling sound at 2200 rpms
wtb: EGR Block off plate robinhood Private TDI Items for Sale/Wanted 3 December 14th, 2010 10:17
WTB EGR block off plate Berniem Private TDI Items for Sale/Wanted 14 November 27th, 2010 11:39
Page generated in 0.16118 seconds with 10 queries
[Output: 120.47 Kb. compressed to 99.56 Kb. by saving 20.91 Kb. (17.36%)]
