veedubgolf00
Just wondering if the panels will swap between cars with no modification. I'm mainly looking to do just the rears
The Golf and Jetta door panels can be separated along a horizontal seam with a heat gun (they are plastic welded together). You can then attach the bottoms from a Jetta to the tops from a Golf or vice versa. (In other words, it's only the tops that are different.) Not easy but doable if you're having trouble locating the exact door panels that you want..4 door golf and Jetta rear panels are different and will not interchange. Wagon rear panels are also different.
Hi R-Truck, how or what clue did you use to attach the leather insert to the rear Gold door panel?Door cards. I had to swap the leather inserts from an 01 Jetta Sedan to my 02 4-door golf because the complete panels wouldn't swap directly.
