Old September 13th, 2013, 21:00   #1
vdubdezl
vdubdezl's Avatar
Fuel Economy: 40-45 mpg
Question Finally just got vag-com. What should I check first?
I finally scrounged up enough money from side jobs to get my Hex-Can+USB Vag-com. I know I am going to check the timing again just because it hasn't been done since I put the EGR cooler back on. Also, where can I find the procedure for limiting the EGR? I've also had a constant problem fighting the Glow plug check engine code. I really hope it can narrow my focus on this too. Can vag-com be used like a tuner??
06 Jetta TDI 5MT
05 Honda Odyssey EX-L
"Evil will always win because good is dumb."
Lord Helmet Spaceballs
vdubdezl is offline   Reply With Quote
Old September 13th, 2013, 21:42   #2
JSWTDI09
JSWTDI09's Avatar
VCDS (Vag-Com) cannot be used as a tuner. It cannot modify the programming in any controller. However, it can change any configuration bits to enable or disable options.
As for what to do first - always start with an autoscan, and save the results. This will give you a baseline to go back to in case you change something and don't like the results. You will discover that your 2011 probably has a lot more configuration options than your 2001 does.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old September 14th, 2013, 06:55   #3
vdubdezl
vdubdezl's Avatar
Have Fun!
Don
I was pretty sure I couldn't do any "tuning", but just wanted to make sure. There are a few things I read about a while ago on the 11 JSW that I would like to do like adding foglights, etc. I'm sure the isn't much you can do with 01.
Is there a way on the 01 Golf I can make the trunk lock only when I lock the car like my JSW does? This really annoys me!
06 Jetta TDI 5MT
Old September 14th, 2013, 07:26   #4
compu_85
Gadget Guy
compu_85's Avatar
This is the best possible advice. Always do an auto scan first, and save it in a safe place.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
compu_85 is online now   Reply With Quote
Old September 14th, 2013, 07:47   #5
vdubdezl
vdubdezl's Avatar
-J
I can just save it to a file right? or do I physically need to write it down?
06 Jetta TDI 5MT
Old September 14th, 2013, 07:49   #6
compu_85
Gadget Guy
compu_85's Avatar
Save it to a .txt file (VCDS can do this for you). Then perhaps email it to yourself.
-J
Present:
Past:
Old September 15th, 2013, 18:18   #7
vdubdezl
vdubdezl's Avatar
Thanks for the info guys. After much searching and trying to remember how I saw the timing checked, I went to Ross-Tech's website and found a list of diagnostic settings/procedures on this page. I thought it would be helpful to others too.
http://www.ross-tech.com/vag-com/cars/index.html
06 Jetta TDI 5MT
Old June 30th, 2014, 20:11   #8
gmcjetpilot
gmcjetpilot's Avatar
As everyone said AUTO SCAN....the #1 most useful thing you can do with it.
This is what I have done with my VCDS:
  • Scan for codes and clear them
  • Change custom settings (number of blinks for soft turn light, windows up/down with key fob, brake lights flash under hard breaking and ABS is activated, coming home headlights....)
  • Measure performance while driving and plotting out.
  • Prime fuel system running tank and boost pumps.
To change engine performance, timing, fuel delivery (mapping), I don't
know. Personally I wouldn't do it. I do recall reading the manual if you
change engine parameters you better copy the old code before you
do... just in case. Otherwise you could make your engine not run at all.
gmcjetpilot is offline   Reply With Quote
Old July 9th, 2014, 12:24   #9
Ol'Rattler
Ol'Rattler's Avatar
Something you need to remember is that VCDS is just one of many tools in your tool kit. Hands down, the best tool you can own is having a working understanding of what you are working on.
When troubleshooting, VCDS doesn't tell you what the problem is, it tells you what the ECU sees. When a DTC (code) is set, you do not just change the part described in the text of the DTC, your next step is to figure out why the ECU set the code.
The last real problem I had with my car was a glow plug light and DTC's for glow plugs. Change the glow plugs, right? Not even close. The actual cause of the problem was a loose ground. Tightening the ground completely cured the problem. The proof was that the DTC's never came back after I cleared them.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old July 17th, 2014, 13:54   #10
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
^^^This bares repeating^^^
Troubleshoot the system, not the components. The cars computer controls are not that sophisticated.
BobnOH is online now   Reply With Quote
Old August 17th, 2014, 10:34   #11
vondiesel
Fuel Economy: 42mpg 650 per tank
where is the best place to pick up a vag-com and how much does it run?
vondiesel is offline   Reply With Quote
Old September 30th, 2014, 05:19   #12
Smalls
Www.ross-tech.com seems to be the go to place.
Depending on what your needs are, you're looking between 300-500 dollars.
Smalls is offline   Reply With Quote
Old October 1st, 2014, 22:52   #13
matthew83544
Is there anyone in or near Lewiston, Idaho who has vag-com? I've got a glow plug light on my 2011 and can't even find the bently manual. Maybe some suggestions? The plugs seem fine, but I don't know about pressure sensors that are incorporated in them? Also I was told about a relay, but couldn't find any.
Thanks,
Matthew
matthew83544 is offline   Reply With Quote
Old October 2nd, 2014, 08:27   #14
forcedfedbug
Matthew,
There are no betley manuals after 2k8 or so. If you want a repair manual you either need to buy some time on ebaun and download everything you can or get another type repair manual.
On a side note I am no where near Idaho unless you are talking 1 tank of fuel one way, Sorry.
Ron
forcedfedbug is offline   Reply With Quote
Old December 31st, 2014, 10:06   #15
jimmyjay6
TDI(s): BMW
You can also check these guys (check engine Light) guys. They sometimes have great deals.
jimmyjay6 is offline   Reply With Quote
vag-com finally jjohnv VW MKIV-A4 TDIs (VE and PD) 2 April 9th, 2009 03:17
VAG-COM came in Finally storx TDI 101 5 December 10th, 2006 14:59
Finally a Vag-Com in RI TDIinRI Eastern USA 4 August 28th, 2005 20:50
Finally got VAG-COM landon11 VW MKIV-A4 TDIs (VE and PD) 1 January 19th, 2005 11:23
finally got my Vag-com...car is way off!!! dbusch TDI Power Enhancements 6 December 2nd, 2004 18:29
Page generated in 0.12279 seconds with 10 queries
[Output: 134.91 Kb. compressed to 113.22 Kb. by saving 21.69 Kb. (16.08%)]
