Old September 2nd, 2013, 13:53   #1
tta
Default Replace Mechatronics unit ??
What is involved in replacing the mechatronics unit ??
Would like to hear from someone that has actually done one.
Just had mine done, and I thought it was very complicated, but after talking to the service manager it sounded like its a pretty simple task.
IE drain it , remove the mech pan on the bottom of the trans, pull the unit out, install new one and adjust and add fluid and new filter etc.
Looking at a photo of one out, it looks very simple.
Can you even order these units ??
Also just read they have to be programmed according to the VIN number ??
tta is offline   Reply With Quote
Old September 3rd, 2013, 18:01   #2
meerschm
meerschm's Avatar
http://www.youtube.com/watch?v=trhfvm5aJAY
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old November 14th, 2013, 21:04   #3
fwthompson
idparts.com sells them. Also check boraparts.com they are around $1200 tho. Why do you think you need one? Also some have had luck getting the dealer to replace transmission parts for recall purposes maybe call and check your VIN.... good luck.
fwthompson is offline   Reply With Quote
Old November 14th, 2013, 21:07   #4
tta
Trans dropped out into limp mode, stuck in 1st, no rev.
Dealer ran a check and said needs a new mechatronics unit.
VW America would not offer any help. The dealer gave me a $150 credit.
Ended up being $2350 out the door.
WTB 2006 Mechatronics unit mack42b Private TDI Items for Sale/Wanted 1 March 28th, 2013 06:46
Mechatronics unit needed for 06 tdi 2500hd2 Private TDI Items for Sale/Wanted 0 September 9th, 2011 09:14
How to replace a Mechtronics unit? 87homebuilttdi VW MKV-A5 Golf/Jettas 1 July 4th, 2011 08:12
WTB Mechatronics unit DSG 2500hd2 Private TDI Items for Sale/Wanted 7 December 15th, 2010 14:31
Replace entire turbo unit? jettafuel VW MKIV-A4 TDIs (VE and PD) 10 July 25th, 2010 14:35
Page generated in 0.08660 seconds with 10 queries
[Output: 61.44 Kb. compressed to 54.97 Kb. by saving 6.47 Kb. (10.53%)]
