No Abacus, I did that and loving it! I blocked mine off just at the block but this guy is trying to bypass the whole thing! What I got confused at is what he was trying to do. I still do not think he made his mind because he keeps changing his mind.
Here is what I did for my CCV fatbuck... blocked the CCV on the block with a block off plate (I can find you one if you need one!) I got a 3/4inch elbow to replace my puck and re-routed the hose to my BMW Cyclone oil separator(god darn cheap and works the best!). The separated gases then goes to my intake and it cut some of the smoke from my exhaust
Also I am about 90% leak free now. (trying to tap the weep hole and re-route it to my oil separator but cannot fit a barb without removing the manifold) I thought I had a bigger problem than CCV but no.
Sorry to wake you up to this Abacus
good morning!
