Old January 23rd, 2015, 16:55   #16
Idahosnoman
TDI(s): 2010 Jetta
I just got my Vag Com as well. As I was performing an auto scan, there were a few things that were in red. For example:
Address 25: Immobilizer
Cannot be reached
Please let me know if this is bad. I would post my scan but it has personal information serial numbers etc. on it and Im not sure what to delete or black out prior to posting it.
2010 Jetta TDi Sedan "My First TDi"
DSG Auto
Relex Silver
175000 Miles
Idahosnoman is offline   Reply With Quote
Old December 12th, 2015, 05:55   #17
reildawg
Cannot be reached
Someone else can feel free to correct me, but I think that simply means your car doesn't have an immobilizer installed, or its malfunctioning.
Sent from my Nexus 4 using Tapatalk
"Keep the water outside the boat"
reildawg is offline   Reply With Quote
Old December 14th, 2015, 05:28   #18
jason_
I'm scared to write because of this pop up
So I pick no to write my custom values? I'm trying to change drl, tpms to use wheels rotation, etc.
I got all original code saved, just scared to write new values!
On a 09.
Sent from my s-off'ed m7 with cm11!
jason_ is offline   Reply With Quote
Old December 14th, 2015, 05:57   #19
compu_85
Gadget Guy
compu_85's Avatar
Try No first. If it doesn't work then try Yes.
-J
Old December 14th, 2015, 06:39   #20
jason_
Positive no bad things will happen?
Old December 14th, 2015, 06:57   #21
compu_85
Gadget Guy
compu_85's Avatar
Yes that's just recording the dealer numbers in the control units. Think of it like an audi trail.
-J
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old December 14th, 2015, 08:28   #22
jason_
I did a few things. Drl down to 35 percent. Was going to disable, but carrying kids I kept them on, and they are killed while blinker active.
I did the can bus tpms disable, but not certain of 2 things.
How to enable wheel speed sensor monitoring via abs, and how to reset in vcds if an error is detected. I don't plan on installing the glove box reset switch any time soon.
Old December 14th, 2015, 13:33   #23
jason_
Not sure if it's been covered, I googled a bit and what little results I found, it was all British with no chime, ir American units with chime.
Well, I did this.
To kill door open chime, code to British, then go through mfd and change output units to American.
Done.
I de-dinged the doors and belts because i drive a lot on a huge apartment complex, jumping in/out a million times a day, in private property, sometimes exceeding 15mph, which triggers stuff.
It got annoying... Fast.....
Old December 16th, 2015, 08:22   #24
jason_
Anyone confirm drl deactivate during blink is overriden with instrument recode to British?
It seems I can't have drl deactivation during turn signal and no door chime.
Old December 16th, 2015, 15:14   #25
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Where's our Ross Tech friends on this one?
Post #18
Old December 16th, 2015, 16:08   #26
jason_
I'm past that. Now I'm finding out what I can and can't mix and match.
Apparently door chime drl suspension during turn signal isn't possible.
Oh well.
Old March 7th, 2016, 19:10   #27
compu_85
Gadget Guy
compu_85's Avatar
After having the clock spring recall done on our '12 Passat I discovered the dealer didn't recode the steering wheel module properly, meaning half the buttons on the steering wheel didn't work properly
I was able to use my saved auto scan to find the proper coding for the module and apply it. After clearing all the fault codes the steering wheel buttons are working properly again
Always auto scan first. Always save the file in a safe place.
-J
Present:
Past:
Old March 8th, 2016, 05:38   #28
jason_
Oh. Damn. I've changed so much, and have nothing saved. Haha. Is that bad? I'm always changing and recoding without writing or saving anything.
Sent from my s-off'ed m7 with CM11
Old December 31st, 2016, 11:57   #29
ckbarcus
Can vag-com reprogram the speedometer to 16"tires from 17's
ckbarcus is offline   Reply With Quote
Old January 4th, 2017, 08:23   #30
jason_
If the overall diameter is the same of road contact, it won't matter. Computer doesn't care or measure what's bolted on, it's what contacts the road...
Sent from my S-Off'ed HTC One...
vag-com finally jjohnv VW MKIV-A4 TDIs (VE and PD) 2 April 9th, 2009 02:17
VAG-COM came in Finally storx TDI 101 5 December 10th, 2006 13:59
Finally a Vag-Com in RI TDIinRI Eastern USA 4 August 28th, 2005 19:50
Finally got VAG-COM landon11 VW MKIV-A4 TDIs (VE and PD) 1 January 19th, 2005 10:23
finally got my Vag-com...car is way off!!! dbusch TDI Power Enhancements 6 December 2nd, 2004 17:29
Page generated in 0.15983 seconds with 10 queries
[Output: 126.13 Kb. compressed to 105.58 Kb. by saving 20.55 Kb. (16.30%)]
